path: root/arch/mips
2020-07-18mips: octeon: Add minimal Octeon 3 EBB7304 EVK supportStefan Roese
This patch adds very basic minimal support for the Marvell Octeon 3 CN73xx based EBB7304 EVK. Please note that the basic Octeon port does not support DDR3/4 initialization yet. To still use U-Boot on with this port, the L2 cache (4MiB) is used as RAM. This way, U-Boot can boot to the prompt on this board. Supported devices: - UART - reset - CFI parallel NOR flash Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: octeon: use mips_mach_early_init() to copy to L2 cacheStefan Roese
This patch adds the code to copy itself from bootrom location to a different location (TEXT_BASE) to the Octeon platform. Its used in this case to copy the complete U-Boot image into L2 cache, which greatly improves the bootup time - especially in regard to the very long and complex DDR4 init code. The Kconfig symbol CONFIG_MIPS_MACH_EARLY_INIT is enabled with this patch for Octeon. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: octeon: dts: Add Octeon 3 cn73xx base dtsi fileStefan Roese
This patch adds the base dtsi file for the Octeon 3 cn73xx SoC. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: octeon: Initial minimal support for the Marvell Octeon SoCAaron Williams
This patch adds very basic support for the Octeon III SoCs. Only CFI parallel NOR flash and UART is supported for now. Please note that the basic Octeon port does not include the DDR3/4 initialization yet. This will be added in some follow-up patches later. To still use U-Boot on with this port, the L2 cache (4MiB on Octeon III CN73xx) is used as RAM. This way, U-Boot can boot to the prompt on such boards. Signed-off-by: Aaron Williams <awilliams@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: Add CONFIG_MIPS_MACH_EARLY_INIT for very early mach init codeStefan Roese
This patch adds the optional call to mips_mach_early_init() to start.S at a very early stage. Its disabled per default. It can be used for very early machine / platform specific init code. Its called very early and at this stage the PC is allowed to differ from the linking address (CONFIG_TEXT_BASE) as no absolute jump has been performed until this call. It will be used by thje Octeon platform. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2020-07-18mips: sync asm/mipsregs.h with Linux 5.7Daniel Schwierzeck
Sync asm/mipsregs.h with Linux 5.7. Also replace the custom symbols EBASE_CPUNUM and EBASE_WG with the according symbols from Linux. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: sync asm/addrspace.h with Linux 5.7Daniel Schwierzeck
Sync asm/addrspace.h with Linux 5.7 Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: sync asm/asm.h with Linux 5.7Daniel Schwierzeck
Sync asm/asm.h with Linux 5.7. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: remove deprecated UNCACHED_SDRAM() macroDaniel Schwierzeck
This macro only served as a wrapper for CKSEG1ADDR() with an exception for CONFIG_TB0229. CONFIG_TB0229 doesn't exist, thus use CKSEG1ADDR() directly. This also prepares for an upcoming asm header sync with Linux. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: add config options for generic cache setup codeDaniel Schwierzeck
Add an own Kconfig symbol for the initial disabling of caches invoked from generic start code. Also add an own Kconfig symbols for the initialization of caches invoked from generic start code. Until now both code paths could only be disabled with CONFIG_SKIP_LOWLEVEL_INIT. But this is not flexible enough for RAM boot scenarios like EJTAG or SPL payload or for machines which don't require cache initialization or which want to provide their own cache implementation. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: refactor disabling of cachesDaniel Schwierzeck
Logically this code belongs to cache_init.S. If a complex SoC needs to replace the generic cache init, mips_cache_disable() can now be called from custom start.S files. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: add KSEG1 wrapper for change_k0_ccaDaniel Schwierzeck
change_k0_cca() is called multiple times. Move the code for changing to KSEG1 to a macro to avoid code duplication. Also fix missing change to KSEG1 when changing to CONF_CM_CACHABLE_COW. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: start.S: remove dead codeDaniel Schwierzeck
Since commit 703ec9ddf965 ("MIPS: Stop building position independent code") the relocation code was completely reworked and removed from start.S. Remove some left-overs of the old code. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2020-07-18mips: cache: Make invalidate_dcache_range() weak to enable overwriteStefan Roese
This patch adds __weak to invalidate_dcache_range() in lib/cache.c. This makes it possible to overwrite this function by a platforms specific version, which will be done for Octeon. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: cache: Make flush_cache() weak to enable overwriteStefan Roese
This patch adds __weak to flush_cache() in lib/cache.c. This makes it possible to overwrite this function by a platforms specific version, like done with the Octeon base port. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: cache: Allow using CONFIG_MIPS_L2_CACHE without CONFIG_MIPS_CMStefan Roese
This patch enables the usage of CONFIG_MIPS_L2_CACHE without CONFIG_MIPS_CM, which is what is needed for the newly added Octeon platform. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: reloc: Change R_MIPS_NONE to catch pre-reloc BSS usageStefan Roese
This patch changes the R_MIPS_NONE define from 0 to a magic value. This makes it possible to better detect any forbidden pre-relocation usage of BSS variables, as they are often zero'ed and then relocation is stopped too early. Additionally the error message is improved to also print the faulting address. This helps finding the root-cause for this breakage by comparing this address with the values in System.map. This patch helps a lot when working on pre-relocation code, like the Octeon DDR init code, where such variables have hit me multiple times now. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Aaron Williams <awilliams@marvell.com> Cc: Chandrakala Chavva <cchavva@marvell.com>
2020-07-18mips: traps: Set WG bit in EBase register on OcteonStefan Roese
WG (bit 11) needs to be set on Octeon to enable writing bits 63:30 of the exception base register. Signed-off-by: Stefan Roese <sr@denx.de>
2020-07-18mips: time: Only compile the weak get_tbclk() when neededStefan Roese
This patch opts-out the compilation of get_tbclk() if CONFIG_SYS_MIPS_TIMER_FREQ is not defined. This is used on the Octeon platform, where the weak get_tbclk() function is overwritten by its platform specific one. Signed-off-by: Stefan Roese <sr@denx.de>
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
2020-05-18common: Drop linux/bug.h from common headerSimon Glass
2020-05-18common: Drop asm/ptrace.h from common headerSimon Glass
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop image.h from common headerSimon Glass
2020-05-18common: Drop bootstage.h from common headerSimon Glass
Move this fairly uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-27mips: Add support for SoM "VoCore2".Mauro Condarelli
Small patch to add support for VoCore/VoCore2 board. VoCore is open hardware and runs OpenWrt/LEDE. It has WIFI, USB, UART, 20+ GPIOs but is only one inch square. It will help you to make a smart house, study embedded system or even make the tiniest router in the world. Details about this SoM can be found at "https://vocore.io/v2.html". Signed-off-by: Mauro Condarelli <mc5686@mclink.it> Reviewed-by: Stefan Roese <sr@denx.de>
2020-04-27mips: mt76x8: ddr_cal: Correct dqs_find_min/max implementationsStefan Roese
The current implementations have some issues detecting the correct values: dqs_find_max() will return "last passing fieldval + 1" instead of "last passing fieldval". Also it will return "maxval + 1" in the case that all fieldvals are tested valid (without error). dqs_find_min() will not test the "lowest" value because of using ">" instead of ">=". This patch now rewrites these functions to fix those issues. Also, this patch uses the same approach of a for loop in both functions making it easier to read and maintain. Since the variables are integers now, we can use min()/max(), which handles the wrap around case for fieldval=0: return (0 - 1). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mt76x8: ddr_cal: Change types from u32 to int in dqs_find_min/maxStefan Roese
This change is made to enable comparison of integer variables, which might be negative in the next patch. No functional change is intended in this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mt76x8: ddr_cal: Rename dqs_test_valid() to dqs_test_error()Stefan Roese
This function returns "-1" (true) upon error. So the function name does not match its implementation which is confusing. This patch renames the function to dqs_test_error() which makes the code easier to read. Also change the return type to bool and return "true" or "false". Signed-off-by: Stefan Roese <sr@denx.de> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: add support for mt7628-rfbWeijie Gao
This patch adds support for mt7628 reference board. SPL_DM and DT are not enabled for SPL to save about 17KiB for u-boot-spl.bin. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: enable SPL for all boardsWeijie Gao
This patch enables SPL for all mtmips boards. And also remove defconfig files which are intend to build ram bootable u-boot files. SPL_DM and OF_CONTROL are enabled for both boards. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: add SPL supportWeijie Gao
This patch adds SPL support for mtmips platform. The lowlevel architecture is split into SPL and the rest parts are built into a memory loadable u-boot image. Optional SPL_DM and OF_CONTROL are also supported. The increment of size is very small (< 10 KiB) if SPL_DM and OF_CONTROL are not enabled and the memory bootable u-boot (u-boot.img) is generated automatically so there is not need to add a separate config for it. A lzma compressed payload (u-boot-lzma.img) is also generated and it will be combined with u-boot-spl.bin to form the unified ROM bootable binary u-boot-mtmips.bin. A spl loader is added to support uncompress the payload. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: rewrite lowlevel codes of mt7628Weijie Gao
This patch rewrites the mtmips architecture with the following changes: 1. Move MT7628 soc parts into a subfolder. 2. Lock parts of D-Cache as temporary stack. 3. Reimplement DDR initialization in C language. 4. Reimplement DDR calibration in a clear logic. 5. Add full support for auto size detection for DDR1 and DDR2. 6. Use accurate CPU clock depending on the input xtal frequency for timer and delay functions. Note: print_cpuinfo() has incompatible parts with MT7620 so it's moved into mt7628 subfolder. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: add a option to support not reserving malloc space on initial stackWeijie Gao
The initial stack on some platforms is too small to hold a large malloc space. This patch adds a option to allow these platforms not reserving the malloc space on initial stack. These platforms should set the malloc base after DRAM is usable. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: add an option to support initialize SRAM for initial stackWeijie Gao
Currently CONFIG_MIPS_INIT_STACK_IN_SRAM assumes the memory space for the initial stack can be used directly. However on some platform the SRAM needs initialization, e.g. lock cache. This patch adds an option to allow a new function mips_sram_init() being called before setup_stack_gd. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27dts: mtmips: add alternative pinmux node for uart2Weijie Gao
This patch adds a new pinmux for UART2, which shares the pins with SPIS. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: add a mtmips-specific field to architecture-specific global dataWeijie Gao
SoCs of mtmips can use different CPU frequencies depending on the HW/SW configurations. For example mt7628 uses 580MHz clock if the input xtal frequency is 40MHz, and 575MHz clock if the xtal is 25MHz. Upon cold boot the CPU uses the xtal frequency directly. So hardcoding the timer frequency (half of the CPU frequency) in CONFIG_SYS_MIPS_TIMER_FREQ is not a good idea for this case. This patch adds a mtmips-specific field timer_freq to arch_global_data. This field will be used later in mtmips-specific get_tbclk() to provide accurate timer frequency in different boot stage. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: make use of sysreset-resetctrl for mt7628 socWeijie Gao
This patch replaces sysreset-syscon with sysreset-resetctrl for mt7628 soc. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: spl: Flush cache before jumping to U-Boot properStefan Roese
This patch adds a MIPS specific jump_to_image_no_args() implementation, which flushes the U-Boot proper image loaded from the boot device in SPL before jumping to it. It has been noticed on MT76x8, that this cache flush is needed. Other MIPS platforms might need it as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2020-04-27mips: add an option to enable u_boot_list section for SPL loaders in ↵Weijie Gao
u-boot-spl.lds u_boot_list is not only used by DM, but also by some SPL image load methods such as spl_nor.c. This patch adds an option CONFIG_SPL_LOADER_SUPPORT in conjunction with CONFIG_SPL_DM surrounding the u_boot_list section to make sure SPL image loaders can be correctly built into u-boot SPL without DM enabled. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: enable support for appending dtb to spl binaryWeijie Gao
If CONFIG_SPL_OF_CONTROL is enabled for SPL and CONFIG_OF_SEPARATE is also enabled, the dtb will be appended to the u-boot-spl.bin. When calling dm_init_and_scan() in SPL, fdtdec_setup() will try to locate dtb at the end of u-boot-spl.bin, by referencing to _image_binary_end. However _image_binary_end is currently missing in u-boot-spl.lds. This patch adds _image_binary_end to u-boot-spl.lds to make sure linking u-boot-spl will not fail. Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: start.S: avoid overwriting outside gd when clearing global data in stackWeijie Gao
When setting up initial stack, global data will also be put in the stack, and being cleared. The assembler instructions for clearing gd is as follows: move t0, k0 1: PTR_S zero, 0(t0) blt t0, t1, 1b PTR_ADDIU t0, PTRSIZE t0 is the start address of gd, t1 is the end address of gd (t0 + GD_SIZE). [PTR_ADDIU t0, PTRSIZE] is in the delay slot of [blt t0, t1, 1b], so it will be executed before the branch operation. However the comparison for the BLT instruction is done before executing the delay slot. This means when the last word just before k1 is cleared, the loop will continue to run once. This will clear an extra word at k1, which is outside the global data. Global data is placed at the top of the stack. If the initial stack is a SRAM or locked cache, the area outside them may be inaccessible. A write operation performed in this area may cause an exception. To solve this, [PTR_ADDIU t0, PTRSIZE] should be placed before the BLT instruction. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: mtmips: add predefined i-cache/d-cache size and linesizeWeijie Gao
Both mt7620 and mt7628 has the same cache configuration. There is no need to use CONFIG_SYS_CACHE_SIZE_AUTO to probe it at runtime. Add them into Kconfig to reduce some code size. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-27mips: add support to restore exception vector base before booting linuxWeijie Gao
In U-Boot the exception vector base will be moved to top of memory, to be used to display register dump when exception occurs. But some old linux kernel does not honor the base set in CP0_EBASE. A modified exception vector base will cause kernel crash. This patch adds an option to enable reset exception vector base to its previous value, or a user configured value before booting linux kernel. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-13Merge branch 'next'Tom Rini
Pull in changes that have been pending in our 'next' branch. This includes: - A large number of CI improvements including moving to gcc-9.2 for all platforms. - amlogic, xilinx, stm32, TI SoC updates - USB and i2c subsystem updtaes - Re-sync Kbuild/etc logic with v4.19 of the Linux kernel. - RSA key handling improvements
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
