- fdt_support: Add fdt_for_each_node_by_compatible() helper macro
(Marek)
- turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob (Pali)
- pci_mvebu: Add support for Kirkwood PCIe controllers (Pali)
- SPL: More verifications for kwbimage in SPL (Pali)
- mvebu: Remove comphy_update_map() (Pali)
- Minor misc stuff
Add macro fdt_for_each_node_by_compatible() to allow iterating over
fdt nodes by compatible string.
Convert various usages of
off = fdt_node_offset_by_compatible(fdt, start, compat);
while (off > 0) {
code();
off = fdt_node_offset_by_compatible(fdt, off, compat);
and similar, to
fdt_for_each_node_by_compatible(off, fdt, start, compat)
code();
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
On mvebu this is defined if and only if !ARM64.
Otherwise it is defined for boards with ARCH_MX23, ARCH_TEGRA and
ARCH_ZYNQ, and also for SOC_AR934X (tplink_wdr4300).
On MediaTek boards we cannot override the SYS_BOARD / SYS_CONFIG_NAME
variables from defconfig.
This is because in board/mediatek/mtXXXX/Kconfig this value was override
by default due to the if CONFIG_TARGET_MTXXXX condition.
Merge all the Kconfigs to the mach-medatek/Kconfig.
This way:
- we only define SYS_{SOC,VENDOR} once
- all board definitions are in a single place, simplifying the build logic.
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Switch arc/arm/m68k/microblaze/mips/ppc arch_lmb_reserve() to
arch_lmb_reserve_generic().
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Alexey Brodkin <alexey.brodkin@synopsys.com>
Cc: Angelo Dureghello <angelo@sysam.it>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Cc: Hai Pham <hai.pham.ud@renesas.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
This option has not effect now. Drop it, using PCI instead where needed.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
default n/no doesn't need to be specified. It is default option anyway.
[trini: Rework FSP_USE_UPD portion]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
We move the SYS_CACHE_SHIFT_N options from arch/arm/Kconfig to
arch/Kconfig, and introduce SYS_CACHE_SHIFT_4 to provide a size of 16.
Introduce select statements for other architectures based on current
usage. For MIPS, we take the existing arch-specific symbol and migrate
to the generic symbol. This lets us remove a little bit of otherwise
unused code.
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Leo <ycliang@andestech.com>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Sean Anderson <seanga2@gmail.com>
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
Enable DM_PCI and DM_ETH on MIPS Malta.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add DT binding for GT64120 and MSC01 PCI controllers. Only
GT64120 is enabled by default to support Qemu. The MSC01 node
will be dynamically enabled by Malta board code dependent
on the plugged core card.
Remove qemu_mips boards because DM migration doesn't make sense.
The board support for qemu_mips is already marked as deprecated
in Qemu in favour of the Malta board. Also qemu_mips support
has been removed from Linux a long time ago.
The official replacement is the Malta board. The same Malta U-Boot
image can be used with Qemu and on physical hardware.
All combinations of Big Endian and Little Endian as well as 32 bit
and 64 bit are supported.
This commit does the same thing as Linux commit 33def8498fdd.
Use a more generic form for __section that requires quotes to avoid
complications with clang and gcc differences.
Remove the quote operator # from compiler_attributes.h __section macro.
Convert all unquoted __section(foo) uses to quoted __section("foo").
Also convert __attribute__((section("foo"))) uses to __section("foo")
even if the __attribute__ has multiple list entry forms.
https://source.denx.de/u-boot/custodians/u-boot-mips
- MIPS: octeon: fix minor bugs of initial merge
- MIPS: octeon: add support for QLM and PCI-E controller
- MIPS: octeon: add support for AHCI and SATA
- MIPS: octeon: add E1000 ethernet support
- MIPS: octeon: add Octeon III NIC23 board
- ata/scsi: add support for Big Endian platforms
This patch adds support for the following I2C devices connected to
I2C bus 0 on the Octeon EBB7304:
- Dallas DS1337 RTC
- TLV EEPROM
Signed-off-by: Aaron Williams <awilliams@marvell.com>
Cc: Chandrakala Chavva <cchavva@marvell.com>
We already have a clock driver for MIPS Octeon. This patch changes the
Octeon DT nodes to supply the clock property via the clock driver
instead of using an hard-coded value, which is not correct in all cases.
This patch adds the basic support for the PCIe target board equipped
with the Octeon III CN2350 SoC.
Add the AHCI compatible SATA DT node to the Octeon CN73xx dtsi file.
Cc: Aaron Williams <awilliams@marvell.com>
For easy AHCI/ SATA integration, this patch adds board_ahci_enable()
for the MVEBU AHCI driver, which will be used by this platform. This
platform specific "enable" function will setup the proper endian
swapping in the AHCI controller so that it can be used by the common
AHCI code.
Additionally the endian swizzle entry for AHCI in
octeon_should_swizzle_table[] is removed, as this enabled the original
lowlevel code function, e.g. octeon_configure_qlm(), for the QLM setup
to work correctly.
This patch adds the necessary platform infrastructure code, so that the
MIPS Octeon drivers "serial_octeon_pcie_console" & "serial_bootcmd" can
be used. This is e.g. the bootmem initialization in a compatible way to
the Marvell 2013 U-Boot, so that the exisiting PC remote tools like
"oct-remote-console" & "oct-remote-load" can be used. This is be done in
the newly introduced arch_misc_init(), which calls the necessary init
functions when enabled.
These patches are in preparation for the MIPS Octeon NIC23 board
support, which is a desktop PCIe target board enabling these features.
As DEBUG is no Kconfig symbol, we can't use the IS_ENABLED() macros.
This patch switches to the unfortunately necessary #ifdef usage again
to make it work correctly.
While porting from the Marvell source, I introduced a bug by misplacing
the parenthesis. This patch fixes this issue.
This makes is easier to use this macro from non-DDR related files.
This patch adds the PCIe controller node to the MIPS Octeon 73xx dtsi
file.
Setting CONFIG_SYS_PCI_64BIT is needed for correct PCIe functionality on
MIPS Octeon.
This patch adds the newly added C files to the Makefile to enable
compilation. This is done in a separate step, to not introduce build
breakage while adding the single files with potentially missing
externals.
Import octeon_qlm.c from 2013 U-Boot. It will be used by the later
added drivers to support PCIe and networking on the MIPS Octeon II / III
platforms.
Import octeon_fdt.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-qlm.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-pcie.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-helper.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-helper-util.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-helper-jtag.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-helper-fdt.c from 2013 U-Boot. It will be used by the later
platforms.
Import cvmx-helper-cfg.c from 2013 U-Boot. It will be used by the later
platforms.
To match all other cvmx-* header, this patch moves the already existing
cvmx-lmcx-defs.h header one directory up.
With the newly added headers and their restructuring (which macro is
defined where), some changes in the already existing Octeon files are
necessary. This patch makes the necessary changes.
Import misc remaining header files from 2013 U-Boot. These will be used
by the later added drivers to support PCIe and networking on the MIPS
Octeon II / III platforms.
Import cvmx-sso-defs.h header file from 2013 U-Boot. It will be used
Import cvmx-sriox-defs.h header file from 2013 U-Boot. It will be used
Import cvmx-sriomaintx-defs.h header file from 2013 U-Boot. It will be used
Import cvmx-smix-defs.h header file from 2013 U-Boot. It will be used
Import cvmx-sli-defs.h header file from 2013 U-Boot. It will be used
Import cvmx-sata-defs.h header file from 2013 U-Boot. It will be used
