path: root/arch/sh/cpu
2019-05-10sh: sh3: Remove CPU supportMarek Vasut
This CPU core is old, no boards using the CPU are left in mainline, it has no prospects of ever being converted to DM, drop it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Chris Brandt <chris.brandt@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
2019-05-10sh: sh2: Remove CPU supportMarek Vasut
2018-02-21sh: Use -m2a-nofpu onlyTom Rini
Based on reading over the GCC manual, passing both -m2a and -m2a-nofpu are redundant, as -m2a-nofpu will provide functional code for both. As -m2a-nofpu functions with more toolchains and does what is expected, switch. Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-27sh: Fix linking of ms7722seTom Rini
While it is true that we no longer have 'ppcenv' and similar sections, including env/embedded.o at all results in the text/etc sections being available for the rest of the link. This in turn is required for the setup used on ms7722se. This also, likely, needs further fine-tuning. Fixes: f40ad66fa066 ("arch/sh: don't bring common/env_embedded.o into the link") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-26arch/sh: don't bring common/env_embedded.o into the linkThomas Petazzoni
The linker script for SuperH brings the .ppcenv and .ppcenvr section of common/env_embedded.o into the .text section. However, the .ppcenv section is only ever filled in by env_embedded.o when CONFIG_SYS_USE_PPCENV is defined, but no platforms in mainline U-Boot use this. In addition, common/env_embedded.o is not always built (when you use CONFIG_ENV_IS_NOWHERE for example), which causes the following build failure: Fixes: LD u-boot /home/thomas/sh4aeb-linux-musl/bin/sh4aeb-linux-ld.bfd: cannot find common/env_embedded.o We fix this by no longer adding the .ppcenv and .ppcenvr sections from common/env_embedded.o into the .text section. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26arch/sh: allow building in big-endian modeThomas Petazzoni
The SuperH architecture allows to be run in either little or big endian mode. Some SuperH SoCs get the little vs. big endian decision through mode pins sampled at reset, so if big endian has been choosen by HW designers, it cannot be easily changed. Therefore, it makes sense to allow building U-Boot for SuperH in big endian mode. To allow this, the only change needed is to adjust the OUTPUT_FORMAT() in the linker script. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-02sh: generate position independent code for all platformsVladimir Zapolskiy
Finally add fpic compilation option to produce relocatable code. Note that this requires to define CONFIG_NEEDS_MANUAL_RELOC for all board files, also relocation support still has some limitations (e.g. a developer should care not to overwrite the executing code or memset() with zeroes not yet relocated data on malloc init etc.), which may be fixed while switching to PIE. Due to short investigation the architecture code is not ready for PIE linking, this will require some manipulations with .dyn* sections. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: share the correct version of start.S among all cpusVladimir Zapolskiy
It is easy to note that SH2/SH3/SH4 start.S code is practically the same with a minor difference for SH2 where a short data header is present. To avoid unwanted code duplication and to automatically convert SH2 and SH3 platforms to generic board support move fixed SH4 start.S into arch/sh/lib/start.S and share it among all platforms. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: fix start.S by calling board_init_f() after first code relocationVladimir Zapolskiy
Like on ARM platform keep the first code relocation from a U-boot image storage to RAM at CONFIG_SYS_TEXT_BASE, then pass execution to a generic board_init_f() with empty GD flags. If CONFIG_SYS_TEXT_BASE is equal to a calculated by board_init_f() relocation address there will be no more code and data copy, however it's worth to mention that the first copy happens even if $pc on _start is the same as CONFIG_SYS_TEXT_BASE, on practice this works without a problem. Also note that _sh_start is renamed back to _start to correct gd->mon_len calculation by setup_mon_len(), the opposite rename was done in pre-generic board commit 2024b968ee9 ("sh: Fix build in start.S"). Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: add shared relocate_code() function and call board_init_r()Vladimir Zapolskiy
Commits b61e90e6fd83 ("sh: Drop the arch-specific board init") and f41e6088eb1a ("sh: Fix build errors for generic board") left code and data relocation done in start.S, however further actual U-boot configuration is not started anymore. Practically SH boards with the code relocated into the expected position by start.S still can be booted, so the change adds this option and provides an option how to relocate code for board_init_r() execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: add MEMORY command to a shared linker scriptVladimir Zapolskiy
At the moment in runtime all defined sections are copied into or created in RAM, specify this explicitly to assert potential out of RAM placements of the sections. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: define entry point and reloc_dst inside a linker scriptVladimir Zapolskiy
No functional change, concentrate linker script commands in one place for convenience. Entry point is set to CONFIG_SYS_TEXT_BASE by default on build, so this option can be omitted from being added to the linker script. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: place board lowlevel_init code in the beginning of .textVladimir Zapolskiy
Reference lowlevel_init of all supported SH2A/SH3/SH4/SH4A boards from a shared linker script, the lowlevel_init function will be called by a relative address. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: use single u-boot linker script for all boardsVladimir Zapolskiy
Three supported SH4/SH4A boards with the bootloader image stored on SPI flash have own flavour of a linker script, in turn they are equal among each other. The only difference is that the text from lowlevel_init.o is placed right after start.o, which makes sense. Note that .bss section is not marked as NOLOAD, because for about 10 years this is a default option of a GNU linker, either the attribute is found or not the resulting image file is the same. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: move exported cache manipulation functions into cache.cVladimir Zapolskiy
No functional change, moving cache manipulation functions into cache.c allows to collect all of them in a single location and as a pleasant side effect cache_control() function can be unexported now. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh: cache: don't modify CCR from P1 areaVladimir Zapolskiy
cache_wback_all() is a local function and it is called from cache_control() only, which is in turn jumps to P2 area. The change fixes an issue when cache_wback_all() returns from P2 to P1, however cache_control() continues to manipulate with CCR register, according to the User's Manual this is restricted. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: cache use jump_to_P2() and back_to_P1() from asm/system.hVladimir Zapolskiy
Both jump_to_P2() and back_to_P1() functions are found in asm/system.h header file and functionally they are the same, don't redefine them. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh3: remove unused cache.c file from being builtVladimir Zapolskiy
The change is similar to commit 994b56616bae ("sh: delete an unused source file") for SH2, however here the removed cache.c file was built and included into an image as a dead code. If it is needed in future the contents can be reused from a similar arch/sh/cpu/sh4/cache.c file, which is in turn will be moved to a shared among all core flavours location at arch/sh/lib/cache.c. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: correct flush_cache() to writeback and invalidateVladimir Zapolskiy
In common usecases flush_cache() assumes both cache invalidation and write-back to memory, instead of doing cache invalidation only with the wrapped 'ocbi' instruction pin flush_cache() to cache invalidation with memory write-back done by 'ocbp'. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-02sh4: cache: correct dcache flush to invalidate with write-backVladimir Zapolskiy
In common usecases flush_cache() assumes both cache invalidation and write-back to memory, thus in flush_dcache_range() implementation change SH4 cache write-back only instruction 'ocbwb' with cache purge instruction 'ocbp', according to the User's Manual there should be no performance penalty for that. Note that under circumstances only cache invalidation is expected from flush_cache() call, in these occasional cases the current version of flush_cache() works, which is a wrapper over invalidate_dcache_range() at the moment, this will be fixed in the following change. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-05-27sh: Fix build errors for generic boardSimon Glass
This includes the following fixes: - Define needed __init_end symbol - see initr_reloc_global_data() - Drop SH-specific struct bd_info - Add an empty relocate_code() function This prevents build errors with generic board, but the code will still need work. Perhaps this is a better alternative than deleting the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2014-11-13sh: move CONFIG_{SH2, SH2A, SH3, SH4} to KconfigMasahiro Yamada
This commit moves CONFIG_SH2, CONFIG_SH2A, CONFIG_SH3, CONFIG_SH4 to Kconfig renaming into CONFIG_CPU_SH2, CONFIG_CPU_SH2A, CONFIG_CPU_SH3, CONFIG_CPU_SH4, respectively because arch/sh/Kconfig of Linux uses CONFIG_CPU_SH* convention. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-07-24sh: unify sh2/sh3/sh4 linker scriptsMasahiro Yamada
The linker scripts of sh2/sh3/sh4 are almost the same. The difference among them is essentially only one line. They can be consolidated into a single file, arch/sh/cpu/u-boot.lds by re-writing the diffrent line as follows: KEEP(*/start.o (.text)) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-30sh: delete an unused source fileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-04sh: merge compiler flag -ffixed-r13Masahiro Yamada
-ffixed-r13 is defined commonly for sh2, sh3, sh4. Move it to arch/sh/config.mk Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-03-04sh: Do not define -ffreestanding twiceMasahiro Yamada
-ffreestanding is defined at the top Makefile for all architectures. Do not define it twice for SH2A. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-09sh: sh4: Remove CONFIG_SH4A definition from source codeNobuhiro Iwamatsu
SH4 and SH4A are compatible. But some instructions are different from these. In Linux kernel, It is treated as a separate CPU, but for now, I think that there is no need to divide especially in the U-Boot. This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4. And this fix white space. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh4: Add CONFIG_SH4 definition to config.mk of SH4Nobuhiro Iwamatsu
2014-01-08sh: sh3: Add CONFIG_SH3 definition to config.mk of SH3Nobuhiro Iwamatsu
2014-01-08sh: sh2: Add CONFIG_SH2 definition to config.mk of SH2Nobuhiro Iwamatsu
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-31sh: Do not include start.o in lib$(CPU).oMasahiro Yamada
2013-10-17sh: cache: Change cache API to defines as U-BootNobuhiro Iwamatsu
A chache API of SH is developped by reference in linux kernel. And API was the same as the linux kernel. This patch change cache API to defines as U-Boot. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-08-08sh: modify checkcpu() for SH-4AYoshihiro Shimoda
Even if using CPU is SH-4A, the previous code always put "SH4". This patch fixes it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: avoid multiple definition errors with cache funcsMike Frysinger
Recent builds for SH4 boards fail with a lot of errors like: cmd_mem.o: In function 'dcache_invalid_range': include/asm/cache.h:25: multiple definition of 'dcache_invalid_range' include/asm/cache.h:25: first defined here This is due to the funcs being defined in the header, but not static or inline or extern. So move them to the sh4-specific cache.c file. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh: only add -mno-fdpic if the compiler supports itMike Frysinger
Not all SuperH toolchains support -mno-fdpic. Chances are good that if the flag doesn't work, it isn't defaulting to the FDPIC ABI, so the flag isn't needed. So only add it if it is actually supported. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: sh2a: Add sh2a optimize to config.mkNobuhiro Iwamatsu
Only the optimization of sh2 had been supported up. This adds the optimization of sh2a. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-16sh: Add KEEP order to start.o sectionNobuhiro Iwamatsu
The start.o section is changed by --gc-section option of ld. Of this using KEEP order, therefore, evade this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
