path: root/arch/powerpc/include/asm/immap_85xx.h
2018-10-29powerpc: t1040: Correct RCW EC2 settingsBin Meng
Per T1040RM (Rev. 1, 08/2015), there are 2 issues with the RCW EC2 settings. - The value of FSL_CORENET_RCWSR13_EC2_FM1_GPIO is wrong and should be 0x04000000 (value of 1 in RCW bit [420:421]) - Value of 2/3 are reserved in RCW bit [420:421], hence there is no macro FSL_CORENET_RCWSR13_EC2_FM1_DTSEC5_MII. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Poonam Aggrwal <poonam.aggrwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-10-29powerpc: t1040: Correct RCW MAC2_GMII_SEL valueBin Meng
Per T1040RM (Rev. 1, 08/2015), the value of FSL_CORENET_RCWSR13_MAC2_GMII_SEL_ENET_PORT is wrong and should be 0x00000080 (bit 440 in the RCW). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Poonam Aggrwal <poonam.aggrwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-10drivers/misc: Share qbman init between archsAhmed Mansour
This patch adds changes necessary to move functionality present in PowerPC folders with ARM architectures that have DPAA1 QBMan hardware - Create new board/freescale/common/fsl_portals.c to house shared device tree fixups for DPAA1 devices with ARM and PowerPC cores - Add new header file to top includes directory to allow files in both architectures to grab the function prototypes - Port inhibit_portals() from PowerPC to ARM. This function is used in setup to disable interrupts on all QMan and BMan portals. It is needed because the interrupts are enabled by default for all portals including unused/uninitialised portals. When the kernel attempts to go to deep sleep the unused portals prevent it from doing so Signed-off-by: Ahmed Mansour <ahmed.mansour@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-15powerpc: t1024: Fix SRDS_MAX_LANES valuePaulo Zaneti
T1023 and T1024 have 4 SerDes lanes. Fix macro SRDS_MAX_LANES and use this macro instead of hard-coded value in t1024_serdes.c. Signed-off-by: Paulo Zaneti <paulo.zaneti@datacom.ind.br> Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04powerpc: mpc85xx: Remove variant SoCs T1020/T1022/T1013/T1014York Sun
Remove these SoCs from Kconfig because they don't have individual configuration. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4080: Drop configuration for T4080York Sun
There is no T4080 target. Drop related macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4160: Remove macro CONFIG_PPC_T4160York Sun
Use CONFIG_ARCH_T4160 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040: Remove macro CONFIG_PPC_T1040York Sun
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1023: Remove macro CONFIG_PPC_T1023York Sun
Replace CONFIG_PPC_T1023 with ARCH_T1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4420: Remove macro CONFIG_PPC_B4420York Sun
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up existing macros.
2016-11-23powerpc: B4860: Remove macro CONFIG_PPC_B4860York Sun
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040: Remove macro CONFIG_P5040York Sun
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P4080: Remove macro CONFIG_PPC_P4080York Sun
Replace CONFIG_PPC_P4080 with ARCH_P4080 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041: Remove macro CONFIG_PPC_P3041York Sun
Replace CONFIG_PPC_P3041 with ARCH_P3041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P2041: Remove macro CONFIG_PPC_P2041York Sun
Replace CONFIG_PPC_P2041 with ARCH_P2041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P2020: Remove macro CONFIG_P2020York Sun
Replace CONFIG_P2020 with ARCH_P2020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1025: Remove macro CONFIG_P1025York Sun
Replace CONFIG_P1025 with ARCH_P1025 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1021: Remove macro CONFIG_P1021York Sun
Replace CONFIG_P1021 with ARCH_P1021 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1017: Drop configuration for P1017York Sun
P1017 is a single-core version of P1023. There is no P1017 target configured. Drop related macros. P1017 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1014: Drop configuration for P1014York Sun
P1014 is a variant of P1010. There is no P1014 target configured. Drop related macros. P1014 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1013: Drop configuration for P1013York Sun
P1013 is a single-core version of P1022. There is no P1022 target configured. Drop related macros. P1022 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1012: Drop configuration for P1012York Sun
P1012 is a single-core version of P1021. There is no P1012 target configured. Drop related macros. P1012 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1023: Remove macro CONFIG_P1023York Sun
Replace CONFIG_P1023 with ARCH_P1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1022: Remove macro CONFIG_P1022York Sun
Replace CONFIG_P1022 with ARCH_P1022 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1010: Remove macro CONFIG_P1010York Sun
Replace CONFIG_P1010 with ARCH_P1010 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8572: Remove macro CONFIG_MPC8572York Sun
Replace CONFIG_MPC8572 with ARCH_MPC8572 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8569: Remove macro CONFIG_MPC8569York Sun
Replace CONFIG_MPC8569 with ARCH_MPC8569 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8568: Remove macro CONFIG_MPC8568York Sun
Replace CONFIG_MPC8568 with ARCH_MPC8568 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8555: Remove macro CONFIG_MPC8555York Sun
Replace CONFIG_MPC8555 with ARCH_MPC8555 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: mpc8541: Remove macro CONFIG_MPC8541York Sun
Replace CONFIG_MPC8541 with ARCH_MPC8541 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: mpc8540: Remove macro CONFIG_MPC8540York Sun
Replace CONFIG_MPC8540 with ARCH_MPC8540 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8536: Move CONFIG_MPC8536 to Kconfig optionYork Sun
Replace CONFIG_MPC8536 with ARCH_MPC8536 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: C29X: Move CONFIG_PPC_C29X to Kconfig optionYork Sun
Replace CONFIG_PPC_C29X with ARCH_C29X in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: BSC9131/2: Move CONFIG_BSC9131/2 to Kconfig optionsYork Sun
Replace CONFIG_BSC9131, CONFIG_BSC9132 with ARCH_BSC9131, ARCH_BSC9132 Kconfig options. Also drop #ifdef in BSC9131RDB.h since it is redundant. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8548: Move CONFIG_MPC8548 to Kconfig optionYork Sun
Replace CONFIG_MPC8548 with ARCH_MPC8548 in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-28mpc85xx: powerpc: usb: Enable Usb phy initialisation settings for P1010Sriram Dash
CONFIG_SYS_FSL_USB1_PHY_ENABLE is set and the USB Phy offset are set to enable the initial setting of Usb Phy for P1010. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-08-02powerpc/mpc85xx: Update erratum workaround for A006379York Sun
Update erratum workaround for A006379 to set register CPCHDBCR0 with value 0x001e0000, replacing the old value 0x003c0000. Signed-off-by: York Sun <york.sun@nxp.com> Reported-by: Dave Liu <dave.liu@nxp.com>
2016-06-03dm: gpio: Add driver for MPC85XX GPIO controllermario.six@gdsys.cc
This patch adds a driver for the built-in GPIO controller of the MPC85XX SoC (probably supporting other PowerQUICC III SoCs as well). Each GPIO bank is identified by its own entry in the device tree, i.e. gpio-controller@fc00 { #gpio-cells = <2>; compatible = "fsl,pq3-gpio"; reg = <0xfc00 0x100> } By default, each bank is assumed to have 32 GPIOs, but the ngpios setting is honored, so the number of GPIOs for each bank in configurable to match the actual GPIO count of the SoC (e.g. the 32/32/23 banks of the P1022 SoC). The usual functions of GPIO drivers (setting input/output mode and output value setting) are supported. The driver has been tested on MPC85XX, but it is likely that other PowerQUICC III devices will work as well. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17dm: fsl_i2c: Rename I2C register structuremario.six@gdsys.cc
2016-02-24powerpc/SECURE_BOOT: Add PAMU driverAneesh Bansal
PAMU driver basic support for usage in Secure Boot. In secure boot PAMU is not in bypass mode. Hence to use any peripheral (SEC Job ring in our case), PAMU has to be configured. The patch reverts commit 7cad2e38d61e27ea59fb7944f7e647e97ef292d3. The Header file pamu.h and few functions in driver have been derived from Freescale Libos. Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: create function to determine boot modeAneesh Bansal
A function is created to detrmine if the boot mode is secure or non-secure for differnt SoC's. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-29net: Move some header files to include/Shaohui Xie
The fsl_dtsec.h & fsl_tgec.h & fsl_fman.h can be shared on both ARM and PPC, move it out of ppc to include/, and change the path in drivers accordingly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-05SECURE_BOOT : enable esbc_validate command for powerpc and arm platforms.gaurav rana
esbc_validate command uses various IP Blocks: Security Monitor, CAAM block and SFP registers. Hence the respective CONFIG's are enabled. Apart from these CONFIG_SHA_PROG_HW_ACCEL and CONFIG_RSA are also enabled. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-05fsl_sfp : Move ccsr_sfp_regs definition to common includegaurav rana
Freescale sfp has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the CCSR defintion of sfp_regs to common include. This patch also defines ccsr_sfp_regs definition for newer versions of SFP. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
