path: root/arch/powerpc/cpu/mpc85xx/ether_fcc.c
2012-05-22arch/powerpc/cpu/mpc85xx/ether_fcc.c: Fix compile warningJoe Hershberger
Fix this: ether_fcc.c: In function 'fec_initialize': ether_fcc.c:453:15: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
