path: root/arch/mips/dts
2019-04-22dt: bcm968380gerg: enable nand controllerPhilippe Reynes
Enable the nand controller in the device tree of the board bcm96838gerg. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-22dt: bcm6838: add nand controllerPhilippe Reynes
Add the nand controller in the bcm6838 device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
Conflicts: arch/arm/dts/armada-385-amc.dts arch/arm/dts/armada-xp-theadorable.dts arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12net: mscc: servalt: Add ethernet nodes for ServalTHoratiu Vultur
Add ethernet nodes for ServalT SoCs family. Currently there is only one pcb(pcb116) in this family. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-04-12net: mscc: jaguar2: Add ethenet nodes for Jaguar2.Horatiu Vultur
Add ethernet nodes for Jaguar2 SoCs family. There are 3 pcb in this family: pcb110, pcb111 and pcb112. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-04-12dt: bcm968380gerg: enable gpio controllerPhilippe Reynes
Enable the gpio controllers in the device tree of the board bcm968380gerg. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-04-12dt: bcm6838: add gpio controllerPhilippe Reynes
Add gpio controllers in bcm6838 device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-04-12mips: add initial support for qca956x referenced boardRosy Song
QCA9563 is CPU used on AP152 board : Clock speed : 750 MHz , Arch : Mips 74Kc, Eth : SGMII interface, MIMO config : 3 * 3 450M, 2 * USB 2.0, Signed-off-by: Rosy Song <rosysong@rosinson.com> Changes for v2: - coding style cleanup - remove ununsed flash chip in defconfig - enable automatic icache / dcache size in defconfig Changes for v3: - add detailed information for qca956x in commit message Changes for v4: - remove pre-configured network settings in ap152.h Changes for v5: - coding style cleanup
2019-04-12mips: mt76xx: gardena-smart-gateway: Correct spelling of GARDENAStefan Roese
This patch changes Gardena to the correct GARDENA spelling. Also the platform name is "GARDENA smart Gateway". This patch changes the incorrect occurrances. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-04-12mips: add ethernet support for qca953x referenced boardsRosy Song
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-03-22mips: add missing dtb-y to arch/mips/dts/MakefileMasahiro Yamada
Since commit 27cb7300ffda ("Ensure device tree DTS is compiled"), build succeeds irrespective of the correctness of Makefile. In fact, you can compile any defconfig without adding any entry in arch/*/dts/Makefile. I am going to revert that commit, so device tree must be explicitly listed in Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-02-09dt: bcm6838: add watchdogPhilippe Reynes
This commit add watchdog and sysreset watchdog in the bcm6838 device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-02-01mips: mscc: luton: Add ethernet nodes for Luton.Horatiu Vultur
Add nodes for pcb090 and pcb091. There is currently no support in Linux for this SoC. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MSCC: Add board support for Serval SoC family.Horatiu Vultur
Add board support and configuration for Jaguar2 SoC family. The detection of the board type is based on the phy ids. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-23MSCC: Add device tree for Serval pcb106 boardHoratiu Vultur
Add device tree based on evaluation board pcb106. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MSCC: add device tree for Serval pcb105 boardHoratiu Vultur
Add device tree based on evaluation board pcb105. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MSCC: Add board support for Servalt SoC familyHoratiu Vultur
Add board support, configuration and DTS for Servalt SoC family. Currently there is one board in this family. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MIPS: mscc: ocelot: Add ethernet nodes for OcelotGregory CLEMENT
Import Ethernet related nodes from Linux Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2019-01-16mips: mt7688: gardena-smart-gateway: Enable green power LED on startupStefan Roese
Set the correct power-up state (default-state) of the green power LED. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-16MSCC: Add board support for Jaguar2 SOC familyHoratiu Vultur
Add board support and configuration for Jaguar2 SOC family. The detection of the board type in this family is based on the phy ids. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16MSCC: add device tree for Serval2 boardHoratiu Vultur
Add device tree based on evaluation board pcb112. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16MSCC: Add device tree for Jaguar2-48 boardHoratiu Vultur
Add device tree based on evaluation board pcb111. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16MSCC: Add device tree for Jaguar2 boardHoratiu Vultur
Add device tree based on evaluation board pcb110. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16mips: mscc: DT: Update luton device tree to use fast SPI driverLars Povlsen
Thes patch change the luton base device tree to use the newly added SPI bitbang driver. It also updates the "mscc_luton_defconfig" to use the new driver. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-16mips: ocelot: DT: Enable use of serial gpioLars Povlsen
This enables the use of the MSCC serial GPIO driver on the MSCC VCoreIII 'ocelot' SOC, and add gpio-leds nodes to the pcb123 and pcb120 DT. Signed-off-by: Lars Povlsen <lars.povlsen@microsemi.com>
2019-01-16mips: luton: DT: Enable use of serial gpioLars Povlsen
This enables the use of the MSCC serial GPIO driver, and add gpio-leds nodes to the 'luton' pcb090 and pcb091 DT. Signed-off-by: Lars Povlsen <lars.povlsen@microsemi.com>
2019-01-16mips: mscc: luton+ocelot: Remove board config options, do probingLars Povlsen
As we are moving to multi-dtb and board detection, remove static board config options, and introduce board probing instead. Luton: This add single-binary support for the two MSCC luton-based reference boards - pcb090 and pcb091. The SoC chip ID is used to determine the board type. Ocelot: This add single-binary support for the two MSCC ocelot-based reference boards - pcb120 and pcb123. The PHY ids on specific ports are used to determine the board type. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2019-01-16mips: luton: DT: Add pcb090Lars Povlsen
This prepares individual device trees for MSCC luton-based reference boards - pcb090 and pcb091. Note: Even though the devices trees are quite common, they will differ significantly in coming patches. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2018-12-19mips: jz47xx: Add Creator CI20 platformPaul Burton
Add support for the Creator CI20 platform based on the JZ4780 SoC. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Marek Vasut <marex@denx.de>
2018-12-19mips: jz47xx: Add JZ4780 SoC supportPaul Burton
Add initial support for the Ingenic JZ47xx MIPS SoC. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Marek Vasut <marex@denx.de>
2018-12-19MSCC: add board support for the Luton based evaluation boardGregory CLEMENT
Adding the support for the Luton boards PCB91 which share common code with the Ocelots boards, including board code, device tree and configuration. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-19MSCC: add board support for the Ocelots based evaluation boardsGregory CLEMENT
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123 Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-19mips: xilfpga: fix DTC warningsDaniel Schwierzeck
This fixes following DTC warning: arch/mips/dts/nexys4ddr.dtb: Warning (compatible_is_string_list): /ethernet@10e00000/mdio/phy@1:compatible: property is not a string list As upstream DTS in Linux doesn't have the offending property, simply remove it to fix the warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19mips: ath79: fix DTC warningsDaniel Schwierzeck
Remove all interrupt nodes that cause warnings regarding a missing interrupt parent. There are no interrupt controller nodes defined and the device trees don't match the ones in Linux anymore. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-19bmips: enable ar-5315u enet supportÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-12-19bmips: bcm6318: add support for bcm6368-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable vr-3032u enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm63268: add support for bcm6368-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable dgnd3700v2 enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm6362: add support for bcm6368-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable ar-5387un enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm6328: add support for bcm6368-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable wap-5813n enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm6368: add support for bcm6368-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable nb4-ser enet supportÁlvaro Fernández Rojas
2018-12-19bmips: enable hg556a enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm6358: add support for bcm6348-enetÁlvaro Fernández Rojas
2018-12-19bmips: enable ct-5361 enet supportÁlvaro Fernández Rojas
2018-12-19bmips: bcm6348: add support for bcm6348-enetÁlvaro Fernández Rojas
