On mvebu this is defined if and only if !ARM64.
Otherwise it is defined for boards with ARCH_MX23, ARCH_TEGRA and
ARCH_ZYNQ, and also for SOC_AR934X (tplink_wdr4300).
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
At present panic() is in the vsprintf.h header file. That does not seem
like an obvious choice for hang(), even though it relates to panic(). So
let's put hang() in its own header.
[trini: Migrate a few more files]
These functions relate to memory init so move them into the init
header.
These three clock functions don't use driver model and should be migrated.
In the meantime, create a new file to hold them.
QCA9563 is CPU used on AP152 board :
Clock speed : 750 MHz ,
Arch : Mips 74Kc,
Eth : SGMII interface,
MIMO config : 3 * 3 450M,
2 * USB 2.0,
Signed-off-by: Rosy Song <rosysong@rosinson.com>
Changes for v2:
- coding style cleanup
- remove ununsed flash chip in defconfig
- enable automatic icache / dcache size in defconfig
Changes for v3:
- add detailed information for qca956x in commit message
Changes for v4:
- remove pre-configured network settings in ap152.h
Changes for v5:
See details in chapter 8.6.2 and 8.6.4 (page 140-141) of qca9563 datasheet,
NFRAC[17:0]
So the mask of [17:5] is 0x1fff not 0x3fff.
Changes for v2-v3:
- add more information for this commit
Changes for v4-v5:
Another round of sorting Kconfig entries aplhabetically.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
wait_for_bit callers use the 32 bit LE version
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
This allows us to use the same DRAM init function on all archs. Add a
dummy function for arc, which does not use DRAM init here.
[trini: Dummy function on nios2]
At present we cannot use this function as an init sequence call without a
wrapper, since it returns the RAM size. Adjust it to set the RAM size in
global_data instead, and return 0 on success.
It looks like only cm5200 and tqm8xx use this feature, so we don't really
need it in generic code. Drop it and have the users access gd->board_type
directly.
This adds a compile time option to include code for static
exception vectors. Static exception vectors are only needed,
when the U-Boot entry point is equal to the CPU reset exception
vector address. For instance this is the case when U-Boot is
used as ROM in Qemu or booted from parallel NOR flash. When
U-Boot is booted from RAM (e.g. loaded there by SPL), the
exception vectors need to be setup dynamically, which is done
in follow-up commits.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
In order to prepare for MIPS arch code making use of arch_cpu_init in a
later patch, stop using it from ath79 SoC code & instead use the new
mach_cpu_init which is provided for this purpose.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Add AR933X_PLL_SWITCH_CLOCK_CONTROL_REG define for ar933x chip.
Signed-off-by: Wills Wang <wills.wang@live.com>
Add code to ungate USB and ethernet controller on qca953x
Add a platform prefix for function name in order to make more readable,
and move it into ath79.h
GCC 5.3 report a warning: 'upper' and 'lower' may be used
uninitialized in this function [-Wmaybe-uninitialized].
Compiler might need explicit initializer.
We need reset the Ethernet Switch analog part before operation,
or the build-in Ethernet PHY don't work.
Add support for the TPLink WDR4300 router, which is based on the
AR9344 MIPS 74Kc CPU and has 128 MiB of RAM. The USB is supported
on this system as well.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Wills Wang <wills.wang@live.com>
Add support for the Atheros AR934x WiSoCs. This patchs adds complete
system init, including PLL and DRAM init, both of which happen from
full C environment, since the AR934x has proper SRAM.
Add code to ungate the ethernet controller on ar933x and ar934x .
Add code to ungate the USB controller on ar933x and ar934x .
The assignment const T var; var = value; is illegal, since var is
constant. Drop the const to fix the compiler warning.
The indent in this file triggers my OCD, so fix it. Replace multiple
spaces with tabs and align the values in one column.
use 'const' keywork to qualify readonly attribute for lookup-table member
used a uniform BIT macro for register bit-field shift
This patch add board-level code and base DT for AP143.
[updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y]
This patch add board-level code and base DT for AP121.
This patch enable work for qca953x SOC.
This patch enable work for ar933x SOC.
This patch add some common code for QCA/Atheros ath79 SOCs such as
DDR tuning, chip reset and CPU detection.
