path: root/arch/sparc/lib/bootm.c
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-14sparc: Use image_setup_linux() instead of local codeSimon Glass
Sparc only really sets up the ramdisk, but we should still use image_setup_linux() so that setup is common across all architectures that use the FDT. Cover-letter Introduce a common image_setup_linux() function This series continues the work to tidy up the image code. Each architecture has its own code for setting up ready for booting linux. An attempt is made here to unify these in a single image_setup_linux() function. The part of the image code that deals with FDT is split into image-fdt.c and a few tweaks are added to make FIT images more viable in SPL. END Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15usb: lowlevel interface change to support multiple controllersLucas Stach
Carry an index in the lowlevel usb functions to make specify the respective usb controller. Also pass through an controller struct from lowlevel_init to the creation of the root usb device of this controller. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2011-12-05sparc: fix unused variable warningsMike Frysinger
Fix the build warnings: board.c: In function 'board_init_f': board.c:179:8: warning: unused variable 'e' board.c:178:6: warning: unused variable 'i' board.c:173:13: warning: unused variable 'cmdtp' bootm.c: In function 'do_bootm_linux': bootm.c:101:28: warning: unused variable 'kernend' bootm.c:101:15: warning: unused variable 'initrd_addr' bootm.c:100:26: warning: unused variable 'checksum' bootm.c:100:21: warning: unused variable 'len' bootm.c:100:15: warning: unused variable 'data' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
