path: root/arch/sh/config.mk
2018-11-18Kbuild: add LDFLAGS_STANDALONEDaniel Schwierzeck
Introduce a new Makefile variable for passing LDFLAGS to standalone programs. Currently the variable CONFIG_STANDALONE_LOAD_ADDR is misued on some archs to pass a specific linker script. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2016-12-02sh: generate position independent code for all platformsVladimir Zapolskiy
Finally add fpic compilation option to produce relocatable code. Note that this requires to define CONFIG_NEEDS_MANUAL_RELOC for all board files, also relocation support still has some limitations (e.g. a developer should care not to overwrite the executing code or memset() with zeroes not yet relocated data on malloc init etc.), which may be fixed while switching to PIE. Due to short investigation the architecture code is not ready for PIE linking, this will require some manipulations with .dyn* sections. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2016-12-02sh: define entry point and reloc_dst inside a linker scriptVladimir Zapolskiy
No functional change, concentrate linker script commands in one place for convenience. Entry point is set to CONFIG_SYS_TEXT_BASE by default on build, so this option can be omitted from being added to the linker script. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04sh: merge compiler flag -ffixed-r13Masahiro Yamada
-ffixed-r13 is defined commonly for sh2, sh3, sh4. Move it to arch/sh/config.mk Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27Coding Style cleanup: remove trailing empty linesWolfgang Denk
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-02-02sh: add support the CONFIG_SYS_LDSCRIPTYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-25Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGSNobuhiro Iwamatsu
Linker needs to use the proper endian/bfd flags even when doing partial linking. LDFLAGS_u-boot sets linker option which is called it when U-boot is built (u-boot final). LDFLAGS sets necessary option by partial linking (use in cmd_link_o_target). CC: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-10-21sh: Rename TEXT_BASE to CONFIG_SYS_TEXT_BASENobuhiro Iwamatsu
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
