path: root/arch/riscv/include/asm/u-boot-riscv.h
2018-05-29riscv: Add board_quiesce_devices stubAlexander Graf
This patch adds an empty stub for board_quiesce_devices() which allows boards to quiesce their devices before we boot into an OS in a platform agnostic way. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-12riscv: nx25: include: Add header files to support RISC-VRick Chen
Add header files for RISC-V. Cache, ptregs, data type and other definitions are included. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
