path: root/arch/openrisc
2016-01-25openrisc: Fix build errorsBin Meng
With kernel.org toolchain, it reports: CC arch/openrisc/lib/board.o arch/openrisc/lib/board.c:56:2: error: 'console_init_f' undeclared here (not in a function) arch/openrisc/lib/board.c: In function 'board_init': arch/openrisc/lib/board.c:120:2: warning: implicit declaration of function 'console_init_r' make[1]: *** [arch/openrisc/lib/board.o] Error 1 make: *** [arch/openrisc/lib] Error 2 Include console.h will fix this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12openrisc: updating build tools naming conventionGuillaume REMBERT
Dear u-boot community, I just made a small change on the openrisc-generic platform configuration to take in account the new naming convention (or1k instead of or32, so the build process gets fine). Could you take care to review and approve the following patch, please? Kind regards,
2015-11-05openrisc: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-06-05openrisc: fix relocation codeFranck Jullien
The relocation code can now relocate from anywhere to the RAM. The old code assumed that the binary was copied to the RAM by some PBL and then it just relocated the .text section from the loaded address to the linked address. Now, it first checks if vectors are somewhere else than the linked address. If yes, there are copied to address 0 (or to the exception vector base address if register EVBAR is present). Then, the .text section is relocated from its current location to the RAM. Signed-off-by: Franck Jullien <franck.jullien@gmail.com>
2014-06-05openrisc: update SPR registers definitionFranck Jullien
The OpenRISC architecture specification v1.0 defines new SPR registers. This patch adds registers definition for group 0 and update bit definitions for the CPU configuration register. Signed-off-by: Franck Jullien <franck.jullien@gmail.com>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-03-12kbuild: delete redundant LDSCRIPT definitionMasahiro Yamada
$(SRCTREE)/$(CPUDIR)/u-boot.lds is our default location of arch-specific linker script. Remove redundant definitions in arch/{arc,microblaze,openrisc}/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Acked-by: Michal Simek <monstr@monstr.eu>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31openrisc: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26Clarify bootm OS argumentsSimon Glass
At present the arguments to bootm are processed in a somewhat confusing way. Sub-functions must know how many arguments their calling functions have processed, and the OS boot function must also have this information. Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in the same way. Adjust the code so that arguments are removed from the list before calling a sub-function. This means that all functions can know that argv[0] is the first argument of which they need to take notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-10openrisc: move board linker script(s) to a common in cpu/Stefan Kristiansson
Unifies the openrisc boards linker scripts into a common one. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04openrisc: Use generic global_dataSimon Glass
Move openrisc over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-19openrisc: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-02openrisc/bitops: add hweightX definesStefan Kristiansson
2012-10-02openrisc: implement get_ticks and get_tbclkStefan Kristiansson
2012-08-09openrisc: Work around potential relocation issuesJulius Baxter
When reset code is in flash, the jump instructions emitted by the compiler are relative instead of absolute jumps. A fix to the reset code to make correct jumps to the beginning of code relocated to RAM have also been added. Signed-off-by: Julius Baxter <juliusbaxter@gmail.com>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-01-13openrisc: Add library functionsStefan Kristiansson
2012-01-13openrisc: Add cpu filesStefan Kristiansson
2012-01-13openrisc: Add architecture header filesStefan Kristiansson
