path: root/arch/mips/dts/serval_pcb105.dts
2019-05-03net: mscc: serval: Add ethernet nodes for ServalHoratiu Vultur
Add ethernet nodes for Serval SoCs family. There are 2 pcb in this family: pcb105 and pcb106. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-01-23MSCC: add device tree for Serval pcb105 boardHoratiu Vultur
Add device tree based on evaluation board pcb105. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
