path: root/arch/powerpc/cpu/mpc85xx/p2041_serdes.c
2013-06-20powerpc: mpc85xx/mpc86xx: Fix off-by-one boundary checking with ARRAY_SIZEAxel Lin
If a variable is used as array subscript, it's valid value range is 0 ... ARRAY_SIZE -1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-06powerpc/mpc85xx: Ignore E bit for SVR_SOC_VER()York Sun
We don't care E bit of SVR in most cases. Clear E bit for SVR_SOC_VER(). This will simplify the coding. Use IS_E_PROCESSOR() to identify SoC with encryption. Remove all _E entries from SVR list and CPU list. Signed-off-by: York Sun <yorksun@freescale.com>
2011-07-29powerpc/85xx: Add support for P2041[e] XAUI in SERDESKumar Gala
We add XAUI_FM1 into the SERDES tables for P2041[e] devices. However for the P2040[e] devices that dont support XAUI we handle this at runtime via SVR checks. If we are on a P2040[e] device the SERDES functions will behave as follows: is_serdes_prtcl_valid() will always report invalid if prtcl passed in is XAUI_FM1. serdes_get_prtcl() will report NONE if the prtcl in the table is set to XAUI_FM1. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/85xx: Rename P2040 id & SERDES to P2041Kumar Gala
P2041 is the superset part that covers both P2040 & P2041. The only difference between the two devices is that P2041 supports 10g/XAUI and has an L2 cache. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
