path: root/arch/powerpc/cpu/mpc85xx/cpu.c
2010-10-20Add memory test feature for mpc85xx POST.York Sun
The memory test is performed after DDR initialization when U-boot stills runs in flash and cache. On recent mpc85xx platforms, the total memory can be more than 2GB. To cover whole memory, it needs be mapped 2GB at a time using a sliding TLB window. After the testing, DDR is remapped with up to 2GB memory from the lowest address as normal. If memory test fails, DDR DIMM SPD and DDR controller registers are dumped for further debugging. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-19powerpc/8xxx: share PIC defines among 85xx and 86xxKim Phillips
fixes breakeage introduced by commit a37c36f4e70bada297f281b0e542539ad43e50f6 "powerpc/8xxx: query feature reporting register for num cores on unknown cpus" Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/mpc85xx: Report FMAN # to match user manualEmil Medve
The user manual refers to FMAN1 and FMAN2 not 0 and 1. Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16powerpc/85xx: Add recognition of e5500 coreKumar Gala
2010-07-16powerpc 83xx/85xx: Merge lbc upmconfig codeBecky Bruce
Each platform had its own version of the upmconfig, despite the init process being identical. Now that we have a spot for common lbc code, create a common upmconfig() there. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-2685xx: Fix compile warningKumar Gala
cpu.c: In function 'checkcpu': cpu.c:47: warning: unused variable 'gur' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-26ppc/p4080: Fix synchronous frequency calculationsSrikanth Srinivasan
When DDR is in synchronous mode, the existing code assigns sysclk frequency to DDR frequency. It should be synchronous with the platform frequency. CPU frequency is based on platform frequency in synchronous mode. Also fix: * Fixes the bit mask for DDR_SYNC (RCWSR5[184]) * Corrects the detection of synchronous mode. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
