path: root/arch/mips
2018-08-08bcm968380gerg: add initial supportPhilippe Reynes
This add the initial support of the broadcom reference board bcm968380gerg with a bcm68380 SoC. This board has 512 MB of RAM, 128 MB of flash (nand), 2 USB port, 1 UART, 4 ethernet ports and BCM43217 (wifi). Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-08-08bcm6838: add initial supportPhilippe Reynes
This adds the initial support of the Broadcom BCM6838 SoC familly, only cpu, dram, uart and leds are supported. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-08-08mips: au1x00: Remove support for these SoCsTom Rini
The only platform left for the AU1x00 SoCs was the pb1x00 platform, an apparent clone of the dbau1x00 platform. As pb1x00 had no listed maintainer I am assuming that it is also orphaned. Remove this platform and then remove the unused SoC support. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-08-08mips: dbau1x00: Remove this boardTom Rini
This platform has been marked as orphan since June of 2016 and should have been removed some time ago. Do so now. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-07-30Kconfig: Sort bool, default, select and imply optionsMichal Simek
Another round of sorting Kconfig entries aplhabetically. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-30dm: Change CMD_DM enablingMichal Simek
CMD_DM is used for debug purpose and it shouldn't be enabled by default via Kconfig. Unfortunately this is in the tree for quite a long time that's why solution is to use imply DM for all targets which are enabling DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Fix Kconfig bool, default, select and imply options to be alphabetically sorted. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-06-18.gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignoreMasahiro Yamada
Follow Linux commit 10b62a2f785a (".gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignore"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-21mips: bmips: add ar-5315 usb supportÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-03-21mips: bmips: add support for bcm6318 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add vr-3032u usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm63268 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add dgnd3700v2 usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm6362 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add ar-5387un usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm6328 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add wap-5813n usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm6368 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add nb4-ser usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add hg556a usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm6358 usbÁlvaro Fernández Rojas
2018-03-21mips: bmips: add ct-5361 usb supportÁlvaro Fernández Rojas
2018-03-21mips: bmips: add support for bcm6348 usbÁlvaro Fernández Rojas
2018-03-21MIPS: add BMIPS Netgear DGND3700v2 boardÁlvaro Fernández Rojas
2018-03-21MIPS: add support for Broadcom MIPS BCM6362 SoC familyÁlvaro Fernández Rojas
2018-02-18fdt: Implement weak arch_fixup_fdt()Alexey Brodkin
Only ARM and in some configs MIPS really implement arch_fixup_fdt(). Others just use the same boilerplate which is not good by itself, but what's worse if we try to build with disabled CONFIG_CMD_BOOTM and enabled CONFIG_OF_LIBFDT we'll hit an unknown symbol which was apparently implemented in arch/xxx/lib/bootm.c. Now with weak arch_fixup_fdt() right in image-fdt.c where it is used we get both items highlighted above fixed. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-26Merge git://git.denx.de/u-boot-mipsTom Rini
2018-01-26MIPS: add BMIPS Comtrend AR-5315u boardÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-26MIPS: add support for Broadcom MIPS BCM6318 SoC familyÁlvaro Fernández Rojas
2018-01-26MIPS: add BMIPS Comtrend WAP-5813n boardÁlvaro Fernández Rojas
2018-01-26MIPS: add support for Broadcom MIPS BCM6368 SoC familyÁlvaro Fernández Rojas
2018-01-25mips: bmips: increment SYS_MALLOC_F_LENÁlvaro Fernández Rojas
This prevents the following ENOMEM: Error binding driver 'bmips_cpu': -12 Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-24mips: bmips: enable the SPI flash on the Comtrend AR-5387unÁlvaro Fernández Rojas
It's a Macronix (mx25l12805d) 16 MB SPI flash. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24mips: bmips: add bcm63xx-hsspi driver support for BCM63268Álvaro Fernández Rojas
This driver manages the high speed SPI controller present on this SoC. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24mips: bmips: add bcm63xx-hsspi driver support for BCM6328Álvaro Fernández Rojas
This driver manages the SPI controller present on this SoC. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24mips: bmips: enable the SPI flash on the Netgear CG3100DÁlvaro Fernández Rojas
It's a Spansion (s25fl064a) 8 MB SPI flash. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-24mips: bmips: enable the SPI flash on the Sagem F@ST1704Álvaro Fernández Rojas
It's a Winbond (w25x32) 4 MB SPI flash. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-24mips: bmips: add bcm63xx-spi driver support for BCM63268Álvaro Fernández Rojas
This driver manages the low speed SPI controller present on this SoC. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-24mips: bmips: add bcm63xx-spi driver support for BCM3380Álvaro Fernández Rojas
This driver manages the SPI controller present on this SoC. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-24mips: bmips: add bcm63xx-spi driver support for BCM6358Álvaro Fernández Rojas
2018-01-24mips: bmips: add bcm63xx-spi driver support for BCM6348Álvaro Fernández Rojas
2018-01-24mips: bmips: add bcm63xx-spi driver support for BCM6338Álvaro Fernández Rojas
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-11-28MIPS: Break out of cache loops for unimplemented cachesPaul Burton
If we run on a CPU which doesn't implement a particular cache then we would previously get stuck in an infinite loop, executing a cache op on the first "line" of the missing cache & then incrementing the address by 0. This was being avoided for the L2 caches, but not for the L1s. Fix this by generalising the check for a zero line size & avoiding the cache op loop when this is the case. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2017-11-28MIPS: Clear instruction hazards in flush_cache()Paul Burton
When writing code, for example during relocation, we ensure that the icache has a coherent view of the new instructions with a call to flush_cache(). This handles the bulk of the work to ensure the new instructions will execute as expected, however it does not ensure that the CPU pipeline doesn't already contain instructions taken from a stale view of the affected memory. This could theoretically be a problem for relocation, but in practice typically isn't because we sync caches for enough code after the entry point of the newly written code that by the time the CPU pipeline might possibly fetch any of it we'll have long ago written it back & invalidated any stale icache entries. This is however a problem for shorter regions of code. In preparation for later patches which write shorter segments of code, ensure any instruction hazards are cleared by flush_cache() by introducing & using a new instruction_hazard_barrier() function which makes use of the jr.hb instruction to clear the hazard. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2017-11-28MIPS: Ensure cache ops complete in cache maintenance functionsPaul Burton
A typical use of cache maintenance functions is to force writeback of data which a device is about to read using DMA - for example a descriptor or command structure. Such users of cache maintenance functions require that operations on the cache have completed before they proceed to instruct a device to read memory. This requires that we place a completion barrier (ie. sync instruction) between the cache ops and whatever write informs the device to perform DMA. Whilst strictly speaking this isn't all users of the cache maintenance functions & we could instead place the barriers in the drivers that require them, it would be much more invasive to do so than to just have the barrier be the default by placing it in the cache functions themselves. The cost is low enough that it shouldn't matter to us in any rare cases that we use the cache functions when not performing DMA. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2017-11-28MIPS: Drop unused PTR_COUNT_SHIFT from u-boot.ldsPaul Burton
The u-boot.lds linker script for MIPS defines a PTR_COUNT_SHIFT macro to 2 or 3 for 32 bit or 64 bit builds respectively. This macro is never actually used though, so remove the dead code. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-10-02mips: Use asm-generic/io.hPaul Burton
Convert the mips architecture to make use of the new asm-generic/io.h to provide address mapping functions. As mips actually performs non-identity mapping between physical & virtual addresses we can't simply make use of the generic functions, with the exception of being able to drop our no-op unmap_physmem() and definitions of unused map flags. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
