path: root/arch/powerpc/cpu/mpc512x/iim.c
2013-04-28mpc: iim: Switch to common fsl_iimBenoît Thébaudeau
Make all mpc512x code point to the new common fsl_iim driver, and remove the former mpc512x-specific iim driver. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
