path: root/arch/sh/cpu/sh2/start.S
2010-11-30sh: Fix build in start.SNobuhiro Iwamatsu
By commit 6d8962e814c15807dd6ac5757904be2a02d187b8, label of _start was not usable in start.S and build fail. This change label from _start to _sh_start. ---- arch/sh/cpu/sh4/libsh4.o: In function `_start': (.text+0x204): multiple definition of `_start' arch/sh/cpu/sh4/start.o:(.text+0x0): first defined here ---- Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-04-13sh: Move cpu/$CPU to arch/sh/cpu/$CPUPeter Tyser
