The patch:
"blackfin: Move blackfin watchdog driver out of the blackfin arch folder."
(sha1: e9a389a18477c1c57a0b30e9ea8f4d38c6e26e63)
changed hw_watchdog_init() prototype which didn't match
with Microblaze one.
This patch fixes the driver and Microblaze initialization.
Initialization spi.
Acked-by: Stephan Linz <linz@li-pro.net>
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
[trini: Fixup common/cmd_io.c]
Delete all occurrences of hang() and provide a generic function.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Modify check around puts() in hang.c slightly]
Make microblaze's board.c checkpatch clean.
Reviewed-by: Michal Simek <monstr@monstr.eu>
Watchdog can be used on Microblaze, PPC and Zynq hw designs.
Reviewed-by: Tom Rini <trini@ti.com>
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI
or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI
is now enabled by default.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tom Rini <trini@ti.com>
Cc: Stefan Roese <sr@denx.de>
Prepare for device-tree driven configuration.
Move board specific function to board_init function in board/ folder
Remove externs from generic board.c
Use board_init_f function in board.c file.
Fix CONFIG_SYS_HZ usage in board config.
Do not use hardcoded value. Use CONFIG_SYS_HZ instead.
Separate static configuration to single block.
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used.
Warning log:
board.c: In function 'board_init':
board.c:101: warning: unused variable 's'
This is minimum code required to be able to use device-tree
for u-boot initialization.
Currently only for device driver initialization.
Linker script change ensures DTB to be aligned
for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE.
CC: Simon Glass <sjg@chromium.org>
Clear and prepare for device-tree driven configuration.
Remove CONFIG_SYS_INTC_0 definition
Use dynamic allocation instead of static.
eth_init() is defined at include/net.h.
All arches init this the same way, so move the logic into the core
net code to avoid duplicating it everywhere else.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
This changes the board code to use the new getenv_ulong() function.
Setup bootfile.
This changes were done to get support for netconsole.
Calling console_init_f enables CTRL+C usage.
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
There's no compelling reason to have the output on bootup or the
"flinfo" command print "flash" in uppercase, so use the proper case
where appropriate.
Patch "Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value"
(sha1: 25ddd1fb0a2281b182529afbc8fda5de2dc16d96)
introduce GENERATED_GBL_DATA_SIZE which is sizeof aligned gd_t
(currently 0x40).
Microblaze configs used 0x40(128) because this place also contained
board info structure which lies on the top of ram.
U-Boot is placed to the top of the ram (for example 0xd7ffffff)
and bd structure was moved out of ram.
This patch is fixing this scheme with GENERATED_BD_INFO_SIZE
which swap global data and board info structures.
For example:
Current: gd 0xd7ffffc0, bd 0xd8000000
Fixed: gd 0xd7ffffc0, bd 0xd7ffff90
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Microblaze hasn't supported NET_MULTI support.
env_relocation should be called first.
Added stdio_init too.
It is more accurate to show that caches are OFF instead of FAIL.
Move FSL out of interrupt controller.
I would like to handle case where system doesn't contain
intc that's why I need timer initialization out of intc code.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
