path: root/arch/nios2
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop image.h from common headerSimon Glass
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move relocate_code() to init.hSimon Glass
This is an init function so move it out of the common header. Avoid using the typedef so that we don't have to include the global_data header file. Also tidy up the function style in comments while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move interrupt functions into a new headerSimon Glass
These functions do not use driver model but are fairly widely used in U-Boot. But it is not clear that they will use driver model anytime soon, so we don't want to label them as 'legacy'. Move them to a new irq_func.h header file. Avoid the name 'irq.h' since it is widely used in U-Boot already. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02arm: powerpc: Tidy up code style for interrupt functionsSimon Glass
Remove the unwanted space before the bracket. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move some cache and MMU functions out of common.hSimon Glass
These functions belong in cpu_func.h. Another option would be cache.h but that code uses driver model and we have not moved these cache functions to use driver model. Since they are CPU-related it seems reasonable to put them here. Move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-06-18.gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignoreMasahiro Yamada
Follow Linux commit 10b62a2f785a (".gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignore"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-15nios2: Define PLATFORM__CLEAR_BIT for generic_clear_bit()Bryan O'Donoghue
nios2 bitops.h provides a __clear_bit() but does not define PLATFORM__CLEAR_BIT as a result generic_clear_bit() is used instead of the architecturally provided __clear_bit(). This patch defines PLATFORM__CLEAR_BIT which means that __clear_bit() in nios2 bitops.h will be called whenever generic_clear_bit() is called - as opposed to the default cross-platform generic_clear_bit(). Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie> Cc: Thomas Chou <thomas@wytron.com.tw>
2018-05-15nios2: Define PLATFORM__SET_BIT for generic_set_bit()Bryan O'Donoghue
nios2 bitops.h provides a __set_bit() but does not define PLATFORM__SET_BIT as a result generic_set_bit() is used instead of the architecturally provided __set_bit(). This patch defines PLATFORM__SET_BIT which means that __set_bit() in nios2 bitops.h will be called whenever generic_set_bit() is called - as opposed to the default cross-platform generic_set_bit(). Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie> Cc: Thomas Chou <thomas@wytron.com.tw>
2017-11-17nios2: 10m50: Add CPU pre-relocation in device treeGan, Yau Wai
Tag CPU with dm-pre-reloc to enable driver before relocation. Signed-off-by: Gan, Yau Wai <yau.wai.gan@intel.com> Cc: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2017-10-02nios2: Use asm-generic/io.hPaul Burton
Convert the nios2 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As nios2 actually performs non-identity mapping between physical & virtual addresses we can't simply make use of the generic functions, with the exception of being able to drop our no-op unmap_physmem() and definitions of unused map flags. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Thomas Chou <thomas@wytron.com.tw>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-01fdt: Move fdt_fixup_ethernet to a common placeTom Rini
With 3f66149d9fb4 we no longer have a common call fdt_fixup_ethernet. This was fine to do on PowerPC as they largely had calls already in ft_cpu_fixup. On ARM however we largely relied on this call. Rather than introduce a large number of changes to ft_cpu_fixup / ft_board_fixup we recognize that this is a common enough call that we should be doing it in a central location. Do it early enough that we can do any further updates in ft_cpu_fixup / ft_board_fixup. Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Thomas Chou <thomas@wytron.com.tw> (maintainer:NIOS) Cc: York Sun <york.sun@nxp.com> (maintainer:POWERPC MPC85XX) Cc: Stefan Roese <sr@denx.de> (maintainer:POWERPC PPC4XX) Cc: Simon Glass <sjg@chromium.org> Cc: Joakim Tjernlund <Joakim.Tjernlund@infinera.com> Fixes: 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call") Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-19efi: Use asmlinkage for EFIAPISimon Glass
This is required for x86 and is also correct for ARM (since it is empty). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14dm: Use uclass_first_device_err() where it is usefulSimon Glass
Use this new function in places where it simplifies the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-06nios2: set up the debug UART earlyThomas Chou
Set up the debug UART early if enabled, so that it is ready to use. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com>
2016-01-13Fix board init code to respect the C runtime environmentAlbert ARIBAUD
board_init_f_mem() alters the C runtime environment's stack it is actually already using. This is not a valid behaviour within a C runtime environment. Split board_init_f_mem into C functions which do not alter their own stack and always behave properly with respect to their C runtime environment. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-19nios2: display altera sysid at startupThomas Chou
Display altera sysid at startup, which was once removed during the move. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-21nios2: 10m50: change to ns16550 uartThomas Chou
Change to ns16550 uart for 10m50 devboard based on a new Altera release. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-18nios2: zap ioremapThomas Chou
Zap ioremap(), as it is replaced by map_physmem(,,MAP_NOCACHE). Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-18nios2: dma-mapping.h: change ioremap to map_physmemThomas Chou
Change ioremap() to map_physmem(), as it is more used in u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: add 10m50 devboard supportThomas Chou
Add 10m50 devboard support. It is based on the Golden Hardware Reference Design (GHRD), available at, http://rocketboards.org/foswiki/view/Documentation/ AlteraMAX1010M50RevCDevelopmentKitLinuxSetup Though we supported only one nios2-generic board in the past. Now, with the removal of the nios2-generic board dir, adding new nios2 boards to u-boot is easier than before. It should be helpful to add those boards supported in Linux mainline. There are only two such nios2 boards, the 3c120 devboard and 10m50 devboard. The nios2-generic is actually 3c120, and should restore the name. The 10m50 is this one. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: add memcpy_fromio and memcpy_toioThomas Chou
Add memcpy_fromio() and memcpy_toio(). Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-06Merge branch 'master' of git://git.denx.de/u-boot-niosTom Rini
2015-11-06nios2: fix cached mode in clearing the BSSThomas Chou
As the generic board runs in cached mode, it should not use "stwio" which bypass the cache. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Chin Liang See <clsee@altera.com>
2015-11-06nios2: remove CONFIG_SYS_INIT_SP macroThomas Chou
Remove CONFIG_SYS_INIT_SP macro, as the initial stack is set to below the u-boot code. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Chin Liang See <clsee@altera.com>
2015-11-06nios2: change virt_to_phys to use physaddr_mask in global dataThomas Chou
As virt_to_phys() is used a lot in DMA transfer, change it to use physaddr_mask in global data. This will save an "if" statement and get a little faster. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-06nios2: remove the useless parenthesis in asm/io.hThomas Chou
Remove the useless parenthesis in asm/io.h as suggested by Marek. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-06nios2: fix map_physmem to do real cache mappingThomas Chou
Fix the map_physmem() to do real cache mapping. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-05nios2: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-23nios2: fix virt_to_phys for nios2 with MMUThomas Chou
As the virtual address and physical address mapping of nios2 with MMU are different. Add a check of MMU, and fix the mapping. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Ley Foon Tan <lftan@altera.com>
2015-10-23nios2: zap nios2-generic board dirThomas Chou
As we use device tree to control u-boot now, the generic board can be removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert dma_alloc_coherent to use malloc_cache_alignedThomas Chou
Convert dma_alloc_coherent to use memalign. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert copy_exception_trampoline to use dm cpu dataThomas Chou
Convert copy_exception_trampoline() to use dm cpu data. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert cache flush to use dm cpu dataThomas Chou
Convert cache flush to use dm cpu data. The original cache flush functions are written in assembly and use CONFIG_SYS_{I,D}CACHE_SIZE... macros. It is difficult to convert to use cache configuration in dm cpu data which is extracted from device tree. The cacheflush.c of Linux nios2 arch uses cpuinfo structure, which is very close to our dm cpu data. So we copy and modify it to arch/nios2/lib/cache.c to replace the old cache.S. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: set default cache configuration in start.SThomas Chou
Set default icache and dcache configuration for start.S. We want to remove the CONFIG_SYS_{I,D}CACHE_SIZE... configuration macros. As we are just barely starting from reset, there is no luxury of device tree. We will set some maximum cache configuration so that it will work for most configurations. This is used only in this start.S. The speed penalty is only once here. After start up, during board initialization, cpu information will be extracted from device tree. Then cache flush operations will have correct cache configurations. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: clean up comments style in start.SThomas Chou
Clean up comments style in start.S. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: convert ioremap to use dm cpu dataThomas Chou
Convert ioremap() to use io_region_base in dm cpu global data. Also remove three unused io functions, which have style issue and are replaced by macros already. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
