path: root/arch/nios2/lib/libgcc.c
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2010-05-28nios2: fix div64 issue for gcc4Thomas Chou
This patch fixes the run-time error on div64 when built with gcc4, which was reported by jhwu0625 on nios forum. It merges math support from libgcc of gcc4. This patch is copied from nios2-linux. It works with both gcc3 and gcc4. The old mult.c, divmod.c and math.h are removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
