By utilizing the newly introduced BINMAN_STANDALONE_FDT option, along
with a new dedicated device tree source file for the QEMU virt target
used for binman only, we can now use binman to generate u-boot.itb.
Sort the RISC-V DTS build targets by their Kconfig target names in
alphabetical order.
At present SiFive Unleashed board uses the Makefile to create the FIT,
using USE_SPL_FIT_GENERATOR, which is deprecated as per the Makefile
warning. Update to use binman instead.
It is no longer necessary to disallow ai ram, since it is enabled by the
sram driver.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Testing showed that disabling AI while leaving PLL1 enabled disabled the
aisram. This suggests that AI is a more appropriate clock for that ram
bank.
This is more consistent with the naming of other ram banks, and matches
what Linux is doing.
Reported-by: Damien Le Moal <Damien.LeMoal@wdc.com>
These devices are necessary for the clock driver, which is required by the
sram driver, to run pre-relocation.
The uart nodes already provide <clocks> property for the driver to
dynamically calculate the correct clock frequency. There is no need
to keep the hard-coded <clock-frequency> property.
Reviewed-by: Padmarao Begari <padmarao.begari@microchip.com>
Tested-by: Padmarao Begari <padmarao.begari@microchip.com>
In preparation to add SiFive Unmatched board support, let's rename
the existing fu540 board to unleashed.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
This adds the necessary bindings. Most of them are already there.
Acked-by: Rick Chen <rick@andestech.com>
This device has four IOs connected to the SPI flash. Add the appropriate
bindings.
Reviewed-by: Leo Liang <ycliang@andestech.com>
Add device tree for Microchip PolarFire SoC Icicle Kit.
Signed-off-by: Padmarao Begari <padmarao.begari@microchip.com>
Reviewed-by: Anup Patel <anup.patel@wdc.com>
Reviewed-by: Bin Meng <bin.meng@windriver.com>
This patch adds bindings for the MMC slot and SPI flash on the Sipeed Maix
Bit.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
This adds SoC-specific compatible strings to all users of the designware
spi device. This will allow for the correct driver to be selected for each
device. Where it is publicly documented, a compatible string for the
specific device version has also been added. Devices without
publicly-documented device versions include MSCC SoCs, and Arc Socs. All
compatible strings except those for SoCFPGAs and some of the versioned
strings have been taken from Linux.
Since SSI_MAX_XFER_SIZE is determined at runtime, this is not strictly
necessary. However, it is a good cleanup and brings things closer to Linux.
Tested-by Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Although the max DMA size supported by the hardware register is 22 bits (or
4M), the Linux driver for this device only supports transfers of up to 2M.
On a device with 8M total memory, I don't think it will make too much of a
difference.
Add a device tree binding for the BOOT button on the Maix board.
Reviewed-by: Sean Anderson <seanga2@gmail.com>
This patch adds the necessary device tree bindings.
We currently do this in a u-boot specific dts, but hopefully we can get
these bindings added in Linux in the future.
Reviewed-by: Pragnesh Patel <pragnesh.patel@openfive.com>
The interrupt controller property is removed from the clint binding because
the clint is not an interrupt-controller. That is, no other devices have an
interrupt which is controlled by the clint.
The resets to DDR and ethernet sub-system are connected to
PRCI device reset control register, these reset signals
are active low and are held low at power-up. Add these reset
producer and consumer details needed by the reset driver.
Signed-off-by: Sagar Shrikant Kadam <sagar.kadam@sifive.com>
Reviewed-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Make memory node available to SPL in prepration to updates to SiFive
DDR RAM driver to read memory information from DT.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
Add booting from SPI for SiFive Unleashed board.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Bin Meng <bin.meng@windriver.com>
Merge all outstanding changes from the current next branch in now that
we have released.
Add L2 cache node to enable all cache ways from U-Boot proper.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Add cpu aliases to U-Boot specific dtsi for hifive-unleashed.
Without aliases we see that the CPU device sequence numbers are set
randomly and the cpu list/detail command will show it as follows:
=> cpu list
1: cpu@1 rv64imafdc
2: cpu@2 rv64imafdc
3: cpu@3 rv64imafdc
0: cpu@4 rv64imafdc
Seems like CPU probing with dm-model also relies on aliases as observed
in case spi. The fu540-c000-u-boot.dtsi has cpu nodes and so adding
corresponding aliases we can ensure that cpu devices are assigned
proper sequence as follows:
=> cpu list
1: cpu@1 rv64imafdc
2: cpu@2 rv64imafdc
3: cpu@3 rv64imafdc
4: cpu@4 rv64imafdc
Where possible, I have tried to find compatible drivers based on the layout
of registers. However, many devices remain untested. All untested devices
have been left disabled, but some tentative properties (such as compatible
strings, and clocks, interrupts, and resets properties) have been added.
Add a support for SPL which will boot from L2 LIM (0x0800_0000) and
then SPL will boot U-Boot FIT image (OpenSBI FW_DYNAMIC + u-boot.bin)
from MMC boot devices.
SPL related code is leveraged from FSBL
(https://github.com/sifive/freedom-u540-c000-bootloader.git)
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
This sync has changes required to use GPIO in U-Boot and
U-Boot SPL.
Sync dts from linux v5.7-rc2 commit:
"riscv: dts: Add GPIO reboot method to HiFive Unleashed DTS file"
(sha1: 0a91330b2af9f71ceeeed483f92774182b58f6d9)
Set ethernet clock rate to 125 Mhz so that it will work with 1000Mbps,
Earlier this is done by FSBL. With this change We can remove the
ethernet clock rate code from FSBL.
Add dmc node to enable ddr driver. dmc is used to
initialize the memory controller.
Add DDR controller and phy register settings, taken from fsbl
Devicetree files in FU540 platform is synced from Linux, like other
platforms does. Apart from these U-Boot in FU540 would also require
some U-Boot specific node like clint.
So, create board specific -u-boot.dtsi files. This would help of
maintain U-Boot specific changes separately without touching Linux
dts(i) files which indeed easy for syncing from Linux between
releases.
Use the OTP DM driver to set the serial environment variable.
HiFive Unleashed A00 support is25wp256 spi-nor flash,
So enable the same and add test result log for future
reference.
Tested on SiFive FU540 board.
Thanks to Sagar for various use cases and tests.
[QUAD mode in dt with spi-tx-bus-width: <4>]
pp opcode = 0x34 [QUAD MODE]
read opcode = 0x6c [QUAD MODE]
erase opcode = 0x21
SPI-NOR:
1. erase entire flash: Pass
2. write entire flash: Pass
3. read entire flash: Pass
4. cmp 32MiB read back data: Pass
5. MMC: Booted Linux and dtb from mmc
[SPI MODE in dt with spi-tx-bus-width: <1>]
pp opcode = 0x12 [SPI MODE]
read opcode = 0xc [SPI MODE]
erase opcode = 0x21
SPI-NOR:
Tested-by: Sagar Kadam <sagar.kadam@sifive.com>
Add U-Boot specific dts file for hifive-unleashed-a00, this
would help to add u-boot specific properties and other node
changes without touching the base dts(i) files which are easy
to sync from Linux.
Added spi2 alias for qspi2 as an initial u-boot specific
property change.
spi probing in current dm model is very much rely on aliases
numbering. Even though the qspi2 can't come under any associated
spi nor flash it would require to specify the same to make proper
binding happen for other spi slaves.
Those are required for cfi-flash driver to get correct address information.
Also modify size description correctly.
Signed-off-by: Rick Chen <rick@andestech.com>
Cc: KC Lin <kclin@andestech.com>
Cc: Alan Kao <alankao@andestech.com>
Add CPU2 and CPU3 information in cpus node
to support four cores SMP booting.
Sync the hifive-unleashed-a00 dts from Linux with
below commit details:
commit <2993c9b04e616df0848b655d7202a707a70fc876> ("riscv: dts: HiFive
Unleashed: add default chosen/stdout-path")
Idea is to periodically sync the dts from Linux instead of
tweaking internal changes one after another, so better not
add any intermediate changes in between. This would help to
maintain the dts files easy and meaningful since we are
reusing device tree files from Linux.
When L2 node exists inside cpus node, uclass_get_device
can not parse L2 node successfully. So move it outside
from cpus node.
Also add tag-ram-ctl and data-ram-ctl attributes for
v5l2 cache controller driver. This can adjust timing
by requirement from dtb to improve performance.
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot
dts files. This compatible has been added in sf_probe, let use it.
This patch switches to jedec,spi-nor when spi-flash is used in the DTS
and DTSI files, and removed spi-flash when jedec,spi-nor is already
present.
The x86 dts are switched in a separate commit since it depends on a change
in fdtdec.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com>
Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
It occurs since commit 27cb7300ffda
("Ensure device tree DTS is compiled").
More details can refer to
89c2b5c02049aea746b1edee0b4e1d8519dec2f4
ARM: fix arch/arm/dts/Makefile
Cc: Greentime Hu <greentime@andestech.com>
Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
This is not used by any board. Remove it.
Reviewed-by: Anup Patel <anup@brainfault.org>
Add ae350_32.dts for 32 bit. And also rename
ae350.dts to ae350_64.dts for 64 bit.
Use same dts to boot U-Boot and Kernel.
Following are the change notes :
1 Remove early printk bootargs.
2 Timer frequency are changed to 60MHz.
3 Add dma, snd, lcd, virtio nodes which are used
in kernel drivers. They does not been used by U-Boot.
4 Change spi irq from 3 to 4.
There are quite a lot of mixed tabs and spaces in the ae350.dts.
Clean them up.
Add nor node for cfi-flash driver and smc node
for smc(aftsmc020) controller.
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Cc: Greentime Hu <green.hu@gmail.com>
