path: root/arch/sh
2011-12-02sh: Add support Renesas SH7724Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: avoid multiple definition errors with cache funcsMike Frysinger
Recent builds for SH4 boards fail with a lot of errors like: cmd_mem.o: In function 'dcache_invalid_range': include/asm/cache.h:25: multiple definition of 'dcache_invalid_range' include/asm/cache.h:25: first defined here This is due to the funcs being defined in the header, but not static or inline or extern. So move them to the sh4-specific cache.c file. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: Add ashrsi3 libgcc functionPhil Edworthy
The ashrsi3 function is used by some commands that aren't in SH2A default configs (e.g. JFFS2). The ashrsi3.S file has been copied from Linux. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: only add -mno-fdpic if the compiler supports itMike Frysinger
Not all SuperH toolchains support -mno-fdpic. Chances are good that if the flag doesn't work, it isn't defaulting to the FDPIC ABI, so the flag isn't needed. So only add it if it is actually supported. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-23sh: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-08-22sh: add calling mmc_initialize in board.cYoshihiro Shimoda
Some SH have MMC controller. So, if we need it, we have to call the mmc_initialize(). Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: sh2a: Add sh2a optimize to config.mkNobuhiro Iwamatsu
Only the optimization of sh2 had been supported up. This adds the optimization of sh2a. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add support for SH2A freestanding buildPhil Edworthy
SH2A toolchains often only provide an fdpic version of libgcc. This can't be used with bare-metal software like U-Boot, so this patch provides the necessary functions extracted from libgcc. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27Coding Style cleanup: remove trailing empty linesWolfgang Denk
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-03-16sh: Add KEEP order to start.o sectionNobuhiro Iwamatsu
The start.o section is changed by --gc-section option of ld. Of this using KEEP order, therefore, evade this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-16sh: Add handling of CONFIG_SYS_NO_FLASH for board.cNobuhiro Iwamatsu
Some board of SH does not have flash memoy. This revises it to initialize Flash when CONFIG_SYS_NO_FLASH is not defined. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: add support the CONFIG_SYS_LDSCRIPTYoshihiro Shimoda
2011-01-25Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGSNobuhiro Iwamatsu
Linker needs to use the proper endian/bfd flags even when doing partial linking. LDFLAGS_u-boot sets linker option which is called it when U-boot is built (u-boot final). LDFLAGS sets necessary option by partial linking (use in cmd_link_o_target). CC: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-19Replace "FLASH" strings with "Flash" or "flash"Peter Tyser
There's no compelling reason to have the output on bootup or the "flinfo" command print "flash" in uppercase, so use the proper case where appropriate. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2011-01-11sh: Add support zimageboot command for Renesas SHNobuhiro Iwamatsu
Curent U-Boot can boot zImage by use the "go" command. But this is not right method. And this method can not set command-line to linux kernel. zimageboot sets command-line in environment of u-boot in linux kernel, and provides function to boot it. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2011-01-11sh: Divided macro for zImage and add asm/zimage.hNobuhiro Iwamatsu
2011-01-11sh: Delete the function that was not necessaryNobuhiro Iwamatsu
2011-01-11sh: Remove SCIF/SCI register infomationNobuhiro Iwamatsu
The register information of SCIF/SCI was compiled by drivers/serial/serial_sh.h. Therefore, these are not necessary. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: Add support showing KByte of flash memory sizeNobuhiro Iwamatsu
2011-01-11sh: Add support SH7706Nobuhiro Iwamatsu
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-30sh: Fix build in start.SNobuhiro Iwamatsu
By commit 6d8962e814c15807dd6ac5757904be2a02d187b8, label of _start was not usable in start.S and build fail. This change label from _start to _sh_start. ---- arch/sh/cpu/sh4/libsh4.o: In function `_start': (.text+0x204): multiple definition of `_start' arch/sh/cpu/sh4/start.o:(.text+0x0): first defined here ---- Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-21sh: Fix warning about uninitialized value of ramdisk_flagsNobuhiro Iwamatsu
2010-10-21sh: Rename TEXT_BASE to CONFIG_SYS_TEXT_BASENobuhiro Iwamatsu
2010-10-21sh: Add support load and boot of Initrd.Nobuhiro Iwamatsu
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-28sh: Add trigger_address_error and support cpu resetNobuhiro Iwamatsu
This add support cpu reset by trigger_address_error function. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-06-28sh: Fix path of irqflags.hNobuhiro Iwamatsu
This changes path of irqflags.h from linux/ to asm/. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-06-28sh: Fix overflow problem in get_ticksNobuhiro Iwamatsu
2010-04-13sh: Move cpu/$CPU to arch/sh/cpu/$CPUPeter Tyser
