path: root/arch/powerpc/include/asm/cache.h
2014-07-22mpc85xx/t104x: Enable L2 and CPC cache when resumeTang Yuantian
When resume from deep sleep, uboot needs to enable L2 and CPC cache, or they would be keeping unusable in kernel because kernel didn't enble or initialized them. This patch didn't change the existing L2 cache enabling code, just put them in a function. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-10-15ppc4xx: Remove IOP480 supportStefan Roese
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2 boards that are not actively maintained, lets remove support for it completely. This way the ppc4xx code will get a bit cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marex@denx.de>
2011-10-23powerpc: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Acked-by: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de>
