Only some chips have four SerDes banks, so don't define lanes for a bank
that doesn't exist.
Signed-off-by: Timur Tabi <timur@tabi.org>
Signed-off-by: Andy Fleming <afleming@freescale.com>
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
The documented work-around for P4080 erratum SERDES-9 has been updated.
It is now compatible with the work-around for erratum A-4580.
This requires adding a few bitfield macros for the BnTTLCRy0 register.
fsl_corenet_serdes.c:485:6: warning: symbol '__soc_serdes_init' was not declared. Should it be static?
cpu_init.c:185:6: warning: symbol 'invalidate_cpc' was not declared. Should it be static?
bcsr.c:28:27: warning: non-ANSI function declaration of function 'enable_8568mds_duart'
bcsr.c:39:33: warning: non-ANSI function declaration of function 'enable_8568mds_flash_write'
bcsr.c:46:34: warning: non-ANSI function declaration of function 'disable_8568mds_flash_write'
bcsr.c:53:29: warning: non-ANSI function declaration of function 'enable_8568mds_qe_mdio'
bcsr.c:28:33: warning: non-ANSI function declaration of function 'enable_8569mds_flash_write'
bcsr.c:33:34: warning: non-ANSI function declaration of function 'disable_8569mds_flash_write'
bcsr.c:38:28: warning: non-ANSI function declaration of function 'enable_8569mds_qe_uec'
bcsr.c:63:47: warning: non-ANSI function declaration of function 'disable_8569mds_brd_eeprom_write_protect'
ngpixis.c:245:1: error: directive in argument list
ngpixis.c:247:1: error: directive in argument list
Add support for the Freescale P5040 SOC, which is similar to the P5020.
Features of the P5040 are:
Four P5040 single-threaded e5500 cores built
Up to 2.4 GHz with 64-bit ISA support
Three levels of instruction: user, supervisor, hypervisor
CoreNet platform cache (CPC)
2.0 MB configures as dual 1 MB blocks hierarchical interconnect fabric
Two 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving
support Up to 1600MT/s
Memory pre-fetch engine
DPAA incorporating acceleration for the following functions
Packet parsing, classification, and distribution (FMAN)
Queue management for scheduling, packet sequencing and
congestion management (QMAN)
Hardware buffer management for buffer allocation and
de-allocation (BMAN)
Cryptography acceleration (SEC 5.2) at up to 40 Gbps SerDes
20 lanes at up to 5 Gbps
Supports SGMII, XAUI, PCIe rev1.1/2.0, SATA Ethernet interfaces
Two 10 Gbps Ethernet MACs
Ten 1 Gbps Ethernet MACs
High-speed peripheral interfaces
Two PCI Express 2.0/3.0 controllers
Additional peripheral interfaces
Two serial ATA (SATA 2.0) controllers
Two high-speed USB 2.0 controllers with integrated PHY
Enhanced secure digital host controller (SD/MMC/eMMC)
Enhanced serial peripheral interface (eSPI)
Two I2C controllers
Four UARTs
Integrated flash controller supporting NAND and NOR flash
DMA
Dual four channel
Support for hardware virtualization and partitioning enforcement
Extra privileged level for hypervisor support
QorIQ Trust Architecture 1.1
Secure boot, secure debug, tamper detection, volatile key storage
Before proper environment is setup, we extract hwconfig and put it into a
buffer with size HWCONFIG_BUFFER_SIZE. We need to enlarge the buffer to
accommodate longer string. Since this macro is used in multiple files, we
move it into arch/powerpc/include/asm/config.h.
Unlike previous SOCs, the Freescale P5040 has a fifth DTSEC on the second
Fman, so add the Fman and SerDes macros for that DTSEC.
Fix:
fsl_corenet_serdes.c: In function 'fsl_serdes_init':
fsl_corenet_serdes.c:511:8: warning: variable 'buf' set but not used [-Wunused-but-set-variable]
fsl_corenet_serdes.c:498:18: warning: variable 'lane_prtcl' set but not used [-Wunused-but-set-variable]
The work-around for P4080 erratum SERDES9 says that the SERDES receiver
lanes should be reset after the XAUI starts tranmitting alignment signals.
Add P3060 SoC specific information:cores setup, LIODN setup, etc
The P3060 SoC combines six e500mc Power Architecture processor cores with
high-performance datapath acceleration architecture(DPAA), CoreNet fabric
infrastructure, as well as network and peripheral interfaces.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Some P4080 rev1 errata work-arounds, notably erratum SERDES4, required a
bank soft-reset after the bank was configured and enabled, even though
enabling a bank causes it to reset. Because the reset was required for
multiple errata, it was not properly enclosed in an #ifdef, and so was
not removed with all the other rev1 errata work-arounds.
Erratum SERDES-8 says that the clocks for bank 3 needs to be enabled if
bank 2 is enabled, but this was not being done for SERDES protocols 0xF
and 0x10. The bank reset also happened to enable bank 3 (apparently an
undocumented feature). Simply removing the reset breaks these two
protocols.
It turns out that every time we call enable_bank(), we do want at least
one lane of the bank enabled, either because the bank is supposed to be
enabled, or because we need the clock from that bank enabled.
For erratum SERDES-A001, we don't want to modify srds_lpd_b[] when we
call enable_bank(), because that array is used elsewhere to determine if
the bank is available.
Note that the side effect of these changes is that the work-arounds for
these two errata are now linked. Specifically, if SERDES-A001 is
enabled, then we need SERDES-8 enabled as well.
Because this was the only SERDES bank soft-reset, there is no need to
implement a work-around for erratum SERDES-A003.
Also fix an off-by-one error in a printf().
Acked-by: Ed Swarthout <swarthou@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Bank powerdown through RCW[SRDS_LPD_Bn] for XAUI on FM2 and SGMII on FM1
are swapped.
Erratum SERDES-A001 says that if bank two is kept disabled and after bank
three is enabled, then the PLL for bank three won't lock properly. The
work-around is to enable and then disable bank two after bank three is
enabled.
Part of the SERDES9 erratum work-around is to set some bits in the SerDes
TTLCR0 register for lanes configured as XAUI, SGMII, SRIO, or AURORA. The
current code does this only for XAUI, so extend it to the other protocols.
The work-around for P4080 erratum SERDES-8 requires all lanes of banks two
and three to be disabled (powered down) in the RCW. Display a warning
message if this is not the case.
SerDes PLL bandwidth default setting is incorrect when no lanes are
configured as PCI Express.
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Rework and add some new APIs to the fsl_corenet_serdes code for use by
erratum and drivers.
* Rename serdes_get_bank() to serdes_get_bank_by_lane()
* Add serdes_get_first_lane returns which SERDES lane is used by device
Remove the SERDES8 erratum work-around code that only applied to P4080
rev1, which is not supported by this version of U-Boot.
Hwconfig is called before relocating. Use the new hwconfig APIs.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Add support for initializing the SERDES blocks on CoreNet style QoriQ
devices and the p4080 specific SERDES tables to know which actual
componetns are enabled.
Additionally, split out the Frame Manger (FMAN) into its specific ethernet
ports instead of gross level of the full FMAN.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
