path: root/arch/microblaze/lib
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-18fdt: Implement weak arch_fixup_fdt()Alexey Brodkin
Only ARM and in some configs MIPS really implement arch_fixup_fdt(). Others just use the same boilerplate which is not good by itself, but what's worse if we try to build with disabled CONFIG_CMD_BOOTM and enabled CONFIG_OF_LIBFDT we'll hit an unknown symbol which was apparently implemented in arch/xxx/lib/bootm.c. Now with weak arch_fixup_fdt() right in image-fdt.c where it is used we get both items highlighted above fixed. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-02-13microblaze: bootm: Fix compiler warningBin Meng
Fix build warning in arch/microblaze/lib/bootm.c with gcc 7.3.0: warning: this 'if' clause does not guard... [-Wmisleading-indentation] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-02libfdt: replace ARCH_FIXUP_FDT with ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Commit e2f88dfd2d96 ("libfdt: Introduce new ARCH_FIXUP_FDT option") allows us to skip memory setup of DTB, but a problem for ARM is that spin_table_update_dt() and psci_update_dt() are skipped as well if CONFIG_ARCH_FIXUP_FDT is disabled. This commit allows us to skip only fdt_fixup_memory_banks() instead of the whole of arch_fixup_fdt(). It will be useful when we want to use a memory node from a kernel DTB as is, but need some fixups for Spin-Table/PSCI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for x86: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09microblaze: Use standard interrupt_init() functionMichal Simek
Do not use microblaze specific interrupt init function. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-06-19fdt_support: delete force argument of fdt_initrd()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_initrd() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19microblaze: remove an empty file arch/microblaze/lib/time.cMasahiro Yamada
Commit 779bf42c moved timer functions from arch/microblaze/lib/time.c to arch/microblaze/cpu/timer.c. But the empty file, arch/microblaze/lib/time.c has been remaining probably for a human mistake. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-02-04microblaze: Add SPL supportMichal Simek
Add support for U-BOOT SPL. NOR and RAM mode are supported. There are 3 images in NOR flash. u-boot.img, dtb and kernel. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-04microblaze: Show u-boot bannerMichal Simek
It is nice to see u-boot version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-10-31microblaze: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-16microblaze: Fix watchdog initializationMichal Simek
The patch: "blackfin: Move blackfin watchdog driver out of the blackfin arch folder." (sha1: e9a389a18477c1c57a0b30e9ea8f4d38c6e26e63) changed hw_watchdog_init() prototype which didn't match with Microblaze one. This patch fixes the driver and Microblaze initialization. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-08microblaze: Call spi_init functionMichal Simek
Initialization spi. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26Clarify bootm OS argumentsSimon Glass
At present the arguments to bootm are processed in a somewhat confusing way. Sub-functions must know how many arguments their calling functions have processed, and the OS boot function must also have this information. Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in the same way. Adjust the code so that arguments are removed from the list before calling a sub-function. This means that all functions can know that argv[0] is the first argument of which they need to take notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-09microblaze: bootm: Add support for loading initrdMichal Simek
fdt_initrd add additional information to DTB about initrd addresses which are later used by kernel. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-09microblaze: bootm: Fix coding style issuesMichal Simek
Prepare place for new patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-01microblaze: fix style in board.cAndreas Bießmann
Make microblaze's board.c checkpatch clean. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Michal Simek <monstr@monstr.eu>
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-04microblaze: Add muldi3.c which contains routines for _muldi3David Holsgrove
Referenced arch/blackfin/lib/muldi3.c and the linux kernel. Resolves issue seen when building u-boot for HW_MUL=0; PLATFORM_CPPFLAGS += -mxl-soft-mul PLATFORM_CPPFLAGS += -mno-xl-multiply-high which resulted in error while linking to libgcc.a without mul hw (bs / m); libgcc.a(_muldi3.o): In function `__muldi3': .... src/gcc-4.6.2/libgcc/libgcc2.c:550: undefined reference to `_GLOBAL_OFFSET_TABLE_' This link failure would not occur if we used gcc instead of ld directly, as gcc will correctly use the crt's to resolve this link. Signed-off-by: David Holsgrove <david.holsgrove@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-07microblaze: Flush caches before enabling themMichal Simek
Flushing caches is necessary because of soft reset which doesn't clear caches. Signed-off-by: Michal Simek <monstr@monstr.eu> Reviewed-by: Marek Vasut <marex@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-09-11microblaze: board: Use bi_flashstart instead of CONFIG_SYS_FLASH_BASEMichal Simek
Prepare for device-tree driven configuration. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: Clean microblaze initializationMichal Simek
Move board specific function to board_init function in board/ folder Remove externs from generic board.c Use board_init_f function in board.c file. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: timer: Prepare for device-tree initializationMichal Simek
Fix CONFIG_SYS_HZ usage in board config. Do not use hardcoded value. Use CONFIG_SYS_HZ instead. Separate static configuration to single block. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-09-11microblaze: board: Remove compilation warningMichal Simek
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used. Warning log: board.c: In function 'board_init': board.c:101: warning: unused variable 's' Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: Add support for device tree driven board configurationMichal Simek
This is minimum code required to be able to use device-tree for u-boot initialization. Currently only for device driver initialization. Linker script change ensures DTB to be aligned for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net> CC: Simon Glass <sjg@chromium.org>
2012-07-10microblaze: intc: Clear interrupt codeMichal Simek
Clear and prepare for device-tree driven configuration. Remove CONFIG_SYS_INTC_0 definition Use dynamic allocation instead of static. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2012-07-10microblaze: Call serial multi initializationMichal Simek
2012-07-10microblaze: Move __udelay implementationMichal Simek
Move __udelay to the timer code because of unification. And clean coding style because of checkpatch.pl. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2012-07-10microblaze: Remove extern from board.cMichal Simek
eth_init() is defined at include/net.h. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23microblaze: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-10microblaze: Copy bootfile from variablesMichal Simek
Setup bootfile. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-10microblaze: Initialize jumptable and consoleMichal Simek
This changes were done to get support for netconsole. Signed-off-by: Michal Simek <monstr@monstr.eu>
