path: root/arch/sparc/Kconfig
2014-11-04sparc: merge CONFIG_SYS_CPU and CONFIG_SYS_VENDOR definesMasahiro Yamada
For now, all the SPARC boards in U-Boot are provided by Gaisler. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-11-04sparc: move CONFIG_{LEON, LEON2, LEON3} to KconfigMasahiro Yamada
2014-11-04sparc: Use nicer prompt for board select menuMasahiro Yamada
The Board names in the board select menu were simply taken from the board directory name by a conversion tool when switching to Kconfig. Let's use more descriptive prompts taken from include/configs/gr*.h and board/gaisler/*/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
