path: root/arch/sh/include/asm/cpu_sh7752.h
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
