path: root/arch/powerpc/lib/extable.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2012-11-04arch/powerpc/lib/extable.c: sparse fixKim Phillips
extable.c:66:9: warning: symbol 'ex_tab_message' was not declared. Should it be static? making it static can produce a new build warning on some boards: extable.c:66:12: warning: 'ex_tab_message' defined but not used [-Wunused-variable] but ex_tab_message doesn't do much even when used, so just remove it. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
