Make endianess of target CPU configurable. Use the new config
option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through
endianess options to LD.
Build tested with:
- ELDK 4 mips_4KC- and mips4KCle
- Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by
running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
The current MIPS CPU config.mk code always expects a MIPS 4kc
core. This is not appropiate for other CPUs and SoCs.
Replace the current MIPSFLAGS code by cc-option macro and use
-march=mips32r2 as default optimization level for all MIPS32 CPUs.
Note: Since commit f62fb99941c625605aa16a0097b396a5c16d2c88 all
toolchains with binutils prior to v2.16 are not working anymore.
As agreed with Shinya Kuribayashi the support for those toolchains
will be dropped officially with this patch.
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
All current CPUs and SoCs are based on MIPS32 arch. The complete
code resides in the global arch/mips/cpu directory. This is not
suitable if other MIPS architectures like MIPS64 or Octeon should
be supported in the future.
To achieve this the current CPU code is moved to its own mips32
subdirectory. All MIPS32 boards have to use mips32 as config switch
in board.cfg.
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Lange <thomas@corelatus.se>
Cc: Vlad Lungu <vlad.lungu@windriver.com>
