path: root/arch/powerpc/cpu/mpc85xx/commproc.c
2013-02-04ppc: Move dp_alloc_base, dp_alloc_top to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01ppc: Move brg_clk to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
