path: root/arch/powerpc/include/asm/iopin_8xx.h
2018-04-06powerpc: mpc8xx: Change CONFIG_8xx to CONFIG_MPC8xxChristophe Leroy
CONFIG_8xx doesn't mean much outside of arch/powerpc/ This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ... It also renames 8xx_immap.h to immap_8xx.h to be consistent with other file names. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-08powerpc, 8xx: Handle checkpatch errors and some of the warnings/checksChristophe Leroy
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-08powerpc, 8xx: Use IO accessors to access IO memoryChristophe Leroy
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2015-11-09Replace "extern inline" with "static inline"Måns Rullgård
A number of headers define functions as "extern inline" which is causing problems with gcc5. The reason is that starting with version 5.1, gcc defaults to the standard C99 semantics for the inline keyword. Under the traditional GNU inline semantics, an "extern inline" function would never create an external definition, the same as inline *without* extern in C99. In C99, and "extern inline" definition is simply an external definition with an inline hint. In short, the meanings of inline with and without extern are swapped between GNU and C99. The upshot is that all these definitions in header files create an external definition wherever those headers are included, resulting in multiple definition errors at link time. Changing all these functions to "static inline" fixes the problem since this works as desired in all gcc versions. Although the semantics are slightly different (a static inline definition may result in an actual function being emitted), it works as intended in practice. This patch also removes extern prototype declarations for the changed functions where they existed. Signed-off-by: Mans Rullgard <mans@mansr.com>
