path: root/arch/powerpc/include/asm/processor.h
2015-03-04powerpc/mpc85xx: Add DSP side awareness for Freescale Heterogeneous SoCsShaveta Leekha
The code provides framework for heterogeneous multicore chips based on StarCore and Power Architecture which are chasis-2 compliant, like B4860 and B4420 It will make u-boot recognize all non-ppc cores and peripherals like SC3900/DSP CPUs, MAPLE, CPRI and print their configuration in u-boot logs. Example boot logs of B4860QDS: U-Boot 2015.01-00232-geef6e36-dirty (Jan 19 2015 - 11:58:45) CPU0: B4860E, Version: 2.2, (0x86880022) Core: e6500, Version: 2.0, (0x80400120) Clock Configuration: CPU0:1600 MHz, CPU1:1600 MHz, CPU2:1600 MHz, CPU3:1600 MHz, DSP CPU0:1200 MHz, DSP CPU1:1200 MHz, DSP CPU2:1200 MHz, DSP CPU3:1200 MHz, DSP CPU4:1200 MHz, DSP CPU5:1200 MHz, CCB:666.667 MHz, DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:166.667 MHz CPRI:600 MHz MAPLE:600 MHz, MAPLE-ULB:800 MHz, MAPLE-eTVPE:1000 MHz FMAN1: 666.667 MHz QMAN: 333.333 MHz Top level changes include: (1) Top level CONFIG to identify HETEROGENUOUS clusters (2) CONFIGS for SC3900/DSP components (3) Global structures like "cpu_type" and "MPC85xx_SYS_INFO" updated for dsp cores and other components (3) APIs to get DSP num cores and their Mask like: cpu_dsp_mask, cpu_num_dspcores etc same as that of PowerPC (5) Code to fetch and print SC cores and other heterogenous device's frequencies (6) README added for the same Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2014-12-05powerpc/mpc85xx: Add T1024/T1023 SoC supportShengzhou Liu
Add support for Freescale T1024/T1023 SoC. The T1024 SoC includes the following function and features: - Two 64-bit Power architecture e5500 cores, up to 1.4GHz - private 256KB L2 cache each core and shared 256KB CoreNet platform cache (CPC) - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration - Four MAC for 1G/2.5G/10G network interfaces (RGMII, SGMII, QSGMII, XFI) - High-speed peripheral interfaces - Three PCI Express 2.0 controllers - Additional peripheral interfaces - One SATA 2.0 controller - Two USB 2.0 controllers with integrated PHY - Enhanced secure digital host controller (SD/eSDHC/eMMC) - Enhanced serial peripheral interface (eSPI) - Four I2C controllers - Four 2-pin UARTs or two 4-pin UARTs - Integrated Flash Controller supporting NAND and NOR flash - Two 8-channel DMA engines - Multicore programmable interrupt controller (PIC) - LCD interface (DIU) with 12 bit dual data rate - QUICC Engine block supporting TDM, HDLC, and UART - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - Support for hardware virtualization and partitioning enforcement - QorIQ Platform's Trust Architecture 2.0 Differences between T1024 and T1023: Feature T1024 T1023 QUICC Engine: yes no DIU: yes no Deep Sleep: yes no I2C controller: 4 3 DDR: 64-bit 32-bit IFC: 32-bit 28-bit Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-01powerpc: macros for e500mc timer regs addedBoschung, Rainer
For e500mc cores the watchdog timer period has to be set by means of a 6bit value, that defines the bit of the timebase counter used to signal a watchdog timer exception on its 0 to 1 transition. The macro used to set the watchdog period TCR_WP, was redefined for e500mc to support 6 WP setting. The parameter (x) given to the macro specifies the prescaling factor of the time base clock (fTB): watchdog_period = 1/fTB * 2^x Signed-off-by: Rainer Boschung <rainer.boschung@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/mpc85xx: Removed support for G4060Sandeep Singh
G4060 has no PA cores, hence removing its support. Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-30powerpc: hiddendragon: remove orphan boardMasahiro Yamada
This board has been orphan for a while. (Emails to its maintainer have been bouncing.) Because MPC82xx family is old enough, nobody would pick up the maintainership on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denx <wd@denx.de>
2014-05-16powerpc/mpc85xx: Added B4460 supportShaveta Leekha
B4460 differs from B4860 only in number of CPU cores, hence used existing support for B4860. B4460 has 2 PPC cores whereas B4860 has 4 PPC cores. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13powerpc/85xx: add T4080 SoC supportShengzhou Liu
The T4080 SoC is a low-power version of the T4160. T4080 combines 4 dual-threaded Power Architecture e6500 cores with single cluster and two memory complexes. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-11-25powerpc/mpc85xx: Add T2080/T2081 SoC supportShengzhou Liu
Add support for Freescale T2080/T2081 SoC. T2080 includes the following functions and features: - Four dual-threads 64-bit Power architecture e6500 cores, up to 1.8GHz - 2MB L2 cache and 512KB CoreNet platform cache (CPC) - Hierarchical interconnect fabric - One 32-/64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving - Data Path Acceleration Architecture (DPAA) incorporating acceleration - 16 SerDes lanes up to 10.3125 GHz - 8 mEMACs for network interfaces (four 1Gbps MACs and four 10Gbps/1Gbps MACs) - High-speed peripheral interfaces - Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV) - Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz - Additional peripheral interfaces - Two serial ATA (SATA 2.0) controllers - Two high-speed USB 2.0 controllers with integrated PHY - Enhanced secure digital host controller (SD/SDHC/SDXC/eMMC) - Enhanced serial peripheral interface (eSPI) - Four I2C controllers - Four 2-pin UARTs or two 4-pin UARTs - Integrated Flash Controller supporting NAND and NOR flash - Three eight-channel DMA engines - Support for hardware virtualization and partitioning enforcement - QorIQ Platform's Trust Architecture 2.0 Differences between T2080 and T2081: Feature T2080 T2081 1G Ethernet numbers: 8 6 10G Ethernet numbers: 4 2 SerDes lanes: 16 8 Serial RapidIO,RMan: 2 no SATA Controller: 2 no Aurora: yes no SoC Package: 896-pins 780-pins Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-08-20fsl_i2c: add workaround for the erratum I2C A004447Chunhe Lan
This workaround is for the erratum I2C A004447. Device reference manual provides a scheme that allows the I2C master controller to generate nine SCL pulses, which enable an I2C slave device that held SDA low to release SDA. However, due to this erratum, this scheme no longer works. In addition, when I2C is used as a source of the PBL, the state machine is not able to recover. At the same time, delete the reduplicative definition of SVR_VER and SVR_REV. The SVR_REV is the low 8 bits rather than the low 16 bits of svr. And we use the CONFIG_SYS_FSL_A004447_SVR_REV macro instead of hard-code value 0x10, 0x11 and 0x20. The CONFIG_SYS_FSL_A004447_SVR_REV = 0x00 represents that one version of platform has this I2C errata. So enable this errata by IS_SVR_REV(svr, maj, min) function. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Heiko Schocher <hs@denx.de>
2013-08-09powerpc/85xx: Add C29x SoC supportMingkai Hu
The Freescale C29x family is a high performance crypto co-processor. It combines a single e500v2 core with necessary SEC engine. There're three SoC types(C291, C292, C293) with the following features: - 512K L2 Cache/SRAM and 512 KB platform SRAM - DDR3/DDR3L 32bit DDR controller - One PCI express (x1, x2, x4) Gen 2.0 Controller - Trust Architecture 2.0 - SEC6.0 engine Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Po Liu <Po.Liu@freescale.com>
2013-05-24powerpc/chassis2: Change core numbering schemeYork Sun
To align with chassis generation 2 spec, all cores are numbered in sequence. The cores may reside across multiple clusters. Each cluster has zero to four cores. The first available core is numbered as core 0. The second available core is numbered as core 1 and so on. Core clocks are generated by each clusters. To identify the cluster of each core, topology registers are examined. Cluster clock registers are reorganized to be easily indexed. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24powerpc/mpc8xxx: Add T1040 and variant SoCsYork Sun
T1040 and variants have e5500 cores and are compliant to QorIQ Chassis Generation 2. The major difference between T1040 and its variants is the number of cores and the number of L2 switch ports. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24Add e6500 L2 replacement policy selectionJames Yang
This is compile-time config. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Add T4160 SoCYork Sun
T4160 SoC is low power version of T4240. The T4160 combines eight dual threaded Power Architecture e6500 cores and two memory complexes (CoreNet platform cache and DDR3 memory controller) with the same high-performance datapath acceleration, networking, and peripheral bus interfaces. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/mpc85xx: Add definitions for HDBCR registersAndy Fleming
Makes it a bit easier to see if we've properly set them. While we're in there, modify the accesses to HDBCR0 and HDBCR1 to actually use those definitions. Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/mpc85xx: Add BSC9132/BSC9232 processor supportPrabhakar Kushwaha
The BSC9132 is a highly integrated device that targets the evolving Microcell, Picocell, and Enterprise-Femto base station market subsegments. The BSC9132 device combines Power Architecture e500 and DSP StarCore SC3850 core technologies with MAPLE-B2P baseband acceleration processing elements to address the need for a high performance, low cost, integrated solution that handles all required processing layers without the need for an external device except for an RF transceiver or, in a Micro base station configuration, a host device that handles the L3/L4 and handover between sectors. The BSC9132 SoC includes the following function and features: - Power Architecture subsystem including two e500 processors with 512-Kbyte shared L2 cache - Two StarCore SC3850 DSP subsystems, each with a 512-Kbyte private L2 cache - 32 Kbyte of shared M3 memory - The Multi Accelerator Platform Engine for Pico BaseStation Baseband Processing (MAPLE-B2P) - Two DDR3/3L memory interfaces with 32-bit data width (40 bits including ECC), up to 1333 MHz data rate - Dedicated security engine featuring trusted boot - Two DMA controllers - OCNDMA with four bidirectional channels - SysDMA with sixteen bidirectional channels - Interfaces - Four-lane SerDes PHY - PCI Express controller complies with the PEX Specification-Rev 2.0 - Two Common Public Radio Interface (CPRI) controller lanes - High-speed USB 2.0 host and device controller with ULPI interface - Enhanced secure digital (SD/MMC) host controller (eSDHC) - Antenna interface controller (AIC), supporting four industry standard JESD207/four custom ADI RF interfaces - ADI lanes support both full duplex FDD support & half duplex TDD - Universal Subscriber Identity Module (USIM) interface that facilitates communication to SIM cards or Eurochip pre-paid phone cards - Two DUART, two eSPI, and two I2C controllers - Integrated Flash memory controller (IFC) - GPIO - Sixteen 32-bit timers Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-12-05powerpc: Extract EPAPR_MAGIC constants into processor.hStefan Roese
By extracting these defines into a header, they can be re-used by other C sources as well. This will be done by the SPL framework OS boot support. Signed-off-by: Stefan Roese <sr@denx.de>
2012-10-22powerpc/mpc85xx: Add B4860 and variant SoCsYork Sun
Add support for Freescale B4860 and variant SoCs. Features of B4860 are (incomplete list): Six fully-programmable StarCore SC3900 FVP subsystems, divided into three clusters-each core runs up to 1.2 GHz, with an architecture highly optimized for wireless base station applications Four dual-thread e6500 Power Architecture processors organized in one cluster-each core runs up to 1.8 GHz Two DDR3/3L controllers for high-speed, industry-standard memory interface each runs at up to 1866.67 MHz MAPLE-B3 hardware acceleration-for forward error correction schemes including Turbo or Viterbi decoding, Turbo encoding and rate matching, MIMO MMSE equalization scheme, matrix operations, CRC insertion and check, DFT/iDFT and FFT/iFFT calculations, PUSCH/PDSCH acceleration, and UMTS chip rate acceleration CoreNet fabric that fully supports coherency using MESI protocol between the e6500 cores, SC3900 FVP cores, memories and external interfaces. CoreNet fabric interconnect runs at 667 MHz and supports coherent and non-coherent out of order transactions with prioritization and bandwidth allocation amongst CoreNet endpoints. Data Path Acceleration Architecture, which includes the following: Frame Manager (FMan), which supports in-line packet parsing and general classification to enable policing and QoS-based packet distribution Queue Manager (QMan) and Buffer Manager (BMan), which allow offloading of queue management, task management, load distribution, flow ordering, buffer management, and allocation tasks from the cores Security engine (SEC 5.3)-crypto-acceleration for protocols such as IPsec, SSL, and 802.16 RapidIO manager (RMAN) - Support SRIO types 8, 9, 10, and 11 (inbound and outbound). Supports types 5, 6 (outbound only) Large internal cache memory with snooping and stashing capabilities for bandwidth saving and high utilization of processor elements. The 9856-Kbyte internal memory space includes the following: 32 Kbyte L1 ICache per e6500/SC3900 core 32 Kbyte L1 DCache per e6500/SC3900 core 2048 Kbyte unified L2 cache for each SC3900 FVP cluster 2048 Kbyte unified L2 cache for the e6500 cluster Two 512 Kbyte shared L3 CoreNet platform caches (CPC) Sixteen 10-GHz SerDes lanes serving: Two Serial RapidIO interfaces. Each supports up to 4 lanes and a total of up to 8 lanes Up to 8-lanes Common Public Radio Interface (CPRI) controller for glue- less antenna connection Two 10-Gbit Ethernet controllers (10GEC) Six 1G/2.5-Gbit Ethernet controllers for network communications PCI Express controller Debug (Aurora) Two OCeaN DMAs Various system peripherals 182 32-bit timers Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc85xx: Add T4240 SoCYork Sun
Add support for Freescale T4240 SoC. Feature of T4240 are (incomplete list): 12 dual-threaded e6500 cores built on Power Architecture® technology Arranged as clusters of four cores sharing a 2 MB L2 cache. Up to 1.8 GHz at 1.0 V with 64-bit ISA support (Power Architecture v2.06-compliant) Three levels of instruction: user, supervisor, and hypervisor 1.5 MB CoreNet Platform Cache (CPC) Hierarchical interconnect fabric CoreNet fabric supporting coherent and non-coherent transactions with prioritization and bandwidth allocation amongst CoreNet end-points 1.6 Tbps coherent read bandwidth Queue Manager (QMan) fabric supporting packet-level queue management and quality of service scheduling Three 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving support Memory prefetch engine (PMan) Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: Packet parsing, classification, and distribution (Frame Manager 1.1) Queue management for scheduling, packet sequencing, and congestion management (Queue Manager 1.1) Hardware buffer management for buffer allocation and de-allocation (BMan 1.1) Cryptography acceleration (SEC 5.0) at up to 40 Gbps RegEx Pattern Matching Acceleration (PME 2.1) at up to 10 Gbps Decompression/Compression Acceleration (DCE 1.0) at up to 20 Gbps DPAA chip-to-chip interconnect via RapidIO Message Manager (RMAN 1.0) 32 SerDes lanes at up to 10.3125 GHz Ethernet interfaces Up to four 10 Gbps Ethernet MACs Up to sixteen 1 Gbps Ethernet MACs Maximum configuration of 4 x 10 GE + 8 x 1 GE High-speed peripheral interfaces Four PCI Express 2.0/3.0 controllers Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz with Type 11 messaging and Type 9 data streaming support Interlaken look-aside interface for serial TCAM connection Additional peripheral interfaces Two serial ATA (SATA 2.0) controllers Two high-speed USB 2.0 controllers with integrated PHY Enhanced secure digital host controller (SD/MMC/eMMC) Enhanced serial peripheral interface (eSPI) Four I2C controllers Four 2-pin or two 4-pin UARTs Integrated Flash controller supporting NAND and NOR flash Two eight-channel DMA engines Support for hardware virtualization and partitioning enforcement QorIQ Platform's Trust Architecture 1.1 Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/85xx: Add P5040 processor supportTimur Tabi
Add support for the Freescale P5040 SOC, which is similar to the P5020. Features of the P5040 are: Four P5040 single-threaded e5500 cores built Up to 2.4 GHz with 64-bit ISA support Three levels of instruction: user, supervisor, hypervisor CoreNet platform cache (CPC) 2.0 MB configures as dual 1 MB blocks hierarchical interconnect fabric Two 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving support Up to 1600MT/s Memory pre-fetch engine DPAA incorporating acceleration for the following functions Packet parsing, classification, and distribution (FMAN) Queue management for scheduling, packet sequencing and congestion management (QMAN) Hardware buffer management for buffer allocation and de-allocation (BMAN) Cryptography acceleration (SEC 5.2) at up to 40 Gbps SerDes 20 lanes at up to 5 Gbps Supports SGMII, XAUI, PCIe rev1.1/2.0, SATA Ethernet interfaces Two 10 Gbps Ethernet MACs Ten 1 Gbps Ethernet MACs High-speed peripheral interfaces Two PCI Express 2.0/3.0 controllers Additional peripheral interfaces Two serial ATA (SATA 2.0) controllers Two high-speed USB 2.0 controllers with integrated PHY Enhanced secure digital host controller (SD/MMC/eMMC) Enhanced serial peripheral interface (eSPI) Two I2C controllers Four UARTs Integrated flash controller supporting NAND and NOR flash DMA Dual four channel Support for hardware virtualization and partitioning enforcement Extra privileged level for hypervisor support QorIQ Trust Architecture 1.1 Secure boot, secure debug, tamper detection, volatile key storage Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/85xx: clear out TLB on bootScott Wood
Instead of just shooting down the entry that covers CCSR, clear out every TLB entry that isn't the one that we're executing out of. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23Add e6500 processor detectionKumar Gala
2012-08-23powerpc/mpc8xxx: use topology registers to calculate number of coresYork Sun
We have actual topology infomation to find out exactly which core is present. Calculate the number of cores if not specified. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/fsl-corenet: work around erratum A004510Scott Wood
Erratum A004510 says that under certain load conditions, modified cache lines can be discarded, causing data corruption. To work around this, several CCSR and DCSR register updates need to be made in a careful manner, so that there is no other transaction in corenet when the update is made. The update is made from a locked cacheline, with a delay before to flush any previous activity, and a delay after to flush the CCSR/DCSR update. We can't use a readback because that would be another corenet transaction, which is not allowed. We lock the subsequent cacheline to prevent it from being fetched while we're executing the previous cacheline. It is filled with nops so that a branch doesn't cause us to fetch another cacheline. Ordinarily we are running in a cache-inhibited mapping at this point, so we temporarily change that. We make it guarded so that we should never see a speculative load, and we never do an explicit load. Thus, only the I-cache should ever fill from this mapping, and we flush/unlock it afterward. Thus we should avoid problems from any potential cache aliasing between inhibited and non-inhibited mappings. NOTE that if PAMU is used with this patch, it will need to use a dedicated LAW as described in the erratum. This is the responsibility of the OS that sets up PAMU. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/85xx: remove support for the Freescale P3060Timur Tabi
The P3060 was cancelled before it went into production, so there's no point in supporting it. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/mpc8xxx: Remove P1015 and P1016 from CPU listYork Sun
P1015 is the same as P1011 and P1016 is the same as P1012 from software point of view. They have different packages but share SVRs. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-08powerpc/mpc85xx: Ignore E bit for BSC9130/1York Sun
Commit 48f6a5c34 removed E bit. BSC9130/1 were left out due to patch apply timing. Remove them now. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-06powerpc/mpc85xx: Ignore E bit for SVR_SOC_VER()York Sun
We don't care E bit of SVR in most cases. Clear E bit for SVR_SOC_VER(). This will simplify the coding. Use IS_E_PROCESSOR() to identify SoC with encryption. Remove all _E entries from SVR list and CPU list. Signed-off-by: York Sun <yorksun@freescale.com>
2012-07-06powerpc/mpc85xx:Add BSC9131/BSC9130/BSC9231 Processor SupportPrabhakar Kushwaha
- BSC9131 is integrated device that targets Femto base station market. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. - BSC9130 is exactly same as BSC9131 except that the max e500v2 core and DSP core frequencies are 800M(these are 1G in case of 9131). - BSC9231 is similar to BSC9131 except no MAPLE The BSC9131 SoC includes the following function and features: . Power Architecture subsystem including a e500 processor with 256-Kbyte shared L2 cache . StarCore SC3850 DSP subsystem with a 512-Kbyte private L2 cache . The Multi Accelerator Platform Engine for Femto BaseStation Baseband Processing (MAPLE-B2F) . A multi-standard baseband algorithm accelerator for Channel Decoding/Encoding, Fourier Transforms, UMTS chip rate processing, LTE UP/DL Channel processing, and CRC algorithms . Consists of accelerators for Convolution, Filtering, Turbo Encoding, Turbo Decoding, Viterbi decoding, Chiprate processing, and Matrix Inversion operations . DDR3/3L memory interface with 32-bit data width without ECC and 16-bit with ECC, up to 400-MHz clock/800 MHz data rate . Dedicated security engine featuring trusted boot . DMA controller . OCNDMA with four bidirectional channels . Interfaces . Two triple-speed Gigabit Ethernet controllers featuring network acceleration including IEEE 1588. v2 hardware support and virtualization (eTSEC) . eTSEC 1 supports RGMII/RMII . eTSEC 2 supports RGMII . High-speed USB 2.0 host and device controller with ULPI interface . Enhanced secure digital (SD/MMC) host controller (eSDHC) . Antenna interface controller (AIC), supporting three industry standard JESD207/three custom ADI RF interfaces (two dual port and one single port) and three MAXIM's MaxPHY serial interfaces . ADI lanes support both full duplex FDD support and half duplex TDD support . Universal Subscriber Identity Module (USIM) interface that facilitates communication to SIM cards or Eurochip pre-paid phone cards . TDM with one TDM port . Two DUART, four eSPI, and two I2C controllers . Integrated Flash memory controller (IFC) . TDM with 256 channels . GPIO . Sixteen 32-bit timers The DSP portion of the SoC consists of DSP core (SC3850) and various accelerators pertaining to DSP operations. This patch takes care of code pertaining to power side functionality only. Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Akhil Goyal <Akhil.Goyal@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Rajan Srivastava <rajan.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2011-11-08powerpc/85xx: Add support for Book-E MMU Arch v2.0Kumar Gala
A few of the config registers changed definition between MMU v1.0 and MMUv2.0. The new e6500 core from Freescale implements v2.0 of the architecture. Specifically, how we determine the size of TLB entries we support in the variable size (or TLBCAM/TLB1) array is specified in a new register (TLBnPS - TLB n Page size) instead of via TLBnCFG. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/p3060: Add SoC related support for P3060 platformShengzhou Liu
Add P3060 SoC specific information:cores setup, LIODN setup, etc The P3060 SoC combines six e500mc Power Architecture processor cores with high-performance datapath acceleration architecture(DPAA), CoreNet fabric infrastructure, as well as network and peripheral interfaces. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536Kumar Gala
The MPC8536 seems to use only 3 bits for the major revision field in the SVR rather than the 4 bits used by all other processors. The most significant bit is used as a mfg code on MPC8536. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/mp: add support for discontiguous coresTimur Tabi
Some SOCs have discontiguously-numbered cores, and so we can't determine the valid core numbers via the FRR register any more. We define CPU_TYPE_ENTRY_MASK to specify a discontiguous core mask, and helper functions to process the mask and enumerate over the set of valid cores. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/85xx: Cleanup handling of PVR detection for e500/e500mc/e5500Kumar Gala
At some point we broke the detection of e500v1 class cores. Fix that and simply the code to just utilize PVR_VER() to have a single case statement. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add P2041 processor supportKumar Gala
The P2041 is similar to P2040, however has a 10G port and backside L2 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-12PPC405EX CHIP_21 erratumSteven A. Falco
APM errata CHIP_21 for the 405EX/EXr (from the rev 1.09 document dated 4/27/11) states that rev D processors may wake up with the wrong feature set. This patch implements the APM-proposed workaround. To enable this patch for your board, add the appropriate define for your CPU to your board header file. See kilauea.h for more information. The following variants are supported: #define CONFIG_SYS_4xx_CHIP_21_405EX_NO_SECURITY #define CONFIG_SYS_4xx_CHIP_21_405EX_SECURITY #define CONFIG_SYS_4xx_CHIP_21_405EXr_NO_SECURITY #define CONFIG_SYS_4xx_CHIP_21_405EXr_SECURITY Please note that if you select the wrong define, your board will not boot, and JTAG will be required to recover. Tested on custom boards using: CONFIG_SYS_4xx_CHIP_21_405EX_NO_SECURITY <sfalco@harris.com> CONFIG_SYS_4xx_CHIP_21_405EX_SECURITY <eibach@gdsys.de> Signed-off-by: Steve Falco <sfalco@harris.com> Acked-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-04-04powerpc/85xx: Support for Freescale P1024/P1025 processorKumar Gala
Add Support for Freescale P1024/P1025 (dual core) and P1015/P1016 (single core) processors. P1024 is a variant of P1020 processor with a core frequency from 400Mhz to 667Mhz and comes in a 561-pin wirebond power-BGA P1025 is a variant of P1021 processor with a core frequency from 400Mhz to 667Mhz and comes in a 561-pin wirebond power-BGA P1015 is a variant of P1024 processor with single core and P1016 is a variant of P1025 processor with single core. Added comments in config_mpc85xx.h to denote single core versions of processors. Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add support for Freescale P1023/P1017 ProcessorsRoy Zang
Add P1023 (dual core) & P1017 (single core) specific information: * SERDES Table * Added P1023/P1017 to cpu_type_list and SVR list (fixed issue with P1013 not being sorted correctly). * Added P1023/P1027 to config_mpc85xx.h * Added new LAW type introduced on P1023/P1017 * Updated a few immap register/defines unique to P1023/P1017 Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/p2040: Add various p2040 specific informationKumar Gala
Add P2040 SoC specific information: * SERDES Table * Added p2040 to cpu_type_list and SVR list * Added number of LAWs for p2040 * Set CONFIG_MAX_CPUS to 4 for p2040 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Add Support for Freescale P1014 ProcessorPoonam Aggrwal
The P1014 is similar to the P1010 processor with the following differences: - 16bit DDR with ECC. (P1010 has 32bit DDR w/o ECC) - no eCAN interface. (P1010 has 2 eCAN interfaces) - Two SGMII interface (P1010 has 3 SGMII) - No secure boot Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Add Support for Freescale P1010 ProcessorPoonam Aggrwal
Key Features include of the P1010: * e500v2 core frequency operation of 500 to 800 MHz * Power consumption less than 5.0 W at 800 MHz core speed * Dual SATA 3 Gbps controllers with integrated PHY * Dual PCI Express controllers * Three 10/100/1000 Mbps enhanced triple-speed Ethernet controllers (eTSECs) * TCP/IP acceleration and classification capabilities * IEEE 1588 support * Lossless flow control * RGMII, SGMII * DDR3 with support for a 32-bit data interface (40 bits including ECC), up to 800 MHz data rate 32/16-bit DDR3 memory controller * Dedicated security engine featuring trusted boot * TDM interface * Dual controller area networks (FlexCAN) controller * SD/MMC card controller supporting booting from Flash cards * USB 2.0 host and device controller with an on-chip, high-speed PHY * Integrated Flash controller (IFC) * Power Management Controller (PMC) * Four-channel, general-purpose DMA controller * I2C controller * Serial peripheral interface (SPI) controller with master and slave support * System timers including a periodic interrupt timer, real-time clock, software watchdog timer, and four general-purpose timers * Dual DUARTs Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Fix wrong SVR value for MPC8567 and MPC8567E processorsPiergiorgio Beruto
Signed-off-by: Piergiorgio Beruto <piergiorgio.beruto@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-04APM821xx: Add CPU supportTirumala Marri
APM821XX is a new line of SoCs which are derivatives of PPC44X family of processors. This patch adds support of CPU, cache, tlb, 32k ocm, bootstraps, PLB and AHB bus. Signed-off-by: Tirumala R Marri <tmarri@apm.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-26powerpc/p4080: Add workaround for erratum CPU22Kumar Gala
2010-07-20powerpc/p3041: Add various p3041 related definesKumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p3041 to cpu_type_list and SVR list * Added number of LAWs for p3041 * Set CONFIG_MAX_CPUS to 4 for p3041 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/p5020: Add various p5020 related defines (and p5010)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p5020 & p5010 to cpu_type_list and SVR list * Added number of LAWs for p5020 * Set CONFIG_MAX_CPUS to 2 for p5020 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
