path: root/arch/powerpc/include
2014-04-02mmc:eSDHC: Workaround for data timeout issue on Txxx SoCHaijun.Zhang
1. The Data timeout counter value in eSDHC_SYSCTL register is not working as it should be, so add quirks to enable this workaround to fix it to the max value 0xE. 2. Add CONFIG_SYS_FSL_ERRATUM_ESDHC111 to enable its workaround. * Update of patch for change mmc interface by Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-07Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-03-07powerpc/mpc85xx: Add SCFG_PIXCLKCR register support for T1040Priyanka Jain
T1040 SoC has SCFG (Supplement Configuration) Block which provides chip specific configuration and status support. The base address of SCFG block in T1040 is 0xfc000. SCFG contains SCFG_PIXCLKCR (DIU pixel clock control register) at offset 0x28. Add definition of -SCFG block -SCFG_PIXCLKCR register -Bits definition of SCFG_PIXCLK register Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc/usb: Workaround for erratum-A006261Suresh Gupta
USB spec says that the minimum disconnect threshold should be over 525 mV. However, internal USB PHY threshold value is below this specified value. Due to this some devices disconnect at run-time. Hence, phy settings are tweaked to increased disconnect threshold to be above 525mV by using this workaround. Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc/b4860: Add workaround for errata A006384 and A006475Shaveta Leekha
SerDes PLLs may not lock reliably at 5 G VCO configuration(A006384) and at cold temperatures(A006475), workaround recalibrate the PLLs with some SerDes configuration Both these errata are only applicable for b4 rev1. So, make workaround for these errata conditional, depending upon soc version. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07B4860/B4420: Add PLL_NUM define for B4420/B4860 to use SerDes2 Refclks ↵Shaveta Leekha
re-configuration B4860 has two PLL per SerDes whereas B4420 has one PLL per SerDes, add their defines in arch/powerpc/include/asm/config_mpc85xx.h Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07board/b4860qds: Add support to make PCIe SATA work on B4860QDSShaveta Leekha
1) SerDes2 Refclks have been set properly to make PCIe SATA to work as it work on SerDes refclk of 100MHz 2) Mask the SerDes's device reset request before changing the Refclks for SerDes1 and SerDes2 for PLL locks to happen properly, device reset request bit unmasked after SerDes refclks configuration Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-02-03driver/ifc:Change accessor function to take care of endiannessPrabhakar Kushwaha
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP. So update acessor functions with common IFC acessor functions to take care both type of endianness. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-02-03powerpc/usb: Enable dual phy for T1040Nikhil Badola
Define CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE macro for enabling dual phy in t1040 Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-03boards/t1040qds: Adds ethernet support for T1040Prabhakar Kushwaha
Enable entherent for T1040QDS. It enables FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5 Define MDIO related configs Added eth.c file Update t1040.c to support RGMII and SGMII Update t1040qds.c to support ethernet Define the PHY address Signed-off-by: Arpit Goel <B44344@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: remove dash from commit message] Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-03powerpc/mpc85xx: Update serdes protocols for T1040Prabhakar Kushwaha
T1040 has only one SerDes block. so update the code accordingly. Also, add support of SerDes Protocol 0x00, 0x06, 0x40, 0x69 0x85, 0xA7 and 0xAA Signed-off-by: Arpit Goel <B44344@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: delete unused header filesMasahiro Yamada
2014-01-22eSDHC: Calculate envaddr accroding to the address formatHaijun.Zhang
On BSC9131, BSC9132, P1010 : For High Capacity SD Cards (> 2 GBytes), the 32-bit source address specifies the memory address in block address format. Block length is fixed to 512 bytes as per the SD High Capacity specification. So we need to convert the block address format to byte address format to calculate the envaddr. If there is no enough space for environment variables or envaddr is larger than 4GiB, we relocate the envaddr to 0x400. The address relocated is in the front of the first partition that is assigned for sdboot only. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/85xx: update erratum a006379Shengzhou Liu
Enable Erratum A006379 for T2080, T2081, T4160, B4420. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-02powerpc/t208x: fix macro CONFIG_SYS_FSL_NUM_USB_CTRLSShengzhou Liu
CONFIG_SYS_FSL_NUM_USB_CTRLS is no longer used, update it to new CONFIG_USB_MAX_CONTROLLER_COUNT. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2014-01-02powerpc/mpc85xx: Add support for single source clockingPriyanka Jain
Single-source clocking is new feature introduced in T1040. In this mode, a single differential clock is supplied to the DIFF_SYSCLK_P/N inputs to the processor, which in turn is used to supply clocks to the sysclock, ddrclock and usbclock. So, both ddrclock and syclock are driven by same differential sysclock in single-source clocking mode whereas in normal clocking mode, generally separate DDRCLK and SYSCLK pins provides reference clock for sysclock and ddrclock DDR_REFCLK_SEL rcw bit is used to determine DDR clock source -If DDR_REFCLK_SEL rcw bit is 0, then DDR PLLs are driven in normal clocking mode by DDR_Reference clock -If DDR_REFCLK_SEL rcw bit is 1, then DDR PLLs are driven in single source clocking mode by DIFF_SYSCLK Add code to determine ddrclock based on DDR_REFCLK_SEL rcw bit. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-12-11powerpc/mpc85xx: Update CONFIG_SYS_FSL_TBCLK_DIV for T1040Prabhakar Kushwaha
The default value of CONFIG_SYS_FSL_TBCLK_DIV is 16. So, update its value as default. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-11-25powerpc/mpc85xx: Add T2080/T2081 SoC supportShengzhou Liu
Add support for Freescale T2080/T2081 SoC. T2080 includes the following functions and features: - Four dual-threads 64-bit Power architecture e6500 cores, up to 1.8GHz - 2MB L2 cache and 512KB CoreNet platform cache (CPC) - Hierarchical interconnect fabric - One 32-/64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving - Data Path Acceleration Architecture (DPAA) incorporating acceleration - 16 SerDes lanes up to 10.3125 GHz - 8 mEMACs for network interfaces (four 1Gbps MACs and four 10Gbps/1Gbps MACs) - High-speed peripheral interfaces - Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV) - Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz - Additional peripheral interfaces - Two serial ATA (SATA 2.0) controllers - Two high-speed USB 2.0 controllers with integrated PHY - Enhanced secure digital host controller (SD/SDHC/SDXC/eMMC) - Enhanced serial peripheral interface (eSPI) - Four I2C controllers - Four 2-pin UARTs or two 4-pin UARTs - Integrated Flash Controller supporting NAND and NOR flash - Three eight-channel DMA engines - Support for hardware virtualization and partitioning enforcement - QorIQ Platform's Trust Architecture 2.0 Differences between T2080 and T2081: Feature T2080 T2081 1G Ethernet numbers: 8 6 10G Ethernet numbers: 4 2 SerDes lanes: 16 8 Serial RapidIO,RMan: 2 no SATA Controller: 2 no Aurora: yes no SoC Package: 896-pins 780-pins Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-11-25net/fman: Add support for 10GEC3 and 10GEC4Shengzhou Liu
There are more than two 10GEC in single FMAN in some SoCs(e.g. T2080). This patch adds support for 10GEC3 and 10GEC4. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-11-25Driver/IFC: Move Freescale IFC driver to a common driverYork Sun
Freescale IFC controller has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the driver to driver/misc and fix the header file includes. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25mpc85xx: Fix the offset of register address errorTang Yuantian
The offset of register address within GPIO module is just CONFIG_SYS_MPC85xx_GPIO_ADDR. So, fix it. The following platforms are confirmed: MPC8572, P1023, P1020, P1022, P2020, P4080, P5020, P5040, T4240, B4860. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
2013-11-13powerpc/t4240: fix per pci endpoint liodn offsetsLaurentiu TUDOR
Update the code that builds the pci endpoint liodn offset list so that it doesn't overlap with other liodns and doesn't generate negative offsets like: fsl,liodn-offset-list = <0 0xffffffcd 0xffffffcf 0xffffffd1 0xffffffd3 0xffffffd5 0xffffffd7 0xffffffd9 0xffffffdb>; The update consists in adding a parameter to the function that builds the list to specify the base liodn. On PCI v2.4 use the old base = 256 and, on PCI 3.0 where some of the PCIE liodns are larger than 256, use a base = 1024. The version check is based on the PCI controller's version register. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com>
2013-11-13powerpc/83xx: Define USB1 and USB2 base addr for MPC834xramneek mehresh
Define base addresse for both MPH(USB1) and DR(USB2) controllers for MPC834x socs Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-11-13powerpc/t1040: Update defines to support T1040SoC personalitiesPriyanka Jain
T1040 Soc has four personalities: -T1040 (4 cores with L2 switch) -T1042:Reduced personality of T1040 without L2 switch -T1020:Reduced personality of T1040 with less cores(2 cores) -T1022:Reduced personality of T1040 with 2 cores and without L2 switch Update defines in arch/powerpc header files, Makefiles and in driver/net/fm/Makefile to support all T1040 personalities Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefiles] Acked-by: York Sun <yorksun@freescale.com>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-10-24fsl/mpc85xx: define common serdes_clock_to_string functionValentin Longchamp
This allows to share some common code for the boards that use a corenet base SoC. Two different versions of the function are available in fsl_corenet_serdes.c and fsl_corenet2_serdes.c files. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix t1040qds.c] Acked-by: York Sun <yorksun@freescale.com>
2013-10-24mpc8xxx: set x2 DDR3 refresh rate if SPD config requires itValentin Longchamp
If the DDR3 module supports industrial temperature range and requires the x2 refresh rate for that temp range, the refresh period must be 3.9us instead of 7.8 us. This was successfuly tested on kmp204x board with some MT41K128M16 DDR3 RAM chips (no module used, chips directly soldered on board with an SPD EEPROM). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix minor conflicts in fsl_ddr_dimm_params.h, lc_common_dimm_params.c, common_timing_params.h] Acked-by: York Sun <yorksun@freescale.com>
2013-10-24powerpc/usb:Differentiate USB controller base addressramneek mehresh
Introduce different macros for storing addresses of multiple USB controllers. This is required for successful initialization and usage of multiple USB controllers inside u-boot Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-10-24powerpc/usb:Define CONFIG_USB_MAX_CONTROLLER_COUNT for all 85xx socsramneek mehresh
CONFIG_USB_MAX_CONTROLLER_COUNT macro recently defined for initializing all USB controllers on a given platform. This macro is defined for all 85xx socs Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-10-16PCIe:change the method to get the address of a requested capability in ↵Zhao Qiang
configuration space. Previously, the address of a requested capability is define like that "#define PCI_DCR 0x78" But, the addresses of capabilities is different with regard to PCIe revs. So this method is not flexible. Now a function to get the address of a requested capability is added and used. It can get the address dynamically by capability ID. The step of this function: 1. Read Status register in PCIe configuration space to confirm that Capabilities List is valid. 2. Find the address of Capabilities Pointer Register. 3. Find the address of requested capability from the first capability. Signed-off-by: Zhao Qiang <B45475@freescale.com>
2013-10-16powerpc/mpc85xx: Add workaround for erratum A006379York Sun
Erratum A006379 says CPCHDBCR0 bit field [10:14] has incorrect default value after POR. The workaround is to set this field before enabling CPC to 0x1e. Erratum A006379 applies to T4240 rev 1.0 B4860 rev 1.0, 2.0 Signed-off-by: York Sun <yorksun@freescale.com>
2013-10-16powerpc: Fix CamelCase warnings in DDR related codePriyanka Jain
Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h has various parameters with embedded acronyms capitalized that trigger the CamelCase warning in checkpatch.pl Convert those variable names to smallcase naming convention and modify all files which are using these structures with modified structures. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-10-16powerpc/mpc85xx:Avoid fix clk groups for Cluster & HW acceleratorPrabhakar Kushwaha
CHASSIS2 architecture never fix clock groups for Cluster and hardware accelerator like PME, FMA. These are SoC defined. SoC defines :- - NUM of PLLs present in the system - Clusters and their Clock group - hardware accelerator and their clock group if no clock group, then platform clock divider for FMAN, PME Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-10-16powerpc/mpc85xx:Update processor defines for T1040Prabhakar Kushwaha
T1040 SoC has - DDR controller ver 5.0 - 2 PLLs - 8 IFC Chip select - FMAN Muram 192K - No Srio - Sec controller ver 5.0 - Max CPU update for its personalities So, update the defines accordingly. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-10-16powerpc: add CONFIG_SECURE_BOOT condition into fsl_secure_boot.hPo Liu
This patch is for board config file not to add CONFIG_SECURE_BOOT condition for include the asm/fsl_secure_boot.h. Signed-off-by: Po Liu <Po.Liu@freescale.com>
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-09-10powerpc/mpc85xx: Add workaround for erratum A-005125York Sun
In a very rare condition, a system hang is possible when the e500 core initiates a guarded load to PCI / PCIe /SRIO performs a coherent write to memory. Please refer to errata document for more details. This erratum applies to the following SoCs and their variants, if any. BSC9132 BSC9131 MPC8536 MPC8544 MPC8548 MPC8569 MPC8572 P1010 P1020 P1021 P1022 P1023 P2020 C29x Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com>
2013-08-21Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-08-20powerpc/sec: Add workaround for SEC A-003571Shengzhou Liu
Multiple read/write transactions initiated by security engine may cause system to hang. Workaround: set MCFGR[AXIPIPE] to 0 to avoid hang. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-08-20fsl_i2c: add workaround for the erratum I2C A004447Chunhe Lan
This workaround is for the erratum I2C A004447. Device reference manual provides a scheme that allows the I2C master controller to generate nine SCL pulses, which enable an I2C slave device that held SDA low to release SDA. However, due to this erratum, this scheme no longer works. In addition, when I2C is used as a source of the PBL, the state machine is not able to recover. At the same time, delete the reduplicative definition of SVR_VER and SVR_REV. The SVR_REV is the low 8 bits rather than the low 16 bits of svr. And we use the CONFIG_SYS_FSL_A004447_SVR_REV macro instead of hard-code value 0x10, 0x11 and 0x20. The CONFIG_SYS_FSL_A004447_SVR_REV = 0x00 represents that one version of platform has this I2C errata. So enable this errata by IS_SVR_REV(svr, maj, min) function. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Heiko Schocher <hs@denx.de>
2013-08-19SPDX-License-Identifier: convert PIBS licensed filesWolfgang Denk
This commit adapts the files that were derived from PIBS (PowerPC Initialization and Boot Software) codeto using SPDX License Identifiers. So far, SPDX has not assigned an official License ID for the PIBS license yet, so this should be considered preliminary. Note that the following files contained incorrect license information: arch/powerpc/cpu/ppc4xx/4xx_uart.c arch/powerpc/cpu/ppc4xx/start.S arch/powerpc/include/asm/ppc440.h These files included, in addition to the GPL-2.0 / ibm-pibs dual license as inherited from PIBS, a GPL-2.0+ license header which was obviously incorrect. This has been removed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Conflicts: Licenses/README Acked-by: Stefan Roese <sr@denx.de>
2013-08-14fsl/usb: Move USB internal phy definitions to fsl_usb.hramneek mehresh
fsl_usb.h file created to share data bewteen usb platform code and usb ip driver. Internal phy structure definitions moved to this file Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-14powerpc/mpc85xx:Avoid hardcoded init for serdes block 1 & 2Prabhakar Kushwaha
It is not necessary for all processor to have serdes block 1 & 2. They may have only one serdes block. So, put serdes block 1 & 2 related code under defines Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/85xx: Add C29x SoC supportMingkai Hu
The Freescale C29x family is a high performance crypto co-processor. It combines a single e500v2 core with necessary SEC engine. There're three SoC types(C291, C292, C293) with the following features: - 512K L2 Cache/SRAM and 512 KB platform SRAM - DDR3/DDR3L 32bit DDR controller - One PCI express (x1, x2, x4) Gen 2.0 Controller - Trust Architecture 2.0 - SEC6.0 engine Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Po Liu <Po.Liu@freescale.com>
