path: root/arch/nds32
2015-02-09common: Move dram_init() declaration to common locationMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: use SoC-specific CONFIG to descend into SoC directoryMasahiro Yamada
Use "obj-$(CONFIG_FOO) += foo/" where it is possible. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-03-28kbuild: move asm-offsets.c from SoC directory to arch/$(ARCH)/libMasahiro Yamada
U-Boot has supported two kinds of asm-offsets.h. One is generic for all architectures and its source is located at ./lib/asm-offsets.c. The other is SoC specific and its source is under SoC directory. The problem here is that only boards with SoC directory can use the asm-offsets infrastructure. Putting asm-offsets.c right under CPU directory does not work. Now a new demand is coming. PowerPC folks want to use asm-offsets. But no PowerPC boards have SoC directory. It seems inconsistent that some boards add asm-offsets.c to SoC directoreis and some to CPU directories. It looks more reasonable to put asm-offsets.c under arch/$(ARCH)/lib. This commit merges asm-offsets.c under SoC directories into arch/$(ARCH)/lib/asm-offsets.c. By the way, I doubt the necessity of some entries in asm-offsets.c. I am leaving refactoring to the board maintainers. Please check "TODO" in the comment blocks in arch/{arm,nds32}/lib/asm-offsets.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Yuantian Tang <Yuantian.Tang@freescale.com>
2014-03-07config.mk: specify the exact path to standalone linker scriptMasahiro Yamada
We want to change the build system to include config.mk only from ./Makefile and spl/Makefile. We must prepare for that in this commit. $(src) is a moving target and not handy for our purpose. We must replace it with a fixed path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-01-28nds32: add support for leopard and orca board boot flow auto detectrick
hardware difference between leopard and orca as below: flash setting leoaprd orca bank size 32MB 64MB bus width 32-bits 16-bits Signed-off-by: rick <rick@andestech.com> Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com>
2013-11-01nds32: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-08-09nds32: introduce DMA allocation APIken kuo
U-Boot does not compile for the adp-ag101 boards since commit a8f9cd1893bef05b92f63242228607b45821c4a7 (net: update FTGMAC100 for MMU/D-cache support) The driver assumes that the DMA allocation API are provided by all architectures. This is not the case for nds32 and it causes a build error. This patch adds DMA allocation API to avoid the errors. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Andes <uboot@andestech.com> Signed-off-by: Andes <uboot@andestech.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-25nds32: Enable FPU if the version of CPU supportedken kuo
Some version of Andes core support FPU coprocessor, if this is the case, and toolchain support FPU instruction set, we should enable it at low level initialization time. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-25nds32: Update <asm/io.h> and <asm/setup.h> with SPDX license identifiersTom Rini
2013-07-25nds32: Convert Makefiles to use COBJS-y styleken kuo
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24nds32: ag101/ag102: Fix setting lastdec and now valuesAxel Lin
The timer3 counter unit for lastdesc and now values are inconsistent in current code. The unit of "readl(&tmr->timer3_counter) / (CONFIG_SYS_CLK_FREQ / 2)" is second. However, CONFIG_SYS_HZ is defined as 1000 in board config file. This means the accuracy of "lastdec" and "now" should be in millisecond, thus fix the equation to set lastdec and now variables accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com>
2013-07-24nds32: Enable the function of passing parameters to Linuxken kuo
Add a header file, setup.h, which copy from Linux source code, this file contain structures are used to pass initialisation parameters to Linux. Enable this function on adp-ag101/adp-ag101p target Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: Enable two banks of SDRAM on Andes boardken kuo
The original adp-ag101/adp-ag101p initialize only one bank(64MB) by default at boot time, but it is not enough for some application, so increasing to two banks(128M). Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: introduce macros for bit manipulationGabor Juhos
U-Boot does not compile for the adp-ag101 boards since commit f6c3b34697bf8bf05cb4e81c2fd3cadb9a98daea (mmc: update Faraday FTSDC010 for rw performance) The driver assumes that the bit manipulation macros are provided by all architectures. This is not the case for nds32 and it causes a build error like this: ftsdc010_mci.c: In function 'ftsdc010_clkset': ftsdc010_mci.c:118: warning: implicit declaration of function 'setbits_le32' ftsdc010_mci.c:123: warning: implicit declaration of function 'clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_request': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:243: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_clkset': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:121: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' The patch adds bit manipulation macros for the nds32 architecture to avoid the errors. The macros are copied from the ARM implementation. Compile tested only. Cc: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-08nds32: Use sections header to obtain link symbolsKuan-Yu Kuo
Include this header to get access to link symbols, which are otherwise removed. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Change stub example to use asm-generic/sections.hSimon Glass
We can use the declarations of __bss_start and _end from this header instead of declaring them locally. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-02-19malloc: make malloc_bin_reloc staticGabor Juhos
On architectures where manual relocation is needed, the 'malloc_bin_reloc' function must be called after 'mem_malloc_init'. Make the 'malloc_bin_reloc' function static and call it directly from 'mem_malloc_init' instead of calling that from board_init_{r,f} functions of the affected architectures. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-18nds32: Add a basic errno.hSimon Glass
This is available on other architectures, and nds32 will start to break without it as code starts to use error numbers more. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04nds32: Use generic global_dataSimon Glass
Move nds32 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01nds32: Drop tlb_addr from global dataSimon Glass
This field doesn't appear to be used for anything important, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19nds32: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Also adjust bi_baudrate to be unsigned. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17nds32: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
With almost all the architecture and board BOARD_LATE_INIT does not use. CONFIG_BOARD_LATE_INIT is used instead. This changed CONFIG_BOARD_LATE_INIT from BOARD_LATE_INIT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Macpaul Lin <macpaul@andestech.com> [trini: Fixup for context changes] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-09-26malloc: remove extern declarations of malloc_bin_reloc() in board.c filesDaniel Schwierzeck
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations in various board.c files to get rid of one checkpatch.pl warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
2012-08-11nds32: fix unused pmu_init warningMike Frysinger
Fixes the build-time warning: board.c: At top level: board.c:106: warning: 'pmu_init' defined but not used This makes the ifdef logic at the call site match the logic at the function definition. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
