After all MIPS boards are switched to generic-board, the
MIPS specific board.c can be removed.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
gd->bd->bi_baudrate is a copy of gd->baudrate.
Since baudrate is a common feature for all architectures,
keep gd->baudrate only.
It is true that bi_baudrate was passed to the kernel in that structure
but it was a long time ago.
Cc: Tom Rini <trini@ti.com>
Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
This is dead hardware and no one is interested in making the
necessary changes for upcoming features like generic board or
driver model.
Move the definition of this variable out of arch/mips/lib/board.c in
preparation for allowing use of generic board on MIPS, which will lead
to this file not being compiled.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
[trini: Fixup common/cmd_io.c]
Delete all occurrences of hang() and provide a generic function.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Modify check around puts() in hang.c slightly]
Remove the manual relocation of env_name_spec. This has been missed
in the previous patch series for introducing dynamic relocation
on MIPS.
The code handles relocation entries with the
following relocation types only:
mips32: R_MIPS_REL32
mips64: R_MIPS_REL+R_MIPS_64
xburst: R_MIPS_REL32
Other relocation entries are skipped without
processing. The code must be extended if other
relocation types must be supported.
Add -pie to LDFLAGS_FINAL to generate the .rel.dyn
fixup table, which will be applied to the relocated
image before transferring control to it.
The CONFIG_NEEDS_MANUAL_RELOC is not needed
after the patch, so remove that as well.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Use the newly introduced symbols __image_copy_end and __bss_end
for setting up the memory area for the relocated U-Boot.
serial_initialize() must be called after relocation to adjust the
pointers to putc(), getc(), etc. This is busted ever since the
serial driver-model-ification series.
mips_io_port_base is exported as 'extern const unsigned long mips_io_port_base;'
in arch/mips/include/asm/io.h. Thus make the variable const too.
This patch converts the old method of creating a list of command
onto the new LG-arrays code. The old u_boot_cmd section is converted
to new u_boot_list_cmd subsection and LG-array macros used as needed.
Minor adjustments had to be made to the common code to work with the
LG-array macros, mostly the fixup_cmdtable() calls are now passed the
ll_entry_start and ll_entry_count instead of linker-generated symbols.
The command.c had to be adjusted as well so it would use the newly
introduced LG-array API instead of directly using linker-generated
symbols.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations
in various board.c files to get rid of one checkpatch.pl warning.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
This fixes some remaining checkpatch.pl warnings.
All arches init this the same way, so move the logic into the core
net code to avoid duplicating it everywhere else.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Boards with CONFIG_SYS_NO_FLASH should not forced to define
CONFIG_SYS_FLASH_BASE. In this case the flash data in bd_info
should be initialized with 0 like the other archs do.
Fix:
board.c: In function 'board_init_r':
board.c:262:8: warning: unused variable 's' [-Wunused-variable]
(raised for configurations without ethernet support like
vct_premium_small)
Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Fix all errors and all warnings except for "externs should be avoided"
which could require more extensive changes.
This changes the board code to use the new getenv_ulong() function.
This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
The Purple SoC and eval board are not actively maintained since years.
This patch removes the support completely as aggreed with Wolfgang Denk.
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02
removed compiler warning for (now) unused cmd_tbl_t* cmdtp
Portions of this work were supported by funding from
the CE Linux Forum.
fixup_cmdtable() did all work for fixing up the cmdtable,
if CONFIG_RELOC_FIXUP_WORKS is not defined.
CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked
with Graeme Russ, and he will fix this soon.
the CE Linux Forum.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
