[trini: Fixup common/cmd_io.c]
Erratum A-006593 is "Atomic store may report failure but still allow
the store data to be visible".
The workaround is: "Set CoreNet Platform Cache register CPCHDBCR0 bit
21 to 1'b1. This may have a small impact on synthetic write bandwidth
benchmarks but should have a negligible impact on real code."
Signed-off-by: Andy Fleming <afleming@freescale.com>
Calculate reserved fields according to IFC bank count
1. Move csor_ext register behind csor register and fix res offset
2. Move ifc bank count to config_mpc85xx.h to support 8 bank count
3. Guard fsl_ifc.h with CONFIG_FSL_IFC macro to eliminate the compile
error on some devices that does not have IFC controller.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
When a T4 board boots from SRIO or PCIE, it needs to finish these processes:
1. Set all the cores in holdoff status.
2. Set the boot location to one PCIE or SRIO interface by RCW.
3. Set a specific TLB entry for the boot process.
4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
5. Set a specific TLB entry in order to fetch ucode and ENV from
master.
6. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
7. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please
refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
When a b4860qds board boots from SRIO or PCIE, it needs to finish these
processes:
master.
ucode and ENV.
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable
the master module of Boot from SRIO and PCIE on a platform. But this
is not a silicon feature, it's just a specific booting mode based on
the SRIO and PCIE interfaces. So it's inappropriate to put the macro
into the file arch/powerpc/include/asm/config_mpc85xx.h.
Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to
"CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from
arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros
in configuration header file of each board which can support the
master module of Boot from SRIO and PCIE.
All the other constants use lowercase 'x' in "MPC85xx", so we
duplicate that here.
BSC9132 has 3 IFC banks.
Signed-off-by: York Sun <yorksun@freescale.com>
BSC9131RDB is a Freescale Reference Design Board for
BSC9131 SoC which is a integrated device that contains
one powerpc e500v2 core and one DSP starcore.
To support DSP starcore
-Creating LAW and TLB for DSP-CCSR space.
-Creating LAW for DSP-core subsystem M2 memory
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
C99's strict aliasing rules are insane to use in low-level code such as a
bootloader, but as Wolfgang has rejected -fno-strict-aliasing in the
past, add a union so that 16-bit accesses can be performed.
Compile-tested only.
Acked-by: Wolfgang Denk <wd@denx.de>
common/cmd_fpga.c
drivers/usb/host/ohci-at91.c
Boot ROM code creates TLB entries for 3.5G space before entering
the u-boot. Earlier we were deleting these entries after early
initialization of CPU. In recent past, code has been added
to invalidate all these entries before relocation of u-boot code.
So this code to delete TLB entries after CPU initialization
is no longer required.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Acked-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
B4420 is a subset of B4860. Merge them in config_mpc85xx.h to simplify
the defines.
- Removed #define CONFIG_SYS_FSL_NUM_CLUSTERS as this is used nowhere.
- defined CONFIG_SYS_NUM_FM1_10GEC to 0 for B4420 as it does not have 10G.
Also move CONFIG_E6500 out of B4860QDSds.h into config_mpc85xx.h.
To align with chassis generation 2 spec, all cores are numbered in sequence.
The cores may reside across multiple clusters. Each cluster has zero to four
cores. The first available core is numbered as core 0. The second available
core is numbered as core 1 and so on.
Core clocks are generated by each clusters. To identify the cluster of each
core, topology registers are examined.
Cluster clock registers are reorganized to be easily indexed.
T1040 and variants have e5500 cores and are compliant to QorIQ Chassis
Generation 2. The major difference between T1040 and its variants is the
number of cores and the number of L2 switch ports.
T4160 is a subset of T4240. Merge them in config_mpc85xx.h to simplify
the defines. Also move CONFIG_E6500 out of t4qds.h into config_mpc85xx.h.
This is compile-time config.
Signed-off-by: James Yang <James.Yang@freescale.com>
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
Removed unused declare serdes_get_prtcl() which was no longer needed.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
1, Implemented board_ft_fman_fixup_port() to fix port for kernel.
2, Implemented fdt_fixup_board_enet() to fix node status of different
slots and interfaces.
3, Adding detection of slot present for XGMII interface.
4, There is no PHY for XFI, so removed related phy address settings.
T4160 SoC is low power version of T4240. The T4160 combines eight dual
threaded Power Architecture e6500 cores and two memory complexes (CoreNet
platform cache and DDR3 memory controller) with the same high-performance
datapath acceleration, networking, and peripheral bus interfaces.
T4240 internal UTMI phy is different comparing to previous UTMI PHY
in P3041.
This patch adds USB 2.0 UTMI Dual PHY new memory map and enable it for
T4240.
The phy timing is very sensitive and moving the phy enable code to
cpu_init.c will not work.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Fix ccsr_gur for corenet platform. Remove non-exist registers. Add fuse
status register.
Makes it a bit easier to see if we've properly set them. While
we're in there, modify the accesses to HDBCR0 and HDBCR1 to actually
use those definitions.
drivers/mtd/nand/mxc_nand_spl.c
include/configs/m28evk.h
Erratum DDR_A003 applies to P5020, P3041, P4080, P3060, P2041, P5040.
As per Errata list of BSC9131 and BSC9132, IFC Errata A003399 is no more
valid. So donot compile its workaround.
On P204x/P304x/P50x0 Rev1.0, USB transmit will result in false internal
multi-bit ECC errors, which has impact on performance, so software should
disable all ECC reporting from USB1 and USB2.
In formal release document, the errata number should be USB14 instead of USB138.
Signed-off-by: xulei <Lei.Xu@freescale.com>
Signed-off-by: xulei <B33228@freescale.com>
Some legacy RGMII phys don't have in band signaling for the
speed information. so set the RGMII MAC mode according to
the speed got from PHY.
Reported-by: John Traill <john.traill@freescale.com>
Per the latest errata updated, B4860/B4420 Rev 1.0 has also
errata A-005871, so adding define A-005871 for B4 SoCs.
B4420/B4860 PCIE can not work because of the wrong definition of
the PCIE register offset in the file:
arch/powerpc/include/asm/immap_85xx.h
Add the judgement of B4420/B4860 to make the register offset to:
#define CONFIG_SYS_MPC85xx_PCIE1_OFFSET 0x200000
Add a fsl_iim driver common to i.MX and MPC.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This enables generic board support so that ppc boards can define
CONFIG_SYS_GENERIC_BOARD.
We create a separate header file for link symbols defined by the link
scripts. It is helpful to have these all in one place and try to
make them common across architectures. Since Linux already has a similar
file, we bring this in even though many of the symbols there are not
relevant to us.
Each architecture has its own asm/sections.h where symbols specifc to
that architecture can be added. For now everything except AVR32 just
includes the generic header.
One change is needed in arch/avr32/lib/board.c to make this conversion
work.
Reviewed-by: Tom Rini <trini@ti.com> (version 5)
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Do maintain a 200 usecs period of stable power and clock before
asserting the CKE signal and sending commands, have at least 200
DRAM clock cycles pass after initialization before data access.
Add new mpc5121e based ac14xx board and a new pinmux config
function for setting individual pinmux bit groups. This
function is used in ac14xx board code.
Boards may define own IPS divider in the config file if
the default IPS divider doesn't fit their needs.
If a board config file defines DIU, LPC and NFC deviders,
configure them in the SCFR1 register.
Move powerpc over to use generic global_data.
This is used by both powerpc and arm, but I think it still qualifies as
architecture-specific.
Move this field into arch_global_data and tidy up.
This does not appear to be used, so punt it.
Move these fields into arch_global_data and tidy up.
