path: root/arch/sandbox
2013-10-31sandbox: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26sandbox: Support trace featureSimon Glass
Support tracing on sandbox by adding suitable CONFIG options. To enable it, compile U-Boot with FTRACE=1. The timer functions are marked to skip tracing, since these are called from the tracing code itself, and we want to avoid an infinite loop. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01sandbox: Allow -c argument to provide a command listSimon Glass
This allows passing of entire scripts to sandbox with the -c argument, which is useful for testing. Commands can be delimited with a newline or semicolon. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01sandbox: Add CONFIG_OF_HOSTFILE to read FDT from host fileSimon Glass
With sandbox it is tricky to add an FDT to the image at build time (or later) since we build an ELF file, not a plain binary, and the address space of the whole U-Boot is not accessible in the emulated memory map of sandbox. Sandbox can read files directly from the host, though, so add an option to read an FDT from a host file on start-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01sandbox: Switch over to generic boardSimon Glass
Add generic board support for sandbox. and remove the old board init code. Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-01sandbox: Provide a way to map from host RAM to U-Boot RAMSimon Glass
In many cases, pointers to memory are passed around, and these pointers refer to U-Boot memory, not host memory. This in itself is not a problem. However, in a few places, we cast that pointer back to a ulong (being a U-Boot memory address). It is possible to convert many of these cases to avoid this. However there are data structures (e.g. struct bootm_headers) which use pointers. We could with a lot of effort adjust the structs and all code that uses them to use ulong instead of pointers. This seems like an unacceptable cost, since our objective with sandbox is to minimise the impact on U-Boot code while maximising the features available to sandbox. Therefore, create a map_to_sysmem() function which converts from a pointer to a U-Boot address. This can be used sparingly when needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-04sandbox: Add a way of obtaining directory listingsSimon Glass
This implementation uses opendir()/readdir() to access the directory information and then puts it in a linked list for the caller's use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28sandbox: Add un/map_sysmen() to deal with sandbox's ram_bufSimon Glass
Sandbox doesn't actually provide U-Boot access to the machine's physical memory. Instead it provides a RAM buffer of configurable size, and all memory accesses are within that buffer. Sandbox memory starts at 0 and is CONFIG_DRAM_SIZE bytes in size. Allowing access outside this buffer might produce unpredictable results in the event of an error, and would expose the host machine's memory architecture to the sandbox U-Boot. Most U-Boot functions assume that they can just access memory at given address. For sandbox this is not true. Add a map_sysmem() call which converts a U-Boot address to a system address. In most cases this is a NOP, but for sandbox it returns a pointer to that memory inside the RAM buffer. To get a U-Boot feature to work correctly within sandbox, you should call map_sysmem() to get a pointer to the address, and then use that address for any U-Boot memory accesses. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: Improve sandbox serial port keyboard interfaceTaylor Hutt
Implements the tstc() interface for the serial driver. Multiplexing the console between the serial port and a keyboard uses a polling method of checking if characters are available; this means that the serial console must be non-blocking when attempting to read characters. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: fix compiler warningAllen Martin
Add back return statement to fix compiler warning about control flow reaching end of non void function that was introduced with: e05e5de arm: move C runtime setup code in crt0.S Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-02-04sandbox: Use generic global_dataSimon Glass
Move sandbox over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04sandbox: Move ram_buf to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19sandbox: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-09-29sandbox: Add asm/errno.hSimon Glass
This file is required for all archs. Fixes a sandbox build break on ext4. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-23sandbox: Use the new run_command()Simon Glass
Now that run_command() handles both parsers, clean up sandbox to use it. This fixes a build error. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add getopt supportSimon Glass
This adds simple command-line parsing to sandbox. The idea is that it sets up the state with options provided, and this state can then be queried later, as needed. New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro, pointers are automatically gathered up in a special section, and then the core code takes care of gathering them up and processing at runtime. This way there is no central place where we have to store a list of flags with ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: allow processing before main loopSimon Glass
In order to pass command line arguments to sandbox we need to be able to act on them. So take control back at the end of board_init_r() from where we can call the main loop or do something else. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add concept of sandbox stateSimon Glass
The state exists through the life of U-Boot. It can be adjusted by command line options and perhaps later through a config file. It is available to U-Boot through state_...() calls (within sandbox code). The primary purpose of this is to contain the "hardware" state. It should only be used by sandbox internal code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: disable fortificationMike Frysinger
Since we provide all our own library calls, the fortification from glibc just gets in our way (which some distros enable by default). Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: u-boot.lds: tweak styleMike Frysinger
We use tabs for indentation, not spaces. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: gpio: add basic driver for simulating GPIOsSimon Glass
This provides a way of simulating GPIOs by setting values which are seen by the normal gpio_get/set_value() calls. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add flags for open() callSimon Glass
This provides a way for callers to create files for writing. The flags are translated at runtime, for the ones we support. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: fdt: add support for CONFIG_OF_CONTROLSimon Glass
This adds support for a controlling fdt, mirroring the ARM implementation. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add lseek helperMike Frysinger
Follow up patches want to be able to seek fd's. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add required header to os.cSimon Glass
We should include the sys/time.h header to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: sort header files in os.cSimon Glass
Tidy this up as the list is long and likely to get longer. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: fix compiling of cpu/os.cAndreas Bießmann
U-boot itself generally builds with -nostdinc. This is because the bootloader needs to be completely standalone. In the sandbox arch though, we need a little bit of code to glue the u-boot world to the host operating system, and we need to be able to access the host libc's headers in order to do so. Currently, we're using -I/usr/include to workaround the global -nostdinc, but that doesn't work for everyone and for all headers. Instead, let's filter out -nostdinc when building the os.c code. Without this patch, some distros hit errors such as: ---8<--- In file included from /usr/include/fcntl.h:27:0, from os.c:22: /usr/include/features.h:323:26: fatal error: bits/predefs.h: No such file or directory --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add timer simulationMatthias Weisser
Making sleep command work Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03sandbox: drop unused returnMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org>
2011-11-03sandbox: put stdin into raw modeMike Frysinger
This allows us to act like a serial device: we get tab chars and CTRL+C and respond appropriately. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-03sandbox: Add asm/cache.h for sandboxAnton staaf
This file is required by the new DMA buffer alignment macro. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-17sandbox: Add main programSimon Glass
Add a main program so that we can run U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add OS dependent layerSimon Glass
We want to keep all OS-dependent code in once place, with a simple interface to U-Boot. For now, this is that place. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add architecture lib filesSimon Glass
These files are taken from the ARM board implementation and then reduced to remove unneeded cruft. Ideally we would work towards unifying arch/xxx/lib files, particularly board.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add cpu filesSimon Glass
This is an initial implementation with all functions defined but not working. The lds file is very simple since we can mostly rely on the linker defaults. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add architecture image supportSimon Glass
We won't actually load an image with this architecture, but we still need to define it. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add architecture header filesSimon Glass
This adds required header files for the sandbox architecture, and a basic description of what sandbox is (README.sandbox). Signed-off-by: Simon Glass <sjg@chromium.org>
