path: root/arch/powerpc/cpu
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/8xxx: query feature reporting register for num cores on unknown cpusKim Phillips
doing so helps avant garde users, such as those using simulators that allow users to configure the number of cores, so as to not have to manually adjust u-boot sources. h/w should also be reliably setting FRR NCPU in the future. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/8xxx: Improvement to DDR parametersyork
Changes for P2020DS DDR applies to other 8xxx platform Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enable DDR3 RDIMM supportyork
Enabled registered DIMMs using data from SPD. RDIMMs have registers which need to be configured before using. The register configuration words are stored in SPD byte 60~116 (JEDEC standard No.21-C). Software should read those RCWs and put into DDR controller before initialization. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enabled address hashing for 85xxyork
For 85xx silicon which supports address hashing, it can be activated by hwconfig. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enable quad-rank DIMMs.york
Previous code presumes each DIMM has up to two rank (chip select). Newer DDR controller supports up to four chip select on one DIMM. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Fix bug in memctrl interleaving & bank interleaving on cs0~cs4york
Verified on MPC8641HPCN with four DDR2 dimms. Each dimm has dual rank with 512MB each rank. Also check dimm size and rank size for memory controller interleaving Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enabled hwconfig for memory interleavingKumar Gala
Replace environmental variables memctl_intlv_ctl and ba_intlv_ctl with hwconfig parameters. The syntax is setenv hwconfig "fsl_ddr:ctlr_intlv=<mode>,bank_intlv=<mode>" The mode values for memory controller interleaving are cacheline page bank superbank The mode values for bank interleaving are cs0_cs1 cs2_cs3 cs0_cs1_and_cs2_cs3 cs0_cs1_cs2_cs3 Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/p4080: Add workaround for erratum CPU22Kumar Gala
2010-07-26powerpc/p4080: Add workaround for errata SERDES8Kumar Gala
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/p4080: Add support for initializing SERDESKumar Gala
Add support for initializing the SERDES blocks on CoreNet style QoriQ devices and the p4080 specific SERDES tables to know which actual componetns are enabled. Additionally, split out the Frame Manger (FMAN) into its specific ethernet ports instead of gross level of the full FMAN. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/85xx: Add support to initialize LIODN registers and portalsKumar Gala
On the new QorIQ/CoreNet based platforms we need to initialize the "portals" as access into the Data Path subystem as well as Logical IO Device Numbers (LIODN) that are used for the IOMMU (PAMU). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/p4080: Add support for CPC(Corenet platform cache) on CoreNet platformsKumar Gala
The CoreNet style platforms can have a L3 cache that fronts the memory controllers. Enable that cache as well as add information into the device tree about it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/85xx: Move INIT_RAM_ADDR physical address to 36-bit spaceyork
If 36-bit physical address is used, move the INIT_RAM_ADDR to higher address. This frees the low 4GB address space for better use. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-07-23ppc4xx: Add ECC status info to machine-check exception for IBM DDR2 coreStefan Roese
2010-07-23ppc4xx: Add "ecctest" command to test/simulate ECC errorsStefan Roese
This patch adds the "ecctest" command to test and simulate ECC errors (single bit and/or double bit) while running from SDRAM. Currently only the IBM DDR2 controller is supported (405EX, 440SP(e), 460EX/GT). This is done by copying and calling functions, modifying the SDRAM controller operation mode, in internal SRAM/OCM. For correctable ECC errors (single bit) only the status will be printed since the DDR2 controller doesn't provide the faulting address: => ecctest 1000000 1 Using address 01000000 for 1 bit ECC error injection ECC: Correctable error Uncorrectable ECC errors (double bit) will also display the faulting address: => ecctest 1000000 2 Using address 01000000 for 2 bit ECC error injection ECC: Uncorrectable error at 0x0001000000 To enable this "ecctest" function you need to define CONFIG_CMD_ECCTEST in the board config header. Tested on katmai and t3corp. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-23ppc4xx: DDR/ECC: Use correct macros to clear error statusStefan Roese
Use the correct macro instead of the hardcoded 0x4c to clear the ECC status in the 440/460 DDR(2) error status register after ECC initialization. Also the non-440 parts (405EX(r) right now) and the IBM DDR PPC variants (440GX) use a different registers to clear this error status. Use the correct ones. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-23ppc4xx: Add CONFIG_DDR_RFDC_FIXED to allow board specific RFDC valuesStefan Roese
Using this define, a board can define an opimized RFDC value and use the auto calibration code to "tune" the remaining DDR2 controller calibration register. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-21powerpc/85xx: Rework P1022 SERDES is_serdes_configured supportKumar Gala
Move serdes init until after we are in ram so we can keep track of a global static protocal map for the particular serdes config we are in. This makes is_serdes_configured() much simplier and not constantly reading registers to determine if a given device is enabled based on the protocol. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-21powerpc/85xx: Rework MPC8536 SERDES is_serdes_configured supportKumar Gala
2010-07-20powerpc/p3041: Add various p3041 related definesKumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p3041 to cpu_type_list and SVR list * Added number of LAWs for p3041 * Set CONFIG_MAX_CPUS to 4 for p3041 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/p5020: Add various p5020 related defines (and p5010)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p5020 & p5010 to cpu_type_list and SVR list * Added number of LAWs for p5020 * Set CONFIG_MAX_CPUS to 2 for p5020 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/mpc85xx: Report FMAN # to match user manualEmil Medve
The user manual refers to FMAN1 and FMAN2 not 0 and 1. Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/p4080: Add setting of clock-frequency for clockgen nodeKumar Gala
On QorIQ CoreNet based devices we have a global clocking block. We want to keep track of SYSCLK frequency as it is what is used to derive all other frequencies in the SoC Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Use fdt_node_offset_by_compat_reg for clock-frequency updatesKumar Gala
Move to using fdt_node_offset_by_compat_reg to find the node offsets we want to update instead of using aliases. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-17Drop support for GTH boardWolfgang Denk
The board maintainer states: The GTH board is obsolete and has not been manufactured for several years. To my knowledge, no recent U-Boot build has been tested on that card. So drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Acked-by: Thomas Lange<thomas@corelatus.se>
2010-07-16powerpc/85xx: Move p1022ds slot code into board fileKumar Gala
The code to map SERDES configs to slot names is board specific and not chip specific. Thus it should live in board/freescale/p1022ds/ and not in arch/powerpc/cpu/. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/85xx: Add command to report errata workaroundsKumar Gala
Add 'errata' command to report what errata we workaround. Report workaround for erratum SATA-A001 on P1022/P1013. Also sorted the CONFIG_CMD_* list. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc: add support for the Freescale P1022DS reference boardTimur Tabi
Specifics: 1) 36-bit only 2) Booting from NOR flash only 3) Environment stored in NOR flash only 4) No SPI support 5) No DIU support Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/85xx: Add recognition of e5500 coreKumar Gala
2010-07-16powerpc 83xx/85xx: Merge lbc upmconfig codeBecky Bruce
Each platform had its own version of the upmconfig, despite the init process being identical. Now that we have a spot for common lbc code, create a common upmconfig() there. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add print_tlbcam() functionBecky Bruce
This dumps out the contents of TLB1 on 85xx-based systems. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: tlb.c cleanupsBecky Bruce
Extract the operation to read a tlb into a function - we will need this later to print out the tlbs, and there's no point in duplicating the code. Create a TSIZE_TO_BYTES macro to deal with the conversion from the MAS field to an actual size instead of duplicating this in code. There are a few misc other minor cleanups. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/8xxx: Add is_core_disabled to remove disabled cores from dtbKumar Gala
If we explicitly disabled a core remove it from the dtb we pass on to the kernel. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc8xxx: Remove cpu-handles for cpus we deleteKumar Gala
We may have cpu-handles pointing to the cpu nodes we delete. If so we should delete the handles as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/8xxx: Add base support for the SEC4Kim Phillips
2010-07-16powerpc/8xxx: Distinguish between incompatible SEC h/w typesKim Phillips
CONFIG_SYS_FSL_SEC_COMPAT is set to 2 for the SEC 2.x and SEC 3.x. Parts with newer SEC h/w versions will increment the number to accomodate incompatible code changes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16fdt: move fsl specific code from common fdt area to mpc8xxx/fdt.cKim Phillips
2010-07-09mpc8308: support for Freescale MPC8308 cpuIlya Yanok
This patch adds basic support for Freescale MPC8308 CPU. Serial ports, NOR flash and integrated Ethernet controllers are supported. PCI Express is also supported. eSDHC, NAND and USB may work but aren't tested (using ULPI PHY requires additional patch). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-01ppc4xx: Cleanup Boot/FLASH TLB reassignment for PPC440/460Stefan Roese
Background Info: Some PPC440/460 boards have caches enabled in the Boot/FLASH TLB (via init.S) to speed up the boot process. In relocate_code (start.S) the cache inhibit attribute for this TLB is set to disable cache. This is needed for the CFI FLASH driver. This patch now cleans this code up: - CONFIG_SYS_TLB_FOR_BOOT_FLASH is defined to 0 (default TLB) if not defined in the top of this file. This way, we can remove an ugly #ifdef in this code. - Replace complex "#if defined(CONFIG_440EP) || defined(CONFIG_GR)..." statement with "#if defined(CONFIG_440)". - Remove unnecessary cache invalidate calls resulting in faster bootup. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-01ppc4xx: DDR2: Complete RDSS configuration on non-SPD based boardsStefan Roese
As described in item #10 of the SDRAM initialization (chapter 22.2.9 of the PPC460EX/EXr/GT users manual), RDSS may need to be adjusted. The code for this is now factored out and executed for non-SPD based boards as well. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-01ppc4xx: Enable overwriting of default scan window for IBM DDR2 controllerStefan Roese
This patch makes it possible to overwrite the default auto-calibration scan window (SDRAM_WRDTR.[WDTR], SDRAM_CLKTR.[CKTR] values) with board specific values. The parameters of the weak default function are corrected as well. This way we don't need the casts any more. This feature will be used by an upcoming PPC460GT board port. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-01ppc4xx: Enable PCIe support without PCI support on PPC440/460Stefan Roese
By not defining CONFIG_SYS_PCI_MASTER_INIT and CONFIG_SYS_PCI_TARGET_INIT, PCI support (host and adapter) will not be enabled. But it's still possible to use the U-Boot PCI infrastructure for the PCIe ports. This configuration option is needed for a new 460GT board, which uses PCIe but has PCI disabled. Signed-off-by: Stefan Roese <sr@denx.de>
