Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
Update the LEON2/3 serial driver to make use of the readl and writel
macros as well as the WATCHDOG_RESET() macro.
Add readl/writel and friends to the asm/io.h file.
Introduce the gd->arch.uart variable to store register address.
Lastly, remove baudrate scaler macro variables from board config. It
is now calculated in the serial driver using the global data variable.
Fixes broken search and replaced license changes in
files cpu/leon3/start.S and include/asm/winmacro.h
from commit 1a4596601fd395f3afb8f82f3f840c5e00bdd57a
Series-to: u-boot
Series-cc: Tom Rini <trini@konsulko.com>
Series-version: 2
Cover-letter:
sparc: Updates to SPARC architecture in preperation for generic board
This patch series is a backlog of preparation work for upcomming
generic board changes.
I first want to get these reviewed and submitted to mainline before
sending out more patches.
END
Remove arch/sparc/cpu/{leon2,leon3}/config.mk and move duplicated
defines of -fPIC to arch/sparc/config.mk.
Cc: Daniel Hellstrom <daniel@gaisler.com>
There is only one line diff between LEON2 and LEON3 linker scripts:
- arch/sparc/cpu/leon2/start.o (.text)
+ arch/sparc/cpu/leon3/start.o (.text)
They can be written in the same way:
*/start.o (.text)
So, board/gaisler/grsim_leon2/u-boot.lds
and arch/sparc/cpu/leon3/u-boot.lds
can be merged into arch/sparc/cpu/u-boot.lds.
The linker scripts of LEON3
- board/gaisler/grsim/u-boot.lds
- board/gaisler/gr_cpci_ax2000/u-boot.lds
- board/gaisler/gr_ep2s60/u-boot.lds
- board/gaisler/gr_xc3s_1500/u-boot.lds
are the same (except cosmetic differences such as indentation).
This commit merges them into arch/sparc/cpu/leon3/u-boot.lds.
Without this patch SPARC/LEON does not build.
Reported-by: Tom Rini <trini@ti.com>
Before it was hardcoded to 1000 ticks per second.
CONFIG_LEON is already defined in
arch/sparc/cpu/{leon2,leon3}/config.mk.
Remove the redundant definition in board header files.
All leon3 boards define CONFIG_LEON3 in board header files.
Move the definition to arch/sparc/cpu/leon3/config.mk.
CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk
as well.
Many USB host controller drivers contain almost identical copies of the
same virtual root hub descriptors. Put these into a common file to avoid
duplication.
Note that there were some very minor differences between the descriptors
in the various files, such as:
- USB 1.0 vs. USB 1.1
- Manufacturer/Device ID
- Max packet size
- String content
I assume these aren't relevant.
Cc: Thomas Lange <thomas@corelatus.se>
Cc: Shinya Kuribayashi <skuribay@pobox.com>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Eric Millbrandt <emillbrandt@coldhaus.com>
Cc: Pierre Aubert <p.aubert@staubli.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Zhang Wei <wei.zhang@freescale.com>
Cc: Mateusz Zalega <m.zalega@samsung.com>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Markus Klotzbuecher <mk@denx.de>
Cc: C Nauman <cnauman@diagraph.com>
Cc: David Müller <d.mueller@elsoft.ch>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Thomas Abraham <t-abraham@ti.com>
Cc: Tom Rini <trini@ti.com>
Cc: Andrew Murray <amurray@embedded-bits.co.uk>
Cc: Matej Frančeškin <matej.franceskin@comtrade.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Bryan Wu <cooloney@gmail.com>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
The SPDX tag conversion ate part of this file, put things back to the
way they should be.
arch/sparc/cpu/leon3/start.S requires CONFIG_SYS_SPARC_NWINDOES
to be defined:
#ifndef CONFIG_SYS_SPARC_NWINDOWS
#error Must define number of SPARC register windows, default is 8
#endif
But it missed to include <config.h>, which always ended up in compile error.
This commit fixes this problem.
This parameter will later be used to verify OTG ports.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
[trini: Fixup common/cmd_io.c]
These macros are already defined in io.h so should not be declared in
serial.c.
serial.c:38:0: warning: "READ_BYTE" redefined
/home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:36:0: note: this is the location of the previous definition
serial.c:39:0: warning: "READ_HWORD" redefined
/home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:37:0: note: this is the location of the previous definition
serial.c:40:0: warning: "READ_WORD" redefined
/home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:38:0: note: this is the location of the previous definition
serial.c:41:0: warning: "READ_DWORD" redefined
/home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:39:0: note: this is the location of the previous definition
It isn't clear why the sparc cpu Makefile has its own compile line, but
it does not work correctly with an out-of-tree build. Removing it fixes
this problem. Perhaps it does not introduce others.
Replace the in-place ad-hoc implementation of serial_puts() within
the drivers with default_serial_puts() call. This cuts down on the
code duplication quite a bit.
Cc: Marek Vasut <marek.vasut@gmail.com>
Carry an index in the lowlevel usb functions to make specify the
respective usb controller.
Also pass through an controller struct from lowlevel_init to the
creation of the root usb device of this controller.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Remove the support for not-CONFIG_SERIAL_MULTI part from serial
port drivers and some board files. Since CONFIG_SERIAL_MULTI is
now enabled by default, that part is a dead code. Remove it.
Implement support for CONFIG_SERIAL_MULTI into leon3 serial driver.
This driver was so far only usable directly, but this patch also adds
support for the multi method. This allows using more than one serial
driver alongside the leon3 driver. Also, add a weak implementation
of default_serial_console() returning this driver.
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: u-boot-dm@lists.denx.de
Common code has a mdelay() func, so use that instead of the usb-specific
wait_ms() func. This also fixes the build errors:
ohci-hcd.c: In function 'submit_common_msg':
/usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available
ohci-hcd.c:1519:9: sorry, unimplemented: called from here
ohci-hcd.c:1816:10: sorry, unimplemented: called from here
ohci-hcd.c:1827:10: sorry, unimplemented: called from here
ohci-hcd.c:1844:10: sorry, unimplemented: called from here
ohci-hcd.c:1563:11: sorry, unimplemented: called from here
ohci-hcd.c:1583:9: sorry, unimplemented: called from here
make[1]: *** [ohci-hcd.o] Error 1
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source
tree, which could cause issues with the patchwork review system.
This commit converts all ISO-8859 files to UTF-8.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Recieve/Receive
recieve/receive
Interupt/Interrupt
interupt/interrupt
Addres/Address
addres/address
Signed-off-by: Mike Williams <mike@mikebwilliams.com>
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
Signed-off-by: Andreas Biemann <andreas.devel@googlemail.com>
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
Signed-off-by: Loc Minier <loic.minier@linaro.org>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
