features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Do not enforce drivers to provide empty video_set_lut()
if they do not implement indexed color (8 bpp) frame
buffer support. Add default function to the cfb_console
driver and remove empty video_set_lut() functions.
Match style we use almost everywhere else
Add common post_word_load/post_word_store routines
for all mpc5121 boards. pdm360ng board POST support
added by subsequent patch needs them.
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh.
Signed-off-by: Michael Weiss <michael.weiss@ifm.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Configure CONFIG_SYS_MAX_RAM_SIZE address range in
DDR Local Access Window and determine the RAM size.
Fix DDR LAW afterwards using detected RAM size.
Extend mpc512x serial driver to support multiple PSC ports.
Subsequent patches for PDM360NG board support make use of this
functionality by defining CONFIG_SERIAL_MULTI in the board config
file. Additionally the used PSC devices are specified by defining
e.g. CONFIG_SYS_PSC1, CONFIG_SYS_PSC4 and CONFIG_SYS_PSC6.
Support for PSC devices other than 1, 3, 4 and 6 is not added
by this patch because these aren't used currently. In the future
it can be easily added using DECLARE_PSC_SERIAL_FUNCTIONS(N) and
INIT_PSC_SERIAL_STRUCTURE(N) macros in cpu/mpc512x/serial.c.
Additionally you have to add code for registering added
devices in serial_initialize() in common/serial.c.
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
