path: root/arch/powerpc
2013-07-16powerpc/mpc85xx:Disable Debug TLB entry for non-minimal SPLPrabhakar Kushwaha
CONFIG_SPL_BUILD creates debug TLB entry, so disable it before init_tlbs. CONFIG_SPL_INIT_MINIMAL never creates any debug TLB entry, so no need of disable_tlb(). Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-28Fix bootm to work on powerpc again (compressed uImage)Stefan Roese
Patch 35fc84fa1 [Refactor the bootm command to reduce code duplication] breaks booting Linux (compressed uImage with fdt) on powerpc. boot_jump_linux() mustn't be called before boot_prep_linux() and boot_body_linux() have been called. So remove the superfluous call to boot_jump_linux() in arch/powerpc/lib/bootm.c as its called later on in this function. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2013-06-20powerpc/85xx: Add P1023RDB board supportChunhe Lan
P1023RDB Specification: ----------------------- Memory subsystem: 512MB DDR3 (Fixed DDR on board) 64MB NOR flash 128MB NAND flash Ethernet: eTSEC1: Connected to Atheros AR8035 GETH PHY eTSEC2: Connected to Atheros AR8035 GETH PHY PCIe: Three mini-PCIe slots USB: Two USB2.0 Type A ports I2C: AT24C08 8K Board EEPROM (8 bit address) Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:Disable Debug TLB entry before init_tlbsPrabhakar Kushwaha
init_tlbs() initialize all the TLB entries required for the system. So disable DEBUG TLB entry before TLB entries initialization. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc: mpc85xx/mpc86xx: Fix off-by-one boundary checking with ARRAY_SIZEAxel Lin
If a variable is used as array subscript, it's valid value range is 0 ... ARRAY_SIZE -1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: modify the functionality clear_bss and aligning the end ↵Ying Zhang
address of the BSS There will clear the BSS in the function clear_bss(), the reset address of the BSS started from the __bss_start, and increased by four-byte increments, finally stoped depending on the address is equal to the _bss_end. If the end address __bss_end is not alignment to 4byte, it will be an infinite loop. 1. The reset action stoped depending on the reset address is greater than or equal the end address of the BSS. 2. The end address of the BSS should be 4byte aligned. Because the reset unit is 4 Bytes. This patch is on top of the patch "powerpc/mpc85xx: support application without resetvec segment in the linker script". Signed-off-by: Ying Zhang <b40530@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: support application without resetvec segment in the linker ↵Ying Zhang
script For SD/SPI 2-stage bootloader, the On-Chip Rom code loads the SPL into L2 SRAM, then jump to it to begin execution. After that, the SPL loads the final uboot image into DDR, then jump to it to begin execution. The segment .resetvec in the SPL and in final U-boot is useless. So, add new symbols CONFIG_SYS_MPC85XX_NO_RESETVEC for this application. If CONFIG_SYS_MPC85XX_NO_RESETVEC is set, the segment .resetvec is excluded and the segment .bootpg is placed in the previous 4K of the segment .text. Signed-off-by: Ying Zhang <b40530@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: work around erratum A-006593Scott Wood
Erratum A-006593 is "Atomic store may report failure but still allow the store data to be visible". The workaround is: "Set CoreNet Platform Cache register CPCHDBCR0 bit 21 to 1'b1. This may have a small impact on synthetic write bandwidth benchmarks but should have a negligible impact on real code." Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20fsl_ifc: add support for different IFC bank countMingkai Hu
Calculate reserved fields according to IFC bank count 1. Move csor_ext register behind csor register and fix res offset 2. Move ifc bank count to config_mpc85xx.h to support 8 bank count 3. Guard fsl_ifc.h with CONFIG_FSL_IFC macro to eliminate the compile error on some devices that does not have IFC controller. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/t4qds: Slave module for boot from SRIO and PCIELiu Gang
When a T4 board boots from SRIO or PCIE, it needs to finish these processes: 1. Set all the cores in holdoff status. 2. Set the boot location to one PCIE or SRIO interface by RCW. 3. Set a specific TLB entry for the boot process. 4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 5. Set a specific TLB entry in order to fetch ucode and ENV from master. 6. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 7. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations. For more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/b4860qds: Slave module for boot from SRIO and PCIELiu Gang
When a b4860qds board boots from SRIO or PCIE, it needs to finish these processes: 1. Set all the cores in holdoff status. 2. Set the boot location to one PCIE or SRIO interface by RCW. 3. Set a specific TLB entry for the boot process. 4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 5. Set a specific TLB entry in order to fetch ucode and ENV from master. 6. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 7. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations. For more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/boot: Change the macro of Boot from SRIO and PCIE master moduleLiu Gang
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h. Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-2085xx: Change case of MPC85XX_PORBMSR_ROMLOC_SHIFTAndy Fleming
All the other constants use lowercase 'x' in "MPC85xx", so we duplicate that here. Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc: Use lower case for the core namesFabio Estevam
Freescale documentation presents the PowerPC core names in lower case, such as "e300", "e500", "e600", etc. Change the upper case occurrences into lower case so that the core names reported in U-boot can match the ones from the documentation. While at it also fix a checkpatch error: ERROR: space prohibited before that close parenthesis ')' #53: FILE: arch/powerpc/cpu/mpc86xx/cpu.c:81: + printf("e600 Core %d", (msscr0 & 0x20) ? 1 : 0 ); Reported-by: Heinz Wrobel <heinz.wrobel@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/BSC9132: Add IFC bank countYork Sun
BSC9132 has 3 IFC banks. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/bsc9131rdb: Add DSP side tlb and lawsPriyanka Jain
BSC9131RDB is a Freescale Reference Design Board for BSC9131 SoC which is a integrated device that contains one powerpc e500v2 core and one DSP starcore. To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 memory Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: new SPL support for IFC NANDPrabhakar Kushwaha
Linker script is not able find start.o binary. So add its absolute path in u-boot-spl.lds. This change is similar to u-boot-nand.lds common/Makefile: Avoid compiling unnecssary files fsl_ifc_spl.c : It is is responsible for reading u-boot binary from NAND flash and copying into DDR. It also transfer control from NAND SPL to u-boot image present in DDR. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:No NOR boot, do not compile IFC errata A003399Prabhakar Kushwaha
IFC errata A003399 is valid for IFC NOR boot i.e.if no on-board NOR flash or no NOR boot, do not compile its workaround. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: explicit cast the SDRAM size to type phys_size_tMingkai Hu
To avoid sign extension problem, use explicit casting to cast the SDRAM size to type phys_size_t, or else, if the SDRAM size is 2G(0x80000000), it will be extended to 0xffffffff80000000 when phys_size_t is type 'unsigned long long'. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-2085xx: Change clock-frequency compatible to 2.0Andy Fleming
Accidentally applied an earlier version of the patch, which set the compatible to "fsl,qoriq-clockgen-2", lacking the final ".0". Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
2013-06-11powerpc: fix 8xx and 82xx type-punning warnings with GCC 4.7Scott Wood
C99's strict aliasing rules are insane to use in low-level code such as a bootloader, but as Wolfgang has rejected -fno-strict-aliasing in the past, add a union so that 16-bit accesses can be performed. Compile-tested only. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Wolfgang Denk <wd@denx.de>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-24powerpc/mpc85xx: Clear L1 D-cache lockYork Sun
dcbi instruction has been used to clear D-cache lock. However, the cache lock is persistent for e6500 core. Use dcblc to clear the lock explicitly. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24SECURE BOOT - Removed deletion of TLB entries codeRuchika Gupta
Boot ROM code creates TLB entries for 3.5G space before entering the u-boot. Earlier we were deleting these entries after early initialization of CPU. In recent past, code has been added to invalidate all these entries before relocation of u-boot code. So this code to delete TLB entries after CPU initialization is no longer required. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Acked-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/b4860qds: Add LAW Target ID and Create LAW entry for MapleShaveta Leekha
Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/B4: Merge B4420 and B4860 in config_mpc85xx.hPoonam Aggrwal
B4420 is a subset of B4860. Merge them in config_mpc85xx.h to simplify the defines. - Removed #define CONFIG_SYS_FSL_NUM_CLUSTERS as this is used nowhere. - defined CONFIG_SYS_NUM_FM1_10GEC to 0 for B4420 as it does not have 10G. Also move CONFIG_E6500 out of B4860QDSds.h into config_mpc85xx.h. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/mpc8xxx: Allow DDR overclockYork Sun
Allow DDR clock runs faster than SPD specifes. This may cause memory failure, but the user should know what is going to happen when using higher than expected DDR clock. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/chassis2: Change core numbering schemeYork Sun
To align with chassis generation 2 spec, all cores are numbered in sequence. The cores may reside across multiple clusters. Each cluster has zero to four cores. The first available core is numbered as core 0. The second available core is numbered as core 1 and so on. Core clocks are generated by each clusters. To identify the cluster of each core, topology registers are examined. Cluster clock registers are reorganized to be easily indexed. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/mpc8xxx: Add T1040 and variant SoCsYork Sun
T1040 and variants have e5500 cores and are compliant to QorIQ Chassis Generation 2. The major difference between T1040 and its variants is the number of cores and the number of L2 switch ports. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/T4160: Merge T4160 and T4240 in config_mpc85xx.hYork Sun
T4160 is a subset of T4240. Merge them in config_mpc85xx.h to simplify the defines. Also move CONFIG_E6500 out of t4qds.h into config_mpc85xx.h. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24Add e6500 L2 replacement policy selectionJames Yang
This is compile-time config. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/mpc85xx: check if core is disabled for showing statusYork Sun
"cpu <num> status" should check if core is disabled before printing the spin table location. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24Enable L2 cache parity/ECC error checkingJames Yang
2013-05-15Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-05-14powerpc/mpc8xxx: Allow board file to override DDR address assignmentYork Sun
This gives boards flexibility to assign other than default addresses to each DDR controller. For example, DDR controler 2 can have 0 as the base and DDR controller 1 has higher memory. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Update workaround for DDR erratum A-004934York Sun
The workaround has been updated to use a slightly different magic number. Change from 0x00003000 to 0x30003000. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4/usb: move usb 2.0 utmi dual phy init code to cpu_init.cRoy Zang
This is what we have done for the UTMI PHY on P3041/P5020. Then the PHY initialization can be reused in kernel without “usb start” command. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/85xx: fix build error introduced by serdes_get_prtclShengzhou Liu
Removed unused declare serdes_get_prtcl() which was no longer needed. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14t4240qds/eth: fixup ethernet for t4240qdsShengzhou Liu
1, Implemented board_ft_fman_fixup_port() to fix port for kernel. 2, Implemented fdt_fixup_board_enet() to fix node status of different slots and interfaces. 3, Adding detection of slot present for XGMII interface. 4, There is no PHY for XFI, so removed related phy address settings. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/85xx: add missing QMAN frequency calculationShaohui Xie
When CONFIG_SYS_FSL_QORIQ_CHASSIS2 is not defined, QMAN frequency will not be initialized, and QMAN will have a wrong frequency display. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Add T4160 SoCYork Sun
T4160 SoC is low power version of T4240. The T4160 combines eight dual threaded Power Architecture e6500 cores and two memory complexes (CoreNet platform cache and DDR3 memory controller) with the same high-performance datapath acceleration, networking, and peripheral bus interfaces. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240: Fix SerDes protocol arrays with const prefixYork Sun
Protocols are constants. Fix arrays with const prefix. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Fix PIR parsing for chassis2York Sun
The PIR parsing algorithm we used is not only for E6500. It applies to all SoCs with chassis 2. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/corenet2: Print SerDes protocol in decimalYork Sun
Use decimal and hexadecimal for protocol numbers. It helps to match with SoC user manual. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4/USB: Add USB 2.0 UTMI dual phy supportRoy Zang
T4240 internal UTMI phy is different comparing to previous UTMI PHY in P3041. This patch adds USB 2.0 UTMI Dual PHY new memory map and enable it for T4240. The phy timing is very sensitive and moving the phy enable code to cpu_init.c will not work. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Fix portal setupYork Sun
Missing nodes of crypto, pme, etc in device tree is not a fatal error. Setting up the qman portal should skip the missing node and continue to finish the rest. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc8xxx: Fix DDR 3-way interleavingYork Sun
Should check if interleaving is enabled before using interleaving mode. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4/SerDes: correct the SATA indexRoy Zang
Lane H on SerDes4 should be SATA2 instead of SATA1 Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
