path: root/arch/openrisc/config.mk
2015-11-12openrisc: updating build tools naming conventionGuillaume REMBERT
Dear u-boot community, I just made a small change on the openrisc-generic platform configuration to take in account the new naming convention (or1k instead of or32, so the build process gets fine). Could you take care to review and approve the following patch, please? Kind regards,
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-12kbuild: delete redundant LDSCRIPT definitionMasahiro Yamada
$(SRCTREE)/$(CPUDIR)/u-boot.lds is our default location of arch-specific linker script. Remove redundant definitions in arch/{arc,microblaze,openrisc}/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Acked-by: Michal Simek <monstr@monstr.eu>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-05-10openrisc: move board linker script(s) to a common in cpu/Stefan Kristiansson
Unifies the openrisc boards linker scripts into a common one. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2012-01-13openrisc: Add cpu filesStefan Kristiansson
