This commit does the same thing as Linux commit 33def8498fdd.
Use a more generic form for __section that requires quotes to avoid
complications with clang and gcc differences.
Remove the quote operator # from compiler_attributes.h __section macro.
Convert all unquoted __section(foo) uses to quoted __section("foo").
Also convert __attribute__((section("foo"))) uses to __section("foo")
even if the __attribute__ has multiple list entry forms.
Signed-off-by: Marek BehĂșn <marek.behun@nic.cz>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
Move this function into init.h which seems to be designed for this sort
of thing. Also update the header to declare struct global_data so that it
can be included without global_data.h being needed.
These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add initial support for the Ingenic JZ47xx MIPS SoC.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
