path: root/arch/microblaze
2011-10-10microblaze: Copy bootfile from variablesMichal Simek
Setup bootfile. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-10microblaze: Fix unaligned.h for endiansMichal Simek
Also support little endian MB. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-10microblaze: Initialize jumptable and consoleMichal Simek
This changes were done to get support for netconsole. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-10microblaze: Support flashes on lower addressesMichal Simek
2011-10-10microblaze: Call common console_init_f initialization functionMichal Simek
Calling console_init_f enables CTRL+C usage. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-10-03microblaze: Clean up reset asm codeMichal Simek
- Remove code copying - Reset address is setup from first stage bootloader - Support reset vector setup on little endian Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-03microblaze: Save and restore first unused vectorMichal Simek
Use one memory space to detect little/big endian platforms. The first unused address(0x28) is used instead 0x0 address (reset vectors). Detection rewrited reset vector setup from first stage bootloader. Workflow: 1. Store 0x28 to r7 2. Do little/big endian test 3. Restore r7 to 0x28 Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-03microblaze: Setup MB vectors if feature is enable for u-bootMichal Simek
For example: Setup reset vectors if reset address is setup. Setup user exception vector if user exception is enabled Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-03microblaze: Remove debug saving valueMichal Simek
Forget to remove debug code. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-15microblaze: Fix msr handling in interrupt_handlerMichal Simek
Fix ancient code which worked with MSR in a bad way. Use rtid instruction which enable IRQs and jump. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-02-15microblaze: Fix systems with MSR=0Michal Simek
u-boot BSP generates XILINX_USE_MSR_INSTR macro even for system with MSR=0. That's why explicitly check that MSR=1. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-01-19Replace "FLASH" strings with "Flash" or "flash"Peter Tyser
There's no compelling reason to have the output on bootup or the "flinfo" command print "flash" in uppercase, so use the proper case where appropriate. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2011-01-10microblaze: Fix bd_info pointerMichal Simek
Patch "Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value" (sha1: 25ddd1fb0a2281b182529afbc8fda5de2dc16d96) introduce GENERATED_GBL_DATA_SIZE which is sizeof aligned gd_t (currently 0x40). Microblaze configs used 0x40(128) because this place also contained board info structure which lies on the top of ram. U-Boot is placed to the top of the ram (for example 0xd7ffffff) and bd structure was moved out of ram. This patch is fixing this scheme with GENERATED_BD_INFO_SIZE which swap global data and board info structures. For example: Current: gd 0xd7ffffc0, bd 0xd8000000 Fixed: gd 0xd7ffffc0, bd 0xd7ffff90 Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-01-10microblaze: Disabling interrupt should return 1 if was enabledMichal Simek
Microblaze implement enable/disable interrupts through MSR that's why disable_interrupts function should return 1 when interrupt was enabled. Return 0 when interrupt was disabled. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-18FDT: only call boot_get_fdt from generic codeJohn Rigby
All arches except nios2 and microblaze call boot_get_fdt from bootm_start in common/cmd_bootm.c. Having nios2 and microblaze do so as well removes code from their respective do_bootm_linux routines and allows removal of a nasty ifdef from bootm_start. In the case where boot_get_fdt returns an error bootm_start returns and the platform specific do_bootm_linux routines will never get called. Also only check argv[3] for an fdt addr if argc > 3 first. This is already the case for nios2. Signed-off-by: John Rigby <john.rigby@linaro.org> CC: Scott McNutt <smcnutt@psyent.com> CC: Michal Simek <monstr@monstr.eu> CC: Thomas Chou <thomas@wytron.com.tw> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-10-12microblaze: Support little-endian microblaze targetMichal Simek
Microblaze little-endian toolchain should export __MICROBLAZEEL__. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-10-12microblaze: Add support for NET_MULTI apiMichal Simek
Microblaze hasn't supported NET_MULTI support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-16microblaze: Consolidate cache codeMichal Simek
Merge cpu and lib cache code. Flush cache before disabling. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Flush cache before jumping to kernelMichal Simek
There is used max cache size on system which doesn't define cache size. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Support system with WB cacheMichal Simek
WB cache use different instruction that WT cache but the major code is that same. That means that wdc.flush on system with WT cache do the same thing as before. You need newer toolchain with wdc.flush support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Change initialization sequenceMichal Simek
env_relocation should be called first. Added stdio_init too. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Change cache report messagesMichal Simek
It is more accurate to show that caches are OFF instead of FAIL. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Fix interrupt handler codeMichal Simek
It is better to read ivr and react on it than do long parsing from two regs. Interrupt controller returs actual irq number. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Move FSL initialization to board.cMichal Simek
Move FSL out of interrupt controller. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Move timer initialization to board.cMichal Simek
I would like to handle case where system doesn't contain intc that's why I need timer initialization out of intc code. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Fix irq.S codeMichal Simek
It is ancient code. There is possible to save several instructions just if we use offset instead of addik Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-16microblaze: Add FDT supportArun Bhanu
This patch adds FDT (flattened device tree) support to microblaze arch. Tested with Linux arch/microblaze kernels with and without compiled in FDT on Xilinx ML506 board. Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-13microblaze: Move cpu/microblaze/* to arch/microblaze/cpu/*Peter Tyser
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
