path: root/arch/mips/include/asm/byteorder.h
2016-01-16MIPS: fix SPDX license identifier in remaining arch header filesDaniel Schwierzeck
Add a SPDX license identifier to MIPS header files where it is still missing. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
