path: root/arch/sh
2019-02-07sh: bitops: add hweight*() macrosVignesh R
Add hweight*() macros required for moving to new SF layer Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-11-18Kbuild: add LDFLAGS_STANDALONEDaniel Schwierzeck
Introduce a new Makefile variable for passing LDFLAGS to standalone programs. Currently the variable CONFIG_STANDALONE_LOAD_ADDR is misued on some archs to pass a specific linker script. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-09-15sh: tmu: Zap get_tbclk and timer_read_counterMarek Vasut
Replace those two functions with generic ones by defining the timer macros in include/config/*.h . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Clean up register usageMarek Vasut
The code uses all in all three TMU registers, drop the massive register layout structures and just define the required timer registers and use them throughout the code. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Inline sh_tmu.hMarek Vasut
The header contains only the TMU register layout, just inline it into the TMU timer implementation and drop the header completely. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SH_TMU_CLK_FREQMarek Vasut
The R-Car Gen2 feeds the TMU with CONFIG_SYS_CLK_FREQ / 2, while the old SH parts use CONFIG_SYS_CLK_FREQ directly. Just put this into the TMU implementation and drop the CONFIG_SH_TMU_CLK_FREQ config option. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Inline get_tmu0_clk_rate()Marek Vasut
This function just returns CONFIG_SH_TMU_CLK_FREQ, use the constant directly instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Inline tmu_timer_{start,stop}()Marek Vasut
These functions are always called for timer = 0, so drop the timer check. Since these functions are called from one place only and they are reduced to one line of code, just inline them. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Simplify the tmu_bit mathMarek Vasut
The tmu_bit value evaluates to (ffs(4) >> 1) - 1 = (3 >> 1) - 1 = 0. Just drop the tmu_bit completely as well as CONFIG_SYS_TMU_CLK_DIV. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SYS_TMU_CLK_DIVMarek Vasut
This constant is always 4 , for all boards that exist. Define it once in arch/sh/lib/time.c and remove it from the configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: sh7724: Drop EDMR macroMarek Vasut
Drop the macro as it is never used and it collides with sh_eth.h macros. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-09-10arch: types.h: factor out fixed width typedefs to int-ll64.hMasahiro Yamada
All architectures have the same definition for s8/16/32/64 and u8/16/32/64. Factor out the duplicated code into <asm-generic/int-ll64.h>. BTW, Linux unified the kernel space definition into int-ll64.h a few years ago as you see in Linux commit 0c79a8e29b5f ("asm/types.h: Remove include/asm-generic/int-l64.h"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-23sh: Do not provide strncmpTom Rini
With modern GCC, we get warnings such as: cmd/jffs2.c: In function 'mtdparts_init': arch/sh/include/asm/string.h:110:38: warning: array subscript is above array bounds [-Warray-bounds] : "0" (__cs), "1" (__ct), "r" (__cs+__n) ~~~~^~~~ This results in a small size reduction as well. Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-21sh: Use -m2a-nofpu onlyTom Rini
Based on reading over the GCC manual, passing both -m2a and -m2a-nofpu are redundant, as -m2a-nofpu will provide functional code for both. As -m2a-nofpu functions with more toolchains and does what is expected, switch. Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02sh: Use asm-generic/io.hPaul Burton
Convert the sh architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for sh this is primarily a matter of moving code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-27sh: Fix linking of ms7722seTom Rini
While it is true that we no longer have 'ppcenv' and similar sections, including env/embedded.o at all results in the text/etc sections being available for the rest of the link. This in turn is required for the setup used on ms7722se. This also, likely, needs further fine-tuning. Fixes: f40ad66fa066 ("arch/sh: don't bring common/env_embedded.o into the link") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-26arch/sh: don't bring common/env_embedded.o into the linkThomas Petazzoni
The linker script for SuperH brings the .ppcenv and .ppcenvr section of common/env_embedded.o into the .text section. However, the .ppcenv section is only ever filled in by env_embedded.o when CONFIG_SYS_USE_PPCENV is defined, but no platforms in mainline U-Boot use this. In addition, common/env_embedded.o is not always built (when you use CONFIG_ENV_IS_NOWHERE for example), which causes the following build failure: Fixes: LD u-boot /home/thomas/sh4aeb-linux-musl/bin/sh4aeb-linux-ld.bfd: cannot find common/env_embedded.o We fix this by no longer adding the .ppcenv and .ppcenvr sections from common/env_embedded.o into the .text section. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26arch/sh: allow building in big-endian modeThomas Petazzoni
The SuperH architecture allows to be run in either little or big endian mode. Some SuperH SoCs get the little vs. big endian decision through mode pins sampled at reset, so if big endian has been choosen by HW designers, it cannot be easily changed. Therefore, it makes sense to allow building U-Boot for SuperH in big endian mode. To allow this, the only change needed is to adjust the OUTPUT_FORMAT() in the linker script. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SH_ZIMAGEBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SH_ZIMAGEBOOT Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2016-12-02sh: generate position independent code for all platformsVladimir Zapolskiy
Finally add fpic compilation option to produce relocatable code. Note that this requires to define CONFIG_NEEDS_MANUAL_RELOC for all board files, also relocation support still has some limitations (e.g. a developer should care not to overwrite the executing code or memset() with zeroes not yet relocated data on malloc init etc.), which may be fixed while switching to PIE. Due to short investigation the architecture code is not ready for PIE linking, this will require some manipulations with .dyn* sections. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: share the correct version of start.S among all cpusVladimir Zapolskiy
It is easy to note that SH2/SH3/SH4 start.S code is practically the same with a minor difference for SH2 where a short data header is present. To avoid unwanted code duplication and to automatically convert SH2 and SH3 platforms to generic board support move fixed SH4 start.S into arch/sh/lib/start.S and share it among all platforms. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: fix start.S by calling board_init_f() after first code relocationVladimir Zapolskiy
Like on ARM platform keep the first code relocation from a U-boot image storage to RAM at CONFIG_SYS_TEXT_BASE, then pass execution to a generic board_init_f() with empty GD flags. If CONFIG_SYS_TEXT_BASE is equal to a calculated by board_init_f() relocation address there will be no more code and data copy, however it's worth to mention that the first copy happens even if $pc on _start is the same as CONFIG_SYS_TEXT_BASE, on practice this works without a problem. Also note that _sh_start is renamed back to _start to correct gd->mon_len calculation by setup_mon_len(), the opposite rename was done in pre-generic board commit 2024b968ee9 ("sh: Fix build in start.S"). Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: add shared relocate_code() function and call board_init_r()Vladimir Zapolskiy
Commits b61e90e6fd83 ("sh: Drop the arch-specific board init") and f41e6088eb1a ("sh: Fix build errors for generic board") left code and data relocation done in start.S, however further actual U-boot configuration is not started anymore. Practically SH boards with the code relocated into the expected position by start.S still can be booted, so the change adds this option and provides an option how to relocate code for board_init_r() execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: add common dram_init() function for all boardsVladimir Zapolskiy
Generic board support assumes a different method of specifying DRAM size on board, also it can be shared among all boards, notably only sh7763rdp board has a custom legacy dram_init(), however the difference is only in printing some additional information, this feature can be removed. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: add MEMORY command to a shared linker scriptVladimir Zapolskiy
At the moment in runtime all defined sections are copied into or created in RAM, specify this explicitly to assert potential out of RAM placements of the sections. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: define entry point and reloc_dst inside a linker scriptVladimir Zapolskiy
No functional change, concentrate linker script commands in one place for convenience. Entry point is set to CONFIG_SYS_TEXT_BASE by default on build, so this option can be omitted from being added to the linker script. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: place board lowlevel_init code in the beginning of .textVladimir Zapolskiy
Reference lowlevel_init of all supported SH2A/SH3/SH4/SH4A boards from a shared linker script, the lowlevel_init function will be called by a relative address. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: use single u-boot linker script for all boardsVladimir Zapolskiy
Three supported SH4/SH4A boards with the bootloader image stored on SPI flash have own flavour of a linker script, in turn they are equal among each other. The only difference is that the text from lowlevel_init.o is placed right after start.o, which makes sense. Note that .bss section is not marked as NOLOAD, because for about 10 years this is a default option of a GNU linker, either the attribute is found or not the resulting image file is the same. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: remove __io config options from r2dplus and r7780mp boardsVladimir Zapolskiy
Defined __io is no-op for the SH architecture and it can be removed from board files without any functional change. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: move exported cache manipulation functions into cache.cVladimir Zapolskiy
No functional change, moving cache manipulation functions into cache.c allows to collect all of them in a single location and as a pleasant side effect cache_control() function can be unexported now. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: cache: don't modify CCR from P1 areaVladimir Zapolskiy
cache_wback_all() is a local function and it is called from cache_control() only, which is in turn jumps to P2 area. The change fixes an issue when cache_wback_all() returns from P2 to P1, however cache_control() continues to manipulate with CCR register, according to the User's Manual this is restricted. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: cache use jump_to_P2() and back_to_P1() from asm/system.hVladimir Zapolskiy
Both jump_to_P2() and back_to_P1() functions are found in asm/system.h header file and functionally they are the same, don't redefine them. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh3: remove unused cache.c file from being builtVladimir Zapolskiy
The change is similar to commit 994b56616bae ("sh: delete an unused source file") for SH2, however here the removed cache.c file was built and included into an image as a dead code. If it is needed in future the contents can be reused from a similar arch/sh/cpu/sh4/cache.c file, which is in turn will be moved to a shared among all core flavours location at arch/sh/lib/cache.c. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: correct flush_cache() to writeback and invalidateVladimir Zapolskiy
In common usecases flush_cache() assumes both cache invalidation and write-back to memory, instead of doing cache invalidation only with the wrapped 'ocbi' instruction pin flush_cache() to cache invalidation with memory write-back done by 'ocbp'. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: correct dcache flush to invalidate with write-backVladimir Zapolskiy
In common usecases flush_cache() assumes both cache invalidation and write-back to memory, thus in flush_dcache_range() implementation change SH4 cache write-back only instruction 'ocbwb' with cache purge instruction 'ocbp', according to the User's Manual there should be no performance penalty for that. Note that under circumstances only cache invalidation is expected from flush_cache() call, in these occasional cases the current version of flush_cache() works, which is a wrapper over invalidate_dcache_range() at the moment, this will be fixed in the following change. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-10-19efi: Use asmlinkage for EFIAPISimon Glass
This is required for x86 and is also correct for ARM (since it is empty). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-07-14arm, nds32, sh: remove useless ioremap()/iounmap() definesMasahiro Yamada
These defines are valid only when iomem_valid_addr is defined, but I do not see such defines anywhere. Remove. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27Drop references to CONFIG_SYS_GENERIC_BOARD in config filesSimon Glass
This option is no longer used so need not be enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-27sh: Drop the arch-specific board initSimon Glass
It is well past the deadline for conversion to generic board init. Remove the old code. Please test this and perhaps send a follow-up patch if needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-27sh: Fix build errors for generic boardSimon Glass
This includes the following fixes: - Define needed __init_end symbol - see initr_reloc_global_data() - Drop SH-specific struct bd_info - Add an empty relocate_code() function This prevents build errors with generic board, but the code will still need work. Perhaps this is a better alternative than deleting the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-05sh: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
