path: root/arch/nds32/include
2016-09-29nds32: Support relocation.rick
Enable pie option for relocation. Signed-off-by: rick <rick@andestech.com> Cc: Andes <uboot@andestech.com>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-07-14arm, nds32, sh: remove useless ioremap()/iounmap() definesMasahiro Yamada
These defines are valid only when iomem_valid_addr is defined, but I do not see such defines anywhere. Remove. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-21nds32: Fix compile error.rick
Fix compile error with gcc 4.9.3 Signed-off-by: rick <rick@andestech.com> Cc: Andes <uboot@andestech.com>
2015-11-05nds32: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-28NDS32: Generic Board Support and UnsupportKun-Hua Huang
Remove ag101 and ag102 support Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
Add nds32 ag101p generic board support. Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
2015-02-09common: Move dram_init() declaration to common locationMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2013-08-09nds32: introduce DMA allocation APIken kuo
U-Boot does not compile for the adp-ag101 boards since commit a8f9cd1893bef05b92f63242228607b45821c4a7 (net: update FTGMAC100 for MMU/D-cache support) The driver assumes that the DMA allocation API are provided by all architectures. This is not the case for nds32 and it causes a build error. This patch adds DMA allocation API to avoid the errors. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Andes <uboot@andestech.com> Signed-off-by: Andes <uboot@andestech.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-25nds32: Update <asm/io.h> and <asm/setup.h> with SPDX license identifiersTom Rini
2013-07-24nds32: Enable the function of passing parameters to Linuxken kuo
Add a header file, setup.h, which copy from Linux source code, this file contain structures are used to pass initialisation parameters to Linux. Enable this function on adp-ag101/adp-ag101p target Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: introduce macros for bit manipulationGabor Juhos
U-Boot does not compile for the adp-ag101 boards since commit f6c3b34697bf8bf05cb4e81c2fd3cadb9a98daea (mmc: update Faraday FTSDC010 for rw performance) The driver assumes that the bit manipulation macros are provided by all architectures. This is not the case for nds32 and it causes a build error like this: ftsdc010_mci.c: In function 'ftsdc010_clkset': ftsdc010_mci.c:118: warning: implicit declaration of function 'setbits_le32' ftsdc010_mci.c:123: warning: implicit declaration of function 'clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_request': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:243: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_clkset': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:121: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' The patch adds bit manipulation macros for the nds32 architecture to avoid the errors. The macros are copied from the ARM implementation. Compile tested only. Cc: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-05-08nds32: Use sections header to obtain link symbolsKuan-Yu Kuo
Include this header to get access to link symbols, which are otherwise removed. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-03-15Change stub example to use asm-generic/sections.hSimon Glass
We can use the declarations of __bss_start and _end from this header instead of declaring them locally. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-18nds32: Add a basic errno.hSimon Glass
This is available on other architectures, and nds32 will start to break without it as code starts to use error numbers more. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04nds32: Use generic global_dataSimon Glass
Move nds32 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01nds32: Drop tlb_addr from global dataSimon Glass
This field doesn't appear to be used for anything important, so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-19nds32: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Also adjust bi_baudrate to be unsigned. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-08-11nds32: drop bi_enetaddr from global dataMike Frysinger
Nothing is using this, so punt it from the gd. Seems to just be a copy & paste wart from the initial port. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-22nds32/ag102: add header support of ag102 socMacpaul Lin
Add device address offsets header of ag102 soc. Add ag102 into mach-types.h. Add asm-offsets.c for helping convert C headers into asm. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-03-19nds32: fix ptrace and interrupt register overflowMacpaul Lin
Fix ptrace and interrupt register overflow warning. Add missing P0 and P1 (r26 and r27) into register lists. These register are usually used in OS. Signed-off-by: Macpaul Lin <macpaul@gmail.com>
2012-02-28nds32: add linkage supportMacpaul Lin
Add linkage support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-18nds32: enhance io.h for compatibility with periphalsMacpaul Lin
Enhance io.h for periphals origin design on x86 systems. For example, pci, ide, etc. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-10adp-ag101p: Add SoC and board support of ag101pMacpaul Lin
Add softcore SoC ag101p and the board adp-ag101p support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-01nds32: asm/io.h: add __iormb __iowmb and inline io supportMacpaul Lin
1. This patch add required __iormb and __iowmb to io.h. This also fix some misbehavior to periphal drivers. This io.h has been fixed with referencing arm/include/asm/io.h. 2. This patch replaced macro writeb and readb into inline function. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-01nds32: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentMacpaul Lin
Add ARCH_DMA_MINALIGN definition to asm/cache.h Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22nds32/ag101: cpu and init funcs of SoC ag101Macpaul Lin
SoC ag101 is the first chip using NDS32 N1213 cpu core. Add header file of device offset support for SoC ag101. Add main function of SoC ag101 based on NDS32 n1213 core. Add lowlevel_init.S and other periphal related code. This version of lowlevel_init.S also replace hardcode value by MARCO defines from the GPL version andesboot for better code quality. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22nds32: add header files support for nds32Macpaul Lin
Add generic header files support for nds32 architecture. Cache, ptregs, data type and other definitions are included. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
