path: root/arch/sparc
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-04sparc: merge CONFIG_SYS_CPU and CONFIG_SYS_VENDOR definesMasahiro Yamada
For now, all the SPARC boards in U-Boot are provided by Gaisler. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-11-04sparc: merge arch/sparc/cpu/*/config.mk to arch/sparc/config.mkMasahiro Yamada
Remove arch/sparc/cpu/{leon2,leon3}/config.mk and move duplicated defines of -fPIC to arch/sparc/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-11-04sparc: move CONFIG_{LEON, LEON2, LEON3} to KconfigMasahiro Yamada
2014-11-04sparc: Use nicer prompt for board select menuMasahiro Yamada
The Board names in the board select menu were simply taken from the board directory name by a conversion tool when switching to Kconfig. Let's use more descriptive prompts taken from include/configs/gr*.h and board/gaisler/*/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-22sparc: merge LEON2 and LEON3 linker scriptsMasahiro Yamada
There is only one line diff between LEON2 and LEON3 linker scripts: - arch/sparc/cpu/leon2/start.o (.text) + arch/sparc/cpu/leon3/start.o (.text) They can be written in the same way: */start.o (.text) So, board/gaisler/grsim_leon2/u-boot.lds and arch/sparc/cpu/leon3/u-boot.lds can be merged into arch/sparc/cpu/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-22sparc: merge LEON3 linker scriptsMasahiro Yamada
The linker scripts of LEON3 - board/gaisler/grsim/u-boot.lds - board/gaisler/gr_cpci_ax2000/u-boot.lds - board/gaisler/gr_ep2s60/u-boot.lds - board/gaisler/gr_xc3s_1500/u-boot.lds are the same (except cosmetic differences such as indentation). This commit merges them into arch/sparc/cpu/leon3/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-05-08leon: implement missing get_tbclk()Daniel Hellstrom
Without this patch SPARC/LEON does not build. Reported-by: Tom Rini <trini@ti.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2014-05-08leon: use CONFIG_SYS_HZ to config timer prescalerDaniel Hellstrom
Before it was hardcoded to 1000 ticks per second. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2014-03-21sparc: consolidate CONFIG_{LEON, LEON2, LEON3} definitionMasahiro Yamada
CONFIG_LEON is already defined in arch/sparc/cpu/{leon2,leon3}/config.mk. Remove the redundant definition in board header files. All leon3 boards define CONFIG_LEON3 in board header files. Move the definition to arch/sparc/cpu/leon3/config.mk. CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-03-10usb: create common header virtual root hub descriptorsStephen Warren
Many USB host controller drivers contain almost identical copies of the same virtual root hub descriptors. Put these into a common file to avoid duplication. Note that there were some very minor differences between the descriptors in the various files, such as: - USB 1.0 vs. USB 1.1 - Manufacturer/Device ID - Max packet size - String content I assume these aren't relevant. Cc: Thomas Lange <thomas@corelatus.se> Cc: Shinya Kuribayashi <skuribay@pobox.com> Cc: Gary Jennejohn <garyj@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Eric Millbrandt <emillbrandt@coldhaus.com> Cc: Pierre Aubert <p.aubert@staubli.com> Cc: Stefan Roese <sr@denx.de> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Denis Peter <d.peter@mpl.ch> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Zhang Wei <wei.zhang@freescale.com> Cc: Mateusz Zalega <m.zalega@samsung.com> Cc: Remy Bohmer <linux@bohmer.net> Cc: Markus Klotzbuecher <mk@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Gary Jennejohn <garyj@denx.de> Cc: C Nauman <cnauman@diagraph.com> Cc: David Müller <d.mueller@elsoft.ch> Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Thomas Abraham <t-abraham@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Andrew Murray <amurray@embedded-bits.co.uk> Cc: Matej Frančeškin <matej.franceskin@comtrade.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Bryan Wu <cooloney@gmail.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-03-07config.mk: specify the exact path to standalone linker scriptMasahiro Yamada
We want to change the build system to include config.mk only from ./Makefile and spl/Makefile. We must prepare for that in this commit. $(src) is a moving target and not handy for our purpose. We must replace it with a fixed path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-25sparc: Correct arch/sparc/cpu/leon3/start.S from SPDX conversionTom Rini
The SPDX tag conversion ate part of this file, put things back to the way they should be. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08sparc: include config.h to start.SMasahiro Yamada
arch/sparc/cpu/leon3/start.S requires CONFIG_SYS_SPARC_NWINDOES to be defined: #ifndef CONFIG_SYS_SPARC_NWINDOWS #error Must define number of SPARC register windows, default is 8 #endif But it missed to include <config.h>, which always ended up in compile error. This commit fixes this problem. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2013-10-31sparc: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-31sparc: fix a link errorMasahiro Yamada
Before this commit, arch/sparc/lib/Makefile used both COBJS and COBJS-y. And it missed to add COBJS-y into OBJS. This means bootm.o was never compiled even if CONFIG_CMD_BOOTM=y Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2013-10-20usb: add enum usb_init_type parameter to usb_lowlevel_initTroy Kisky
This parameter will later be used to verify OTG ports. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-14sparc: Use image_setup_linux() instead of local codeSimon Glass
Sparc only really sets up the ramdisk, but we should still use image_setup_linux() so that setup is common across all architectures that use the FDT. Cover-letter Introduce a common image_setup_linux() function This series continues the work to tidy up the image code. Each architecture has its own code for setting up ready for booting linux. An attempt is made here to unify these in a single image_setup_linux() function. The part of the image code that deals with FDT is split into image-fdt.c and a few tweaks are added to make FIT images more viable in SPL. END Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15sparc: Fix build warnings in serial.cSimon Glass
These macros are already defined in io.h so should not be declared in serial.c. serial.c:38:0: warning: "READ_BYTE" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:36:0: note: this is the location of the previous definition serial.c:39:0: warning: "READ_HWORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:37:0: note: this is the location of the previous definition serial.c:40:0: warning: "READ_WORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:38:0: note: this is the location of the previous definition serial.c:41:0: warning: "READ_DWORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:39:0: note: this is the location of the previous definition Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15sparc: Fix out-of-tree buildingSimon Glass
It isn't clear why the sparc cpu Makefile has its own compile line, but it does not work correctly with an out-of-tree build. Removing it fixes this problem. Perhaps it does not introduce others. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-19malloc: make malloc_bin_reloc staticGabor Juhos
On architectures where manual relocation is needed, the 'malloc_bin_reloc' function must be called after 'mem_malloc_init'. Make the 'malloc_bin_reloc' function static and call it directly from 'mem_malloc_init' instead of calling that from board_init_{r,f} functions of the affected architectures. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-04sparc: Use generic global_dataSimon Glass
Move sparc over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04sparc: Drop kbd_status and reset_status from global_dataSimon Glass
These fields is not used on sparc, so punt them. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-11Add strcasecmp() and strncasecmp()Simon Glass
strncasecmp() is present as strnicmp() but disabled. Make it available and define strcasecmp() also. There is a only a small performance penalty to having strcasecmp() call strncasecmp(), so do this instead of a standalone function, to save code space. Update the prototype in arch-specific headers as needed to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19sparc: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15usb: lowlevel interface change to support multiple controllersLucas Stach
Carry an index in the lowlevel usb functions to make specify the respective usb controller. Also pass through an controller struct from lowlevel_init to the creation of the root usb device of this controller. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from serial driversMarek Vasut
Remove the support for not-CONFIG_SERIAL_MULTI part from serial port drivers and some board files. Since CONFIG_SERIAL_MULTI is now enabled by default, that part is a dead code. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: sparc: Implement CONFIG_SERIAL_MULTI into leon3 serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into leon3 serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the leon3 driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2012-10-15serial: sparc: Implement CONFIG_SERIAL_MULTI into leon2 serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into leon2 serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the leon2 driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2012-09-26malloc: remove extern declarations of malloc_bin_reloc() in board.c filesDaniel Schwierzeck
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations in various board.c files to get rid of one checkpatch.pl warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
2012-09-18dm: sparc: Fixup the compile warnings in sparc codeMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: u-boot-dm@lists.denx.de
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
