Now that we have a C version of this test, drop the Python implementation.
Now that we have more than one test, add a way to select the test to run.
Add a -u flag for U-Boot SPL which requests that unit tests be run. To
make this work, export dm_test_main() and update it to skip test features
that are not used with of-platdata.
To run the tests:
$ spl/u-boot-spl -u
U-Boot SPL 2020.10-rc5 (Oct 01 2020 - 07:35:39 -0600)
Running 0 driver model tests
Failures: 0
At present there are no SPL unit tests.
Note that there is one wrinkle with these tests. SPL has limited memory
available for allocation. Also malloc_simple does not free memory
(free() is a nop) and running tests repeatedly causes driver-model to
reinit multiple times and allocate memory. Therefore it is not possible
to run more than a few tests at a time. One solution is to increase the
amount of malloc space in sandbox_spl. This is not a problem for pytest,
since it runs each test individually, so for now this is left as is.
Up to now the RAM size of the sandbox is hard coded as 128 MiB. This does
not allow testing the correct handling of addresses outside the 32bit
range. 128 MiB is also rather small when tracing functions where the trace
is written to RAM.
Provide configuration variable CONFIG_SANDBOX_RAM_SIZE_MB to set the RAM
size in MiB. It defaults to 128 MiB with a minimum of 64 MiB.
On high-DPI displays U-Boot's LCD window can look very small. Add a
-K flag to expand it to make things easier to read, while still using
the existing resolution internally.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
At present these functions are stubbed out. For more comprehensive testing
with PCI devices it is useful to be able to fully emulate I/O access. Add
simple implementations for these.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
[bmeng: change to use 'const void *' in sandbox_write();
cast 'addr' in read/write macros in arch/sandbox/include/asm/io.h;
remove the unnecessary cast in readq/writeq in nvme.h]
This struct is getting larger and in some cases is being used for things
which would be better put into a driver. For example hwspinlock is not
used outside of sandbox_hwspinlock.c.
Add a note to encourage people to put things elsewhere.
This is uclass for Hardware Spinlocks.
It implements two mandatory operations: lock and unlock
and one optional relax operation.
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
At present the RAM buffer is not inited unless it is read from a file,
likely produced by an earlier phase of U-Boot. This causes valgrind
warnings whenever the RAM buffer is used. Correct this by initing it if
needed.
The old 'sb' command was deprecated in 2015 and replaced with 'host'. It
is useful to be able to access some internal sandbox state, particularly
for testing.
Resurrect the old command and provide a way to print some basic state
information (currently just the arguments to sandbox).
At present we don't have a test that of-platdata can be accessed in SPL.
Add this in as a command-line option to SPL.
Now that we don't have to deal with the command-line flag we can simplify
the code for detecting the emulator. Remove the lookup based on the SPI
specification, relying just on the device tree to locate the emulator.
It is useful to be able to set the default log level from the command line
when running sandbox. Add a new -L command-line flag for this. The log
level is set using the enum log_level_t in log.h. At present a number must
be specified, e.g. -L7 for debug.
At present map_sysmem() maps an address into the sandbox RAM buffer,
return a pointer, while map_to_sysmem() goes the other way.
The mapping is currently just 1:1 since a case was not found where a more
flexible mapping was needed. PCI does have a separate and more complex
mapping, but uses its own mechanism.
However this arrange cannot handle one important case, which is where a
test declares a stack variable and passes a pointer to it into a U-Boot
function which uses map_to_sysmem() to turn it into a address. Since the
pointer is not inside emulated DRAM, this will fail.
Add a mapping feature which can handle any such pointer, mapping it to a
simple tag value which can be passed around in U-Boot as an address.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Running a new test should reset the sandbox state to avoid tests
interferring with each other. Move the existing state-reset code into a
function so it can be used from tests.
Also update the code to reset the SPI devices and adjust the test code to
call it.
This is a simple uclass for Watchdog Timers. It has four operations:
start, restart, reset, stop. Drivers must implement start, restart and
stop operations, while implementing reset is optional: It's default
implementation expires watchdog timer in one clock tick.
Signed-off-by: Maxim Sloyko <maxims@google.com>
The current reset API implements a method to reset the entire system.
In the near future, I'd like to introduce code that implements the device
tree reset bindings; i.e. the equivalent of the Linux kernel's reset API.
This controls resets to individual HW blocks or external chips with reset
signals. It doesn't make sense to merge the two APIs into one since they
have different semantic purposes. Resolve the naming conflict by renaming
the existing reset API to sysreset instead, so the new reset API can be
called just reset.
When running sandbox tests, silence the console to avoid unwanted output.
Also, record the console in case tests want to check it.
The -v option can be used to enable stdout during tests.
Some tests are slow due to delays which are unnecessary on sandbox. The
worst offender is USB where we lose two seconds. Add a way to disable time
delays.
Add settings for the last reset generated, and the types of resets which
are permitted. This will be used for testing.
For the distro_bootcmds to succeed on the sandbox a bit of setup is
required (e.g. network configured or host image bound), so running them
by default isn't that useful.
Add a -b/--boot command to the sandbox binary, which triggers the
distro_bootcmds to run after the other command-line commands.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
When a command is passed into sandbox using the '-c' argument the
command is run directly. This is most helpful when running tests (such
as test-dm.sh). Previously the exit code was an unused enum. Change it
to be the actual return code from the command so that the script calling
sandbox can know if the command succeeded (tests passed). Also remove
the now completely unused "exit_state" in sandbox.
Convert sandbox's spi flash emulation driver to use driver model.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Adjust the sandbox SPI driver to support driver model and move sandbox over
to driver model for SPI.
When jumping from one sandbox U-Boot to another in sandbox, the RAM buffer
is preserved in the jump by using a temporary file. Add an option to tell
the receiving U-Boot to remove this file when it is no longer needed.
Similarly the old U-Boot image is left behind in this case. We cannot delete
it immediately since gdb cannot then find its debug symbols. Delete it just
before exiting.
Together these changes ensure that temporary files are removed both for
memory and U-Boot.
It is useful for Cltl-C to be handled by U-Boot as it is on other boards.
But it is also useful to be able to terminate U-Boot with Ctrl-C.
Add an option to enable signals while in raw mode, and make this the
default. Add an option to leave the terminal cooked, which is useful for
redirecting output.
Add a simple LCD driver which uses SDL to display the image. We update the
image regularly, while still providing for reasonable performance.
Adjust the common lcd code to support sandbox.
For command-line runs we do not want the LCD to be displayed, so add a
--show_lcd option to enable it.
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
In order to support the 'go' command we allow the jumping U-Boot to pass its
filename to the new U-Boot image. This can then be used to delete that image
if required.
It is often useful to be able to save out the state from a sandbox test
run, for analysis or to restore it later to continue a test. Add generic
infrastructure for doing this using a device tree binary file. This is
a flexible tagged file format which is already supported by U-Boot, and
it supports hierarchy if needed.
Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
It is useful to be able to save and restore the RAM contents of sandbox
U-Boot either for setting up tests, for later analysys, or for chaining
together multiple tests which need to keep the same memory contents.
Add a function to provide a memory file for U-Boot. This is read on
start-up and written when shutting down. If the file does not exist
on start-up, it will be created when shutting down.
Normally when U-Boot starts with a command (-c option) it quits when the
command completes. Normally this is what is requires, since the test is
likely complete.
Provide an option to jump into the console instead, so that debugging or
other tasks may be performed before quitting.
This adds a SPI framework for people to hook up simulated SPI clients.
[trini: Fixup common/cmd_io.c]
With sandbox it is tricky to add an FDT to the image at build time (or
later) since we build an ELF file, not a plain binary, and the address
space of the whole U-Boot is not accessible in the emulated memory map
of sandbox.
Sandbox can read files directly from the host, though, so add an option
to read an FDT from a host file on start-up.
This adds simple command-line parsing to sandbox. The idea is that it
sets up the state with options provided, and this state can then be
queried later, as needed.
New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro,
pointers are automatically gathered up in a special section, and
then the core code takes care of gathering them up and processing
at runtime. This way there is no central place where we have to
store a list of flags with ifdefs.
The state exists through the life of U-Boot. It can be adjusted by command
line options and perhaps later through a config file. It is available to
U-Boot through state_...() calls (within sandbox code).
The primary purpose of this is to contain the "hardware" state. It should
only be used by sandbox internal code.
