path: root/arch/nds32
2017-11-30nds32: dts: Support ftsdc010 DM.Rick Chen
Add dts to support ftsdc010 dm flow on AG101P/AE3XX platform. Signed-off-by: Rick Chen <rick@andestech.com>
2017-10-02nds32: Use asm-generic/io.hPaul Burton
Convert the nds32 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for nds32 this is primarily a matter of removing code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Macpaul Lin <macpaul@andestech.com>
2017-09-28nds32: Fix io.h warning message about readbrick
It is caused from asm/io.h declare different input type. Signed-off-by: rick <rick@andestech.com>
2017-09-21nds32: board: Support SPI driver.rick
Add spi dts node and enable spi dm flash config. Signed-off-by: rick <rick@andestech.com>
2017-09-21nds32: ftmac100 support cache enable.rick
Enable cache and ftmac100 performance can be improved. Signed-off-by: rick <rick@andestech.com>
2017-09-21nds32: bootm: Fix warning of struct tag_serialnr declaredrick
move #include <asm/setup.h> from bootm.c to bootm.h Signed-off-by: rick <rick@andestech.com>
2017-09-12dma: import linux/dma-direction.h to consolidate enum dma_data_directionMasahiro Yamada
Import include/linux/dma-direction.h from Linux 4.13-rc7 and delete duplicated definitions of enum dma_data_direction. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05nds32: Remove include files from common.hSimon Glass
With a few tweaks we can avoid including these files, which are only needed by two C files. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05nds32: Make u-boot-nds32.h a private headerSimon Glass
Rather than including this arch-specific header file in common.h, include it from within nds32's u-boot.h header. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-23nds32: eth: Support ftmac100 DM.rick
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform. Verification: Boot linux kernel via dhcp and bootm ok. NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000; NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4899 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'boomimage-310y-ae300-spi.bin'. Load address: 0x600000 Loading: ################################################################# ################################################################# ################################################################# ... ... ################################### 233.4 KiB/s done Bytes transferred = 13872076 (d3abcc hex) NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4592 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'ae300.dtb'. Load address: 0x2000000 Loading: # 82 KiB/s done Bytes transferred = 2378 (94a hex) NDS32 # bootm 0x600000 - 0x2000000 Image Name: Created: 2017-03-22 6:52:03 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13872012 Bytes = 13.2 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Booting using the fdt blob at 0x2000000 Loading Kernel Image ... OK Loading Device Tree to 01efc000, end 01eff949 ... OK Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) ) #293 PREEMPT Wed Mar 22 14:49:28 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159) ... ... Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AE3XX platform.rick
Support Andestech AE3xx platform: serial, timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P timer DM.rick
Support AG101P timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P serial DM.rick
Support AG101P serial device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-29nds32: Support relocation.rick
Enable pie option for relocation. Signed-off-by: rick <rick@andestech.com> Cc: Andes <uboot@andestech.com>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-07-14arm, nds32, sh: remove useless ioremap()/iounmap() definesMasahiro Yamada
These defines are valid only when iomem_valid_addr is defined, but I do not see such defines anywhere. Remove. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-21nds32: Fix compile error.rick
Fix compile error with gcc 4.9.3 Signed-off-by: rick <rick@andestech.com> Cc: Andes <uboot@andestech.com>
2015-11-05nds32: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-28NDS32: Generic Board Support and UnsupportKun-Hua Huang
Remove ag101 and ag102 support Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
Add nds32 ag101p generic board support. Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-02-09common: Move dram_init() declaration to common locationMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: use SoC-specific CONFIG to descend into SoC directoryMasahiro Yamada
Use "obj-$(CONFIG_FOO) += foo/" where it is possible. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-03-28kbuild: move asm-offsets.c from SoC directory to arch/$(ARCH)/libMasahiro Yamada
U-Boot has supported two kinds of asm-offsets.h. One is generic for all architectures and its source is located at ./lib/asm-offsets.c. The other is SoC specific and its source is under SoC directory. The problem here is that only boards with SoC directory can use the asm-offsets infrastructure. Putting asm-offsets.c right under CPU directory does not work. Now a new demand is coming. PowerPC folks want to use asm-offsets. But no PowerPC boards have SoC directory. It seems inconsistent that some boards add asm-offsets.c to SoC directoreis and some to CPU directories. It looks more reasonable to put asm-offsets.c under arch/$(ARCH)/lib. This commit merges asm-offsets.c under SoC directories into arch/$(ARCH)/lib/asm-offsets.c. By the way, I doubt the necessity of some entries in asm-offsets.c. I am leaving refactoring to the board maintainers. Please check "TODO" in the comment blocks in arch/{arm,nds32}/lib/asm-offsets.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Yuantian Tang <Yuantian.Tang@freescale.com>
2014-03-07config.mk: specify the exact path to standalone linker scriptMasahiro Yamada
We want to change the build system to include config.mk only from ./Makefile and spl/Makefile. We must prepare for that in this commit. $(src) is a moving target and not handy for our purpose. We must replace it with a fixed path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-01-28nds32: add support for leopard and orca board boot flow auto detectrick
hardware difference between leopard and orca as below: flash setting leoaprd orca bank size 32MB 64MB bus width 32-bits 16-bits Signed-off-by: rick <rick@andestech.com> Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com>
2013-11-01nds32: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-08-09nds32: introduce DMA allocation APIken kuo
U-Boot does not compile for the adp-ag101 boards since commit a8f9cd1893bef05b92f63242228607b45821c4a7 (net: update FTGMAC100 for MMU/D-cache support) The driver assumes that the DMA allocation API are provided by all architectures. This is not the case for nds32 and it causes a build error. This patch adds DMA allocation API to avoid the errors. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Andes <uboot@andestech.com> Signed-off-by: Andes <uboot@andestech.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-25nds32: Enable FPU if the version of CPU supportedken kuo
Some version of Andes core support FPU coprocessor, if this is the case, and toolchain support FPU instruction set, we should enable it at low level initialization time. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-25nds32: Update <asm/io.h> and <asm/setup.h> with SPDX license identifiersTom Rini
2013-07-25nds32: Convert Makefiles to use COBJS-y styleken kuo
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24nds32: ag101/ag102: Fix setting lastdec and now valuesAxel Lin
The timer3 counter unit for lastdesc and now values are inconsistent in current code. The unit of "readl(&tmr->timer3_counter) / (CONFIG_SYS_CLK_FREQ / 2)" is second. However, CONFIG_SYS_HZ is defined as 1000 in board config file. This means the accuracy of "lastdec" and "now" should be in millisecond, thus fix the equation to set lastdec and now variables accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com>
2013-07-24nds32: Enable the function of passing parameters to Linuxken kuo
Add a header file, setup.h, which copy from Linux source code, this file contain structures are used to pass initialisation parameters to Linux. Enable this function on adp-ag101/adp-ag101p target Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
